[Plugin] FredoTools - v4.5a - 02 Apr 24
@oheimala said:
Hi. The "Solid volume" is very useful in my job, thanks a lot! A great add to it would be a mass calculator. Just an input for material density and the solid mass would be seen; or a even better if a tiny sheet to save some own densities. I have not found any plugins for easy mass reporting. Cheers!
"SUSolid.com" plugin works great for weights. You can input any materials you like.
hello fredo we are a smal company and ve use fredo tools in our job,
thank u for this amazing addon,
we want an extra feature in fredo tool for that we try to contact with you.
pls contact with us. -
NEW RELEASE: FredoTools v4.1b - 10 Jul 21
Requirement: LibFredo6 v10.4b or above
FredoTools 4.1b fixes major bugs in ColorByAltitude (min-max boundaries, wrong coloring on Mac)
See FredoTools plugin home page for Download.
See also main post of this thread for User Discussion.
what I mean is we want to export the information of the model drawn in sketchup as .peb,
Is this possible or should a new plugin be written?
We have the necessary protocol information and details.
We hope you can help us with this situation, if a new plugin needs to be written we would like to hire you or if you have any other way of working and plans we would like to hear from you. -
Installed newest LibFredo6, then FredoTools v4.1b and to this error:
I uploaded again the rbz file on the Sketchucation store. Can you try.
NEW RELEASE: FredoTools v4.1c - 13 Jul 21
FredoTools 4.1c fixes major bugs in ColorByAltitude (min-max boundaries, wrong coloring on Mac). It is a republishing of v4.1b
V4.1C worked as advertised, thanks for all your great extensions.
NEW RELEASE: FredoTools v4.1d - 13 Sep 21
FredoTools 4.1d fixes a bug in MoveAlong, whereby the autosmooth option was always active
NEW RELEASE: FredoTools v4.2a - 17 Sep 21
Requirement: LibFredo6 v12.0a or above
FredoTools 4.2a fixes a bug in MoveAlong, whereby the autosmooth option was smoothing all edges
NEW RELEASE: FredoTools v4.3a - 06 Mar 22
Requirement: LibFredo6 v12.5a or above
FredoTools 4.3a is for compatibility with a future plugin
Download gives an error.
The download page only displays this error message:
/pluginrepo/rbz/
/var/www/html/pluginrepo/rbz/FredoTools.rbz
File does not exist. Make sure you specified correct file name.and I can't download the extension
/pluginrepo/rbz/
File does not exist. Make sure you specified correct file name.There was an issue with the file repository earlier but it should be fixed now. Try the download again.
Hi There,
I have just noticed that FredoTools icon has disappeared from my toolbar in SU Pro 2021 (Windows 10 Pro latest updates etc) and is not listed in the toolbars list when right clicking. The plugin was loaded according to Sketchucation plugin/extension manager, as well as in the Sketch native extension manager.
I tried to upgrade to the latest version through the Sketchucation store, but I am getting an error that says UnZIP Error: Could not unzip archive. I have tried the archive install manager as well with the same issue. When installing the extension via the Sketchup native extensions manager, the error is:
Failed to install FredoTools_v4.3a.rbz.I have just updated LibFredo6 to the latest version and restarted Sketchup and tried everything again with the same errors occurring... I have also uninstalled FredoTools from Sketchup, but cannot seem to get it back.
Related or not related, I have just purchased the pack of 8 previously free plugins and installed curvizard, visuhole and Lord of the Toolbars which I previously did not have. These were the last extensions I installed.
Any ideas as to what the problem could be? Thanks for any insight.
Make sure you have the latest version of the Sketchucation Extension Store tool installed.
Have you installed the latest version of the SketchUcation Toolset from the PluginStore.
It has code changes to circumvent the UNzip error a few users were getting...
However, these we not normally on PCs with newer SketchUp versions [please update your profile at SCF to show the correct details...]
After the [re]install of the Toolset restart SketchUp and reinstall FredoTools from a new RBZ download or through the ExtensionStore³ dialog directly...
Restart SketchUp and see if it improves - you might need to [re]enter a license - depending on what you've done so far... -
Many thanks for this Dave and TIG for your in-depth suggestions. As if by magic, the Sketchucation update worked and I have FredoTools back... After restarting SketchUp again.
how to download
