    [Plugin][$] FredoSpline - v2.6a - 01 Apr 24
    149 Posts 40 Posters 201.1k Views 40 Watching
      You have used all 3 three seats available. Release a license/s on already licensed devices to free up seats.
      • T
        tyuliop
        hi πŸ˜„ I tried to use fredospline today,
        but this error message pops up and I can't use it. I installed the latest version.
        Is there another latest version on fredospline?
        • ArcA
          Arc
          Dear Fredo, this version was expired, please update new version ASAP.
          • fredo6F
            Oooops...! forgot to update
            New version FredoSpline v2.2a published
            • fredo6F
              NEW RELEASE: FredoSpline v2.2a - 31 Aug 21
              Requirements
              • LibFredo6: v11.6a
              FredoSpline 2.2a is a maintenance release for extension of validity
              Home Page of FredoSpline for information and Download.
              Main post of this FredoSpline thread.
              • X
                xyhcwu
                I have purchased a perpetual license, why does it still indicate that it has expired?
                I often use it without internet and it's a pain 🀣
                • fredo6F
                  Sorry for that. This is intened to make sure that user upgrade so that it makes the maintenance easier. The new version does not expire.
                  But if you wish, we can refund the license....
                  • X
                    xyhcwu
                    Thank you for your reply, I will always support you! fredo
                      Jakewyatt4
                      I updated to the latest version, now it wants me to relicense to which I try and get this error any ideas?. As you can see I successfully licensed it fine back in July.
                        rv1974
                        Fredo, Polycorner tool with Seg parameter set on maximum (96s) produces only 2 segment fillets 😞 if the corner is >/= 171 degr. Is there possibility to tweak the algorithm so the wide angle conrers would get more segments?
                        • fredo6F
                          It's computed automatically for the whole curve. Did you try to select the corner and tweak its #seg360 locally (click on the small circle and a panel in green should open)?
                            rv1974
                            Of course, I understand and thankfully use the whole curve instant processing.
                            I'm talking about further refinement of this global computation - 2 segments max for wide angle situation is not enough.
                            Is it possible (as option) to process corners with the same number of segments?
                            Or give an extra option for a minimum number of segments?
                            Manual tweaking won't help - 96 value is Max. And besides.. manual tweaking is not desired.
                            • fredo6F
                              NEW RELEASE: FredoSpline v2.3a - 01 Nov 21
                              Requirements
                              • LibFredo6: v12.2a
                              FredoSpline 2.3a includes a parameter to set the minimum number of segments for PolyCorner curves. This may be useful when the angle if close to 180 degree. The parameter can be set in the Default Parameters dialog. By default, it is set to 8.
                                rv1974
                                Amazing, huge thank you Fredo!
                                  junak
                                  Hi Fred,
                                  Great plugin! I found an issue where when editing the points on a closed curve that defines a surface - sometimes the surface will break for no reason. It works as expected on most edits but regularly there are some edits that just won't work, even when a plane is selected. I haven't been able to establish a pattern of what causes the issue to happen. I found a workaround for the moment but it's time consuming - once the surface disappears after an edit, I copy the curve and paste onto a new surface. My workaround actually proves that my curve is still flat and the issue is indeed a bug. Please let me know if you'd like me to send a video of the reproduction.
                                  J
                                  EDIT:
                                  Here is a link to the a reproduction of the issue: https://www.dropbox.com/s/k0ilok2zwdcay6n/Sketchup%20FredoSpline%20Bug%20Repro%20HB.mp4?dl=0
                                  As you can see toward the end of the video, editing the points sometimes break for no apparent reason. This has been a workflow killer for me as it prevents from editing curved borders in situ.
                                  PS: Unfortunately, I was not able to attach it here as mp4 are not allowed.
                                  • B
                                    bullit
                                    Fredo Spline not showing popup menu or control points
                                    SketchUp 2017 installed on Mac OSX 10.14.6 (Mojave). FredoSpline_v2.3a, LibFredo6_v12.5b installed.
                                    Sketchup working normally. FredoSpline toolbar loads, able to show quick launcher. When Create toolbar button pressed, no popup menu shows up; quill pointer shows up with no β€œ+”, and clicking does not add control points
                                    • fredo6F
                                      Could you open the Ruby console before launching FredoSpline, to see if there are errors displayed.
                                      • T
                                        TheOnlySkydiveBadger Newcomers
                                        What an awesome tool! Works well, but I ran into an unexpected problem.
                                        What works well? When I draw brand new curves in an empty/new workspace.
                                        What doesn't work (for me)? When I try to copy/trace a curve. It won't allow me to even add a point on top of an image. I would load a drawing, and I want to trace the curves on it, but the tool won't allow me even moving into the bounds of the loaded image. The cursor gets stuck on the boundary between the "open space" and the loaded image...
                                        Any ideas?
                                        Sketchup PRO
                                        Version 22.0.353
                                        MAC
                                          Share a SketchUp model file in which this happens so we can see what you are working with and trying to accomplish.
                                          • T
                                            Hi Fredo,
                                            I cannot reply directly to you, so here goes...
                                            It looks like your fix worked! I only did some rudimentary testing, but the initial issue doesn't exist anymore. This is great news, thank you so much for such a quick response! MUCH appreciated!
                                            Badger
                                            • 5 / 8
