[Plugin] LordOfTheToolbars - v2.7b - 07 Apr 24
@fredo6 said:
This UTF8 error is puzzling.
I don't know if it is related to your Cyrillic environment.
After all, there were no problems before (((
Also, which version of Windows do you run?
Windows 10 Pro v.20H2
What was your environment 'before' when it worked?
Fredo if you already implemented double space-bar for Repeat last.. Is it theoretically possible to implement 2-letter shortcuts via plugin (LOTT)?
Like in Revit, for example PB for Profile Builder? I always wanted this feature in SU -
@aismebel said:
I donโt remember what error caused SketchUp to close. But that was in SU 2020. Then I installed SU 2022 and your plugin still doesn't work
Would you mind to do a Repair of SU2022 to see if this fixes the problem.
Same for SU2020 if you still have it on your computer. -
Same for SU2020 if you still have it on your computer.Does your plugin share a file that is referenced by SU 2020 and SU 2022?
Maybe a settings file? Or something in the registry? Perhaps there was an error and this file needs to be updated.
SU 2022 has already done recovery. It didn't help me. -
The error is in Sketchup: some menu texts are wrongly encoded (or are read as such). I don't think this is directly related to LOTT.
Another user has a similar problem, running a French version of Sketchup 2021, but only on one computer.
Hi, I use the Lord of the toolbar program with satisfaction But since yesterday I have this error message which in any case does not prevent me from continuing to work. the error presents us at the Start of SketchUp, I would like to know what it is from and how to solve it, given the great usefulness of this program for me who are disabled.
some extensions are referenced in palettes but not loaded - unknown command sketchup
The latest version of LOTT tracks command icons of extensions which are referenced in palettes but are no longer present (for instance, when you uninstall them, or when you import configuration from another version of Sketchup. It displays a notification at startup if there are some, usually indicating the name of the command and extension.
It might be that there is a problem there. I'll have a look.
Without this plugin I can't work with skp, congratulations. how can I solve this problem? thanks, skp 2022 fredo lib updated.
It may not be a problem actually. The notification automatically disappears after a few seconds.
Do you have issue with LOTT, in particular about 'ghost icons', that is icons in palettes that would have a rounded rectangle around and are disabled?
I managed to solve the problem by uninstalling and deleting all the temporary files created by Fredo \ Users \ xxx \ AppData \ Local \ LIBFREDO6_DATA_Dir \ LOTT \ GHOST now I no longer have the error at startup
But now Fredo Corner no longer works, with a regular license. I deduce that the problem is caused by the combination of Lord of toolbars v12.5a with fredo Corner v2.5a.I await updates
NEW RELEASE: LordOfTheToolbars v2.0a - 24 Feb 22
Requirements
- LibFredo6: v12.4a or above
- Sketchup version: SU2017 and above
LordOfTheToolbars 2.0a includes
- Adjustment for notification at startup of Sketchup
Home Page of LordOfTheToolbars for information and Download.
Hi fredo6,
I am also having a problem with LOT, not a big one but the plugin is not loding with sketchup, I have to manualy open it by navigationg to tools>fredo6>LOT>Master Toolbar Manager, or any other menu that forces LOT to start, and my custom toolbars lose placement, the toolbars are reseting to floating toolbars.
I have sketchup 2022 on windows 10, everytinh is up to date.
It worked before the latest update. -
Could you update to LibFredo6 v12.7a and check if you see errors displayed in the Ruby console at startup.
Hi Fredo,
Sorry I didn't answer back but it seams I don't get any emails with replays, I didn't know there is no email notifications ...
I keep all plugins up to date. Right now I have LibFredo6 12.8a the latest.
The issue is still present and I have attached what comes up in the console at startup.If you don't find anything relevant to help me fix this from what I am sending should I try a full reinstall of sketchup and see if that works?
Thank you very much for your time.
Thanks !
Having similar problem... the plug-in seems to work fine, but I can't get the vignette stripe to display. I can see it with "pop up the vignette stripe" but it comes up as a floating menu and then disappears when I click away.
