    [Plugin]Mesh to Poly
    21 Posts 9 Posters 17.0k Views 9 Watching
    • ithilI
      ithil
      Oh my God!
      This is a holiday!
      Great news!
      about Zbrush
      I agree. It is dangerous to ๐Ÿ˜ƒ
      But at least a little billet..
        Yea, as pilou says, QFT has both an OBJ importer and exporter to complete the workflow of moving quad meshes between other applications. Again it's somewhat hidden. ๐Ÿ˜ž I really need to get on to updating the docs.
        • panixiaP
          panixia
          @pilou said:
          Import ZBrush obj file is a little dangerous! ๐Ÿ˜„
          Make some decimation before! ๐Ÿ’š
          pilou i strongly reccommend z-remesher over decimation master for such stuff ๐Ÿ‘
          actually in the beta stage of the importer a zbrush (z-remeshed) model was used, and that worked pretty fine!
          here is my proud puppet "Pollo" happly imported with proper textures and quads in sketchup for the first time
          more of the original Pollo with all displacement and stuff in action here ๐Ÿคฃ
          https://www.youtube.com/watch?v=3Zd8mFH7bGY
          @pilou said:
          Sounds similar to what QuadFace Tools do - with Sandbox Quads to QuadFace Tools quads.
          ๐Ÿ˜ฎ what a huge doooh-moment. i used to run selection toys "select only soften" for that.. a couple of clicks more.. every time ๐Ÿ˜’
            Yes any functions who reduce, transform this enormous mass of polygons! ๐Ÿ˜‰
            • panixiaP
              panixia
              yes for sure that's the first goal, but in this particular case.. i was suggesting z-remesher over decimation master because that not only reduces the polycount, but also provides nice and clean flowing quad-topology and a good base for unwrapping and putting all polypaint detail into one texture you can use in sketchup.. โ˜€
              not sure that would work with decimation master too..
              here is the wireframe from the low-poly sketchup version of pollo achieved with zremesher + quadface tools .obj importer
              and below you can compare the final unwrap-texture and some of the original photos taken from real-world Pollo, used to texture it by Z-app link..
              i don't know if and when i will have the time to finish it with proper sub-tool for eyes and hands.. ๐Ÿ˜’
                dkdude
                Hey guys, it doesn't work on my pc, I am using sketchup 2016. any suggestions? thx!
                • N
                  nnightdream
                  Hi, Mesh to Poly doesn't work on my PC. What am I doing wrong? I tried to use sketchup 2016 and 2017. I have last version SUBd plugin.
                  Thanks.
                  Mesh to poly doesn't work
                  • panixiaP
                    panixia
                    Thanks.
                    Because the plugin need the edges (for the diagonals) to be set on "soft and smooth" and just turns off the "cast shadows" property.
                    Your triangles are not soft (and I believe not smooth too) so it will not work on them.
                    • N
                      nayazerez
                      hi! I installed the extension through extension manager, but I cant find a tab it the toolbars! can you plz help with that?? thanks!
                        @nayazerez said:
                        .....I cant find a tab it the toolbars! can you plz help with that?? thanks!
                        Try Plugins(Extensions) >> Ithil Tools >> Mesh to Poly
                        • 2 / 2
