    1.5k Posts 471 Posters 3.4m Views 470 Watching
      Can you show what you are seeing that indicates that RoundCorner has expired? There's never been an expiration on RoundCorner. Fredo has done frequent updates on his extensions over the years although Round Corner hasn't had one since December of 2018. Is it possible you also have FredoCorner and you are seeing that its trial period has expired? If that's the case you can purchase a license for it and continue using it. Fredo6 has a sale going on right now, too.
      What version of SketchUp are you using? Please complete your profile.
        Kabayashi_san
        Не работает на последних версиях скеча((( Что делать? 😢 😢 😢 😢
        Doesn't work on latest sketch versions (((What to do? 😢 😢 😢 😢
          It works fine in the latest versions. Here it is in SketchUp 2021.
          Click on the picture
          Maybe it's your model or your settings. Or maybe you need to install or update LibFredo6. You could also use FredoCorner.
          Give specific information about what isn't working.
          • E Offline
            Einstein
            Hello,
            In SketchUp 2021 I got this error after installing Round Corner (see the attached screenshot).
            The plugin seems to be working just fine, despite the error.
            I just thought you might want to know about it. I was actually advised to report it to you anyway.
              We need to wait for @Fredo's reply...
              But before that.. do you have the latest LibFredo installed ?
                Wasn't there an issue with the User name being "user" because of the \u thing?
                • E Offline
                  Einstein
                  Yes, I had the latest LibFredo installed first.
                  And indeed, my system username is "User". I don't know about any issue related to that, but maybe there is one.
                  • fredo6F Offline
                    I don't think this is related to username 'user'.
                    I would suggest that you clean up LibFredo6 and RoundCorner and reinstall. Never seen this issue reported by other users. So, there must be something specific in your environment.
                    • E Offline
                      Einstein
                      Actually, I'm now quite sure that this "something specific in my environment" is my system username starting with capital "U" letter, which causes an issue of Ruby interpreter. Here you can read more from smarter people than me:
                      SketchUp keeps crashing when installing plugins
                      Hello, I recently reinstalled the newest version of SketchUp and started installing my dozens of plugins from scratch. That’s what I was advised to do. I found time to manually install them one by one instead of just …
                      SketchUp Community (forums.sketchup.com)
                        szabgergo
                        Hello there,
                        I have some problems with the round corner plugin so I would like to ask for your help.
                        There is a drawer front model and I would like to round the corners but it has some overlaps.
                        How can I fix that issue in a way that it would look like it does on the attached photo.
                        Thank you very much!
                          Reduce the radius a bit. Or use FredoCorner. it seems to handle that better than Round Corner. Or use the Dave Method. Here I've created a component, copied it, scaled the copy up by 1000, run Round Corner on the big one, exited edit mode, deleted the giant copy and went back to the original.
                            rv1974
                            Variable radius fillets would look wonderful inside SU..
                            https://www.youtube.com/watch?v=MGaZZ4frjLQ
                              rosto
                              Is it exist RoundCorner version for SU 2016 ?
                                You can use the PluginStore search feature at the top of the forum page tofind extensions.
                                SketchUp Plugins | PluginStore | SketchUcation
                                SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                (sketchucation.com)
                                  shannonnovus
                                  Hi. I just got a popup saying Round Corner will expire in two days. Please no!!! This plugin saves me so much time. I greatly appreciate this and all other Fredo6 plugins. Thanks for being a pillar of the SketchUp community!
                                    See the sticky thread at the top of this forum.
                                    http://sketchucation.com/forums/viewtopic.php?f=323&t=74668
                                    Make sure you are running the most recent version of Round Corner
                                      skyskipper
                                      1. Should probably remove all references to the word "free"
                                      2. Should probably fix the extension crashing SketchUp after the first use and claiming the 30-day free trial ended after 3 minutes.
                                      • fredo6F Offline
                                        I updated the post to indicate the licensing
                                        @skyskipper said:
                                        1. Should probably fix the extension crashing SketchUp after the first use
                                        what crash do you get?
                                        I don't know if there is any problem with my code (I am checking that), but anyway, there has been a 12 years free trial period.
                                        • BoxB Offline
                                          A 12 year free trial barely gives us time to test it, let alone make money from it. 💚
                                            abdullahc
                                            I'm Living in turkey and my trial licence is over. I want to obtain licence but the only payment methot with paypal and the problem is starting here because Paypal is blocked in turkey we can't buy anything with paypal. What I'm gonna do now, please need a help. 😢 😢 😢
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 73
                                            • 74
                                            • 55 / 74
