    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 790.3k Views 121 Watching
    • fredo6F Offline
      NEW RELEASE: FredoTools v4.0b - 06 Dec 20
      Requirement: LibFredo6 v10.4b or above
      FredoTools 4.0b is a minor release for ReportLabelArea, offering an option for automatic refresh of the reports.
      See FredoTools plugin home page for Download.
      See also main post of this thread for User Discussion.
      • fredo6F Offline
        @einstein said:
        Still, I think this could be an option. Not a default one, but an available setting. I personally use this tool for low number of faces and with fast computer. Auto-recalculation would not be counterproductive for me. But it's just a suggestion πŸ˜„
        Here it is....
        The option is in the Default Parameters.
        • E Offline
          Einstein
          @fredo6 said:
          Here it is....
          Thank you reeely much! You are fantastic πŸ˜„
            kenteichmann
            I just downloaded Fredotools-v4.ob-06Dec20 to be used with Sketchup Pro 2021. I have the latest Windows 10 PC. I open the Fredotools download and I get this message. "This does not appear to be a Sketch model." I get the message with Sketchup 2021 open and unopened. DOES Fredotools-v4.ob WORK IN 2021 SKETCHUP?
              You don't open extensions in SketchUp with File>Open. Instead, go to the Window menu, click on Extension Manager and then the Install Extension button. Navigate to where you saved the extension file, select it, and choose Open. Also make sure you download and install the LibFredo6 file as well.
              Better would be to go to Resources at the top of this page and download the Sketchucation Plugin Store tool. Install that as above and then use it to search for and install Fredo6's extensions and others. If you do that the installation is automatically done correctly and you'll be able to see when there are updates to extensions.
              And yes, Fredotools works just fine in SketchUp 2021.
              • fredo6F Offline
                NEW RELEASE: FredoTools v4.1a - 24 Apr 21
                FredoTools 4.1a is a technical release for performance of selection contextual menu.
                  kakashi66
                  I love FredoTools, especially Thru Paint. I have come across an issue that may be know or not. I didn't feel like going through 14 pages to see.
                  I noticed that when using TP, if you shift to pan the tool changes to the picker tool not the paint tool. If I shift pan again it goes back to the paint tool. Is this something that can be fixed?
                  SU pro 2020
                  FredoTools 4.1a
                  LibFredo6 11.8a
                  • fredo6F Offline
                    Thanks for catching this problem. Definitely a bug which needs to be fixed.
                    • O Offline
                      oheimala
                      Hi. The "Solid volume" is very useful in my job, thanks a lot! A great add to it would be a mass calculator. Just an input for material density and the solid mass would be seen; or a even better if a tiny sheet to save some own densities. I have not found any plugins for easy mass reporting. Cheers!
                        cadmunkey
                        "SUSolid.com" plugin works great for weights. You can input any materials you like.
                          tcn_ozgr
                          hello fredo we are a smal company and ve use fredo tools in our job,
                          thank u for this amazing addon,
                          we want an extra feature in fredo tool for that we try to contact with you.
                          pls contact with us.
                          • fredo6F Offline
                            NEW RELEASE: FredoTools v4.1b - 10 Jul 21
                            FredoTools 4.1b fixes major bugs in ColorByAltitude (min-max boundaries, wrong coloring on Mac)
                              tcn_ozgr
                              what I mean is we want to export the information of the model drawn in sketchup as .peb,
                              Is this possible or should a new plugin be written?
                              We have the necessary protocol information and details.
                              We hope you can help us with this situation, if a new plugin needs to be written we would like to hire you or if you have any other way of working and plans we would like to hear from you.
                                ct103stu0
                                Installed newest LibFredo6, then FredoTools v4.1b and to this error:
                                • fredo6F Offline
                                  I uploaded again the rbz file on the Sketchucation store. Can you try.
                                  • fredo6F Offline
                                    NEW RELEASE: FredoTools v4.1c - 13 Jul 21
                                    FredoTools 4.1c fixes major bugs in ColorByAltitude (min-max boundaries, wrong coloring on Mac). It is a republishing of v4.1b
                                      ct103stu0
                                      V4.1C worked as advertised, thanks for all your great extensions.
                                      • fredo6F Offline
                                        NEW RELEASE: FredoTools v4.1d - 13 Sep 21
                                        FredoTools 4.1d fixes a bug in MoveAlong, whereby the autosmooth option was always active
                                        • fredo6F Offline
                                          NEW RELEASE: FredoTools v4.2a - 17 Sep 21
                                          Requirement: LibFredo6 v12.0a or above
                                          FredoTools 4.2a fixes a bug in MoveAlong, whereby the autosmooth option was smoothing all edges
                                          • fredo6F Offline
                                            NEW RELEASE: FredoTools v4.3a - 06 Mar 22
                                            Requirement: LibFredo6 v12.5a or above
                                            FredoTools 4.3a is for compatibility with a future plugin
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 21 / 24
