    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    104 Posts 40 Posters 144.1k Views 39 Watching
    • G
      gnome_mo
      I didn't think that was the problem, since it drilled simple circle, no problem.
      But I really need those spaces between them, is it at all possible?
        Seems you can't!
        But if you draw a rectangular box between the 2 existing that will works! 😉
        So not a big deal if you know that from the beginning! 😄
        Just erase the "Joint(s)" at the end! 😄
          Something like this 😄
            jeff1harmed
            I downloaded and installed VisuHole_v1.4b. I got random results on curved surfaces, and frequent crashes on SU2017. Great potential but unrealised in my case and I had to uninstall
              Did you also install the latest Lib Fredo ?
              • K
                kochmichi86
                I have a problem with trying to bend small letters (1cm) on a cylinder as the picture shows in the attachement.
                Could anyone help ?
                  No attachment !
                  If your object is too small, then SketchUp can't cope.
                  Points closer that 1/1000" - as might be created by your tiny sizes and processes - are deemed to be coincident.
                  Then the tiny edges aren't created and their faces are also lost !
                  Try Scaling things up x10 or more and see if that helps ??
                    ACWN
                    For some reason I'm having trouble making a stencil. It seems that when I attempt to make a multi-shaped stencil (such as to drill 4 holes of equal size and spacing through a tube), I cannot select the group. Or, if I'm able to, it does not correctly make the stencil.
                    I've attached the most recent stencil I'm trying to make. The goal is to punch out the holes and leave behind what would be a frame. Yes, I now realize I can go about it a different way, but my problem with making a stencil still stands and I need to know if its something I'm doing thats incorrect or what. So to that end, I've also included a clip of what I'm doing to make the stencil and the results.
                    So this current stencil is already 60' tall, so it should be large enough but as you can see in the clip, it doesnt trigger like it should.
                    Can someone tell me whats going on? Thanks!
                    Component_3.skp
                    Visuhole.wmv
                      Hello
                      You must click a single face or a group or a component of something planed to the XY axes for make a stencil! 😉
                      Can be of course at any z but must be // to xy plane! ❗
                      So your vertical one is impossible! 🤓
                      • fredo6F
                        Actually, you can pick the stencil in any plane, which is given by the face you click.
                        But don't click-drag, when you do that. Just click-release
                          Cool! ☀ So I was half wrong! 💚
                            ACWN
                            It doesnt show it very well, but I was actually doing just that right at the beginning of the video. Right around 12 - 14 seconds, when I put the mouse to the center of the group and suddenly get the demo shapes. If I click-release, nothing happens. Uploaded a new movie to show.
                            However when I flip it so its laying flat like Pilou says to, I get it right away. 😕
                            Visuhole2.wmv
                            • fredo6F
                              When the stencil is based on a group or component, I was lazy to assume that the Z axis was to be sued as the plan for the stencil.
                              I made a change in LibFredo6 v9.5f to treat more general cases.
                              • G
                                Gildaspaspro
                                Bonjour,
                                Tout d'abord merci Fredo pour tout ces plugins extraordinaires qui me font tout les jours gagner des heures de dessin. On a du te le dire pleins de fois mais c'est vrai, t'es le boss!!!
                                Petite suggestion sur celui-ci. Il me semblerait intéressant d'ajouter des marquages sur l'axe des perçage (ou des extrusions également). On pourrait de cette facon non seulement les déplacer/copié + facilement (notamment, lorsqu'on "perce" un trou cylindrique simple, on perd l'intégrité du cercle et donc son centre) mais également de coter et de mettre en plan beaucoup plus rapidement.
                                Si j'ai pu faire avancer modestement le shmilblick....
                                • O
                                  odd Byberg
                                  I have yet to find the way to cut through my outer wall that is made of 3 solids going all around the building.
                                  So if I cut through my first wall ( 6 faces), I will also make an opening at the back ( 6 more faces to o through). And I find I can limit it to only the first cut, but then Im only 1/3 through my wall.
                                  Is there a way to set max drill depth, so it goes all the way through my wall, but does not reach the back walls.?
                                  • B
                                    Buckyman
                                    I have used Visuhole successfully to stamp a logo into my model
                                    I noticed after converting to STEP file with FreeCAD that there are many hidden lines after the stamping, see "after carve.jpg"
                                    After the carve operation my model is no longer solid. I used CleanUp3 to clean up the model, after that there were a few lines I deleted manually.
                                    SolidInspector2 says it is a solid
                                    Solid Solver says it is not
                                    I am just wondering if the extra lines are to be expected after a carve operation or is there some setting in Visuhole that would avoid this?
                                    thx
                                    • fredo6F
                                      Because of the two holes, the front face will become quite busy with edges when you carve the logo. If your model is at small scale, this can generate issues with the shape being manifold.
                                      Possibly, you may try by putting rectangular edges around the holes over the main face to isolate them.
                                      • B
                                        Buckyman
                                        Or do the carve first, Holes after??
                                        • H
                                          Hannahdesigns88
                                          When I try to download this visuhole plug in, it says its not a sketchup model and wont let me download it...or even begin to download. I have sketch up pro 2022 windows.
                                            Extensions cannot be opened by SketchUp. You need to use Extensions > Extension Manager to install the .RBZ file
                                            • 4 / 6
