    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • qwertyasQ
      qwertyas
      @fredo6 said:
      @qwertyas said:
      all fredo6 plugins stopped to work after last fredo6 lib update. Sketchup 2020.
      To test if the problem is related to other plugins, I removed all my plugins from the plugin folder, and installed only sketchucation. From sketchucation plugin I installed fredo cuviloft and fredo6 lib (newest = 12.8a) and restarted Sketchup. Curviloft does not work. You can click on any of the icons but the tool does not initialize (standard cursor and prompt still visible)
      https://ibb.co/QN3Dyb0
      Could you open the Ruby Console before lunching Curviloft
      yes, here you are:
      Error: #<NoMethodError: undefined method visual_version' for SCFLicense:Module> c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1733:in tem_context'
      c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1709:in tem_launcher' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:119:in launch_action'
      c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in launch_action' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action'
      c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:93:in block in startup' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1460:in command_invoke'
      c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1441:in block (2 levels) in build_config_commands' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1378:in block in add_command'
      fredo6-console hosted at ImgBB
      Image fredo6-console hosted on ImgBB
      ImgBB (ibb.co)
      • fredo6F
        @qwertyas
        You need to upgrade to the latest version of Sketchucation ExtensionStore v4.2.4.
        Apparently, you have an old version.
          @qwertyas said:
          Windows 10 Home
          Please complete your profile with that and the SketchUp version after you update the Sketchucation Extension Store as Fredo6 directed.
          • qwertyasQ
            qwertyas
            @dave r said:
            @qwertyas said:
            Windows 10 Home
            done.
            Curviloft plugin is working now. Thanks!
            • qwertyasQ
              qwertyas
              @fredo6 said:
              @qwertyas
              I updated the plugin and reinstalled both Fredo6 Lib and Curviloft. It is working now. Thank you!
                @qwertyas said:
                It is working now.
                Excellent! And thank you for completing your profile.
                  jose_w650
                  NO ES UN PLUGIN GRATUITO, SOLO FUNCIONA UNA TEMPORADA.
                  PERO PARECE UTIL, GRACIAS
                    Translated by Google:
                    @jose_w650 said:
                    IT IS NOT A FREE PLUGIN, IT ONLY WORKS FOR ONE SEASON.
                    BUT IT SEEMS USEFUL, THANK YOU
                    LibFredo6 is available at no charge. A few of Fredo6's extensions are no longer free after their trial periods expire.
                    What version of SketchUp are you using? Your profile says 2021 Free/Make but there is no such version.
                      Scozzarella
                      New LibFredo6?
                      when it will be available?
                      • fredo6F
                        NEW RELEASE: LibFredo6 v12.9a - 13 May 22
                        LibFredo6 12.9a includes:
                        • Various fixes for my plugins
                        • Support for LOTT v2.1a
                          Scozzarella
                          Thank you It works perfectly!
                          • T
                            thortoist
                            Hi I Have been a fun of your works and using it for a few years. time has past that I am in need to try a new version of plugins and sketchup.
                            From that day of reinstalling everything I have been spending days figuring out how to make your plugins work.
                            I have tried installing and reinstalling versions of libFredo from 7 to 12, but still I am getting the error of [please install LibFredo 6.9 or above].
                            I have tried degrading my sketchup version. trying installing different libFredo version. but nothing works.
                            Hope to get an answer soon to this problem. I am really in need of using curviloft.
                            Thank you in advanced. Have a great day.
                            • fredo6F
                              It looks like a problem of installation.
                              First can you confirm which version of Sketchup you run (SU2018?)?
                              Second, go to the Plugin folder of Sketchup and erase Fredo6_!LibFredo6.rb and Fredo6_!LibFredo6 subfolder. Same for Fredo6_Curviloft.rb and Fredo6_Curviloft subfolder.
                              Then, download and install fresh copy from the Sketchucation web site, or better, Use the Sketchucation ExtensionStore to install the plugins in one click.
                                adrianavitor
                                Is this plugin not free anymore? Can't use anything and keeps asking for a licence.
                                  @adrianavitor said:
                                  LibFredo6 is still available at no charge but some of the extensions that rely on it are no longer free as of a few months ago.
                                  See: https://sketchucation.com/forums/viewtopic.php?f=323&t=74668
                                  • K
                                    karimtabbara
                                    fredo_error_plugin_license.jpgHello
                                    I read all, but still cannot find the answer to my problem.
                                    I have saved all my licenses file into a personal folder.
                                    When I click on "Validate a License" and choose the proper file, I get an error message "ERROR_F09".
                                    I have already used correctly those licenses.
                                    But last time there registration must have been "lost"
                                    I haven't been able t use these plugins for a long time because I found no way to validate them...
                                    As I really need them, It's now time for me to use them again.
                                    Could you please help?
                                    Print screen
                                      Your screenshot of the license window for FredoCorner shows an old, outdated version of the license manager. The current version is 5.7a - 50. Update the Sketchucation Extension Store and restart SketchUp.
                                      • K
                                        karimtabbara
                                        Hello
                                        Thank you for your answer but still the same problem even after updating ALL.
                                        I even downloaded my license again, though I had kept a copy of the file.
                                        More of all the dialog box searches for a "FredoCorner.scflicense" so called file.
                                        But the file name is SCF_Purchased_License_RoundCorner_NORMAL_20220417.scflicense
                                        Please see screen copy.
                                        I've been spending quite some time trying.
                                        I'm I the only one to be frustrated ?
                                        I have been using Fredo Corner for years for free with no problem.
                                        I'm happy to contribute.
                                        But now that I have (contributed), won't work...
                                        Many thanks for some help
                                          You are trying to apply the license for Round Corner to FredoCorner. They are two different extensions and require different licenses. The license for Round Corner doesn't work for FredoCorner.
                                          [Am] I the only one to be frustrated ?
                                          No. Others have made the same mistake. Not sure if it's a language translation problem or comprehension problem or what but the two extensions are just not the same and one license won't work for the other.
                                          Either install Round Corner and apply the license to it or get the license for FredoCroner. It's worth having both of them. There are some cases where one of them will work better than the other depending on the geometry you've modeled.
                                            jeon7373
                                            seek help!!
                                            I'm using sketchup version 2021.
                                            If you install and run FREDO6 LIBRARY, an error box appears.
                                            I don't know what went wrong
                                            Error Loading File Fredo6_!LibFredo6.rb
                                            Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                            c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:821:in match' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:821:in block (2 levels) in load_from_config'
                                            c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in each' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in block in load_from_config'
                                            c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:818:in foreach' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:818:in load_from_config'
                                            c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1233:in block in load_all_plugins' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1233:in each'
                                            c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1233:in load_all_plugins' c:/users/subin/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:310:in startup'
                                            C:/Users/subin/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/subin/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                                            C:/Users/subin/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                                            • 90
                                            • 91
                                            • 92
                                            • 93
                                            • 94
                                            • 115
                                            • 116
                                            • 92 / 116
