    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.4k Views 113 Watching
    • samuel_tS
      samuel_t
      Hello Mike,
      Don't mind about OBJ πŸ˜‰ It's used as intermediate format during process...
      Could you please provide us the link to the tank you're trying to simplify?
      Did you try with other models?
      • MikeG73M
        MikeG73
        Hello Samuel,
        Here is the link to the Panther, and no I haven't tried your extension on any other model as of yet as I was immersed in this model at the time of my postings; but I will try it again soon.
        Cheers Mate! 😎
        3D Warehouse
        (3dwarehouse.sketchup.com)
        • MikeG73M
          MikeG73
          Hello Samuel,
          Were we able to find out anything on this model? or do I need to download something similar and try that route?
          Cheers Mate!
          • samuel_tS
            samuel_t
            Hello Mike,
            On my Windows 10 computer with SketchUp 2017, process hangs at 50% when plugin imports simplified "Panther" model. So yes, I suggest you to try with other models.
            • B
              BklynBoy
              Samuel - I have had a great deal of difficulty importing obj files into Sketchup. Here are two examples of error messages. Can you help? I tried to upload the obj files but I couldn't. Thanks.
              • samuel_tS
                samuel_t
                @BklynBoy, could you please upload these OBJ files somewhere? This way I could also try on my PC.
                • MikeG73M
                  MikeG73
                  Hello Samuel.
                  I'm sorry but I am having another issue with your importer and need your advice, I recently bought some models from Turbosquid and downloaded/saved them as obj files which thankfully I can convert them over with your wonderful extension; however when I try to convert the models your extension seems to only use some textures and not all of them. 😲
                  So should/can I upload the mtl files when I am converting these models? 😳 😎
                  Cheers Mate
                  • samuel_tS
                    samuel_t
                    Hello Mike, Could you please send me a (temp) link to these OBJ and MTL files in a private message?
                      autumnwind
                      Hello Samuel,
                      First, thanks for the plugin, the idea is very cool.
                      The only problem I encountered is that when I try to reduce the polygon count, instead they will increase (together with the size of the 3D model) and it's the opposite result of what I'm trying to achieve. What do you suggest?
                      Face count before reduction: 261609
                      Face count after reduction: 4544015
                      My target was 80000
                        rv1974
                        Samuel, thanks for creating and sharing this plugin.
                        Question: is it possible to to implement the original scale, units and origin respect (in fbx at least)?
                        • samuel_tS
                          samuel_t
                          @autumnwind said:
                          Hello Samuel,
                          My target was 80000
                          Hello Autumn Wind,
                          Try to start with a greater target (eg. 200000) then decrease...
                          • samuel_tS
                            samuel_t
                            I don't think so... πŸ˜• The scale is lost during model conversion. I'd study the question if I find the time πŸ˜‰
                            • C
                              coro28
                              How do I install your Universal Importer plugin in Sketchup 2021 Pro?
                              • samuel_tS
                                samuel_t
                                Follow instructions given in Universal Importer plugin documentation.
                                  If you use the PluginStore you login, find and download an RBZ archive for an extension.
                                  Typically you save it in your Downloads folder.
                                  In SketchUp use the Extension Manager and in its dialog use the Install... button, select the RBZ and it auto-installs for you...
                                  Alternatively, if you have the SketchUcation Toolset installed then you find an extension's entry in its ExtensionStoreΒ³ dialog [red toolbar button opens that] and click the button against its entry in the dialog to install it automatically... [essentially skipping the need to manually download an RBZ file...]
                                  • F
                                    fabrice
                                    Hello
                                    Thank you very much for this plugin.
                                    But I also have a problem with sketchup 2017, unable to import an obj, yet I have given the permissions.
                                    A miracle solution ?? 🀣
                                      Find the folder C:/ProgramData/Universal Importer/
                                      Select its icon - select it and right-click > context-menu > Properties > Security > Edit...
                                      Ensure that every entry listed has FULL permissions set...
                                      OK to save changes.
                                      Thereafter you should be able to read/write/delete files in that subfolder or its tmp folder...
                                      • F
                                        fabrice
                                        great, it works THANKS !!!!
                                        • E
                                          ekoek0999
                                          thanks a million!
                                          I was looking for a way to import pmx files into Sketchup, this one does the trick perfectly
                                          You are a lifesaver!!!
                                            Moltres Rider
                                            Plugin DOES NOT work with Sketchup 2020 😞 STILL NO OPTION to import obj files and fbx files. In fact, it did not add a single new file format to import. Still just the usual default stuff 😞
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 22
                                            • 23
                                            • 14 / 23
