    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    446 Posts 109 Posters 455.8k Views 109 Watching
    • MikeG73M Offline
      MikeG73
      Hello Samuel,
      Here is the link to the Panther, and no I haven't tried your extension on any other model as of yet as I was immersed in this model at the time of my postings; but I will try it again soon.
      Cheers Mate! 😎
      3D Warehouse
      (3dwarehouse.sketchup.com)
      • MikeG73M Offline
        MikeG73
        Hello Samuel,
        Were we able to find out anything on this model? or do I need to download something similar and try that route?
        Cheers Mate!
        • samuel_tS Offline
          samuel_t
          Hello Mike,
          On my Windows 10 computer with SketchUp 2017, process hangs at 50% when plugin imports simplified "Panther" model. So yes, I suggest you to try with other models.
            BklynBoy
            Samuel - I have had a great deal of difficulty importing obj files into Sketchup. Here are two examples of error messages. Can you help? I tried to upload the obj files but I couldn't. Thanks.
            • samuel_tS Offline
              samuel_t
              @BklynBoy, could you please upload these OBJ files somewhere? This way I could also try on my PC.
              • MikeG73M Offline
                MikeG73
                Hello Samuel.
                I'm sorry but I am having another issue with your importer and need your advice, I recently bought some models from Turbosquid and downloaded/saved them as obj files which thankfully I can convert them over with your wonderful extension; however when I try to convert the models your extension seems to only use some textures and not all of them. 😲
                So should/can I upload the mtl files when I am converting these models? 😳 😎
                Cheers Mate
                • samuel_tS Offline
                  samuel_t
                  Hello Mike, Could you please send me a (temp) link to these OBJ and MTL files in a private message?
                    autumnwind
                    Hello Samuel,
                    First, thanks for the plugin, the idea is very cool.
                    The only problem I encountered is that when I try to reduce the polygon count, instead they will increase (together with the size of the 3D model) and it's the opposite result of what I'm trying to achieve. What do you suggest?
                    Face count before reduction: 261609
                    Face count after reduction: 4544015
                    My target was 80000
                      rv1974
                      Samuel, thanks for creating and sharing this plugin.
                      Question: is it possible to to implement the original scale, units and origin respect (in fbx at least)?
                      • samuel_tS Offline
                        samuel_t
                        @autumnwind said:
                        Hello Samuel,
                        My target was 80000
                        Hello Autumn Wind,
                        Try to start with a greater target (eg. 200000) then decrease...
                        • samuel_tS Offline
                          samuel_t
                          I don't think so... πŸ˜• The scale is lost during model conversion. I'd study the question if I find the time πŸ˜‰
                            coro28
                            How do I install your Universal Importer plugin in Sketchup 2021 Pro?
                            • samuel_tS Offline
                              samuel_t
                              Follow instructions given in Universal Importer plugin documentation.
                                If you use the PluginStore you login, find and download an RBZ archive for an extension.
                                Typically you save it in your Downloads folder.
                                In SketchUp use the Extension Manager and in its dialog use the Install... button, select the RBZ and it auto-installs for you...
                                Alternatively, if you have the SketchUcation Toolset installed then you find an extension's entry in its ExtensionStoreΒ³ dialog [red toolbar button opens that] and click the button against its entry in the dialog to install it automatically... [essentially skipping the need to manually download an RBZ file...]
                                • F Offline
                                  fabrice
                                  Hello
                                  Thank you very much for this plugin.
                                  But I also have a problem with sketchup 2017, unable to import an obj, yet I have given the permissions.
                                  A miracle solution ?? 🀣
                                    Find the folder C:/ProgramData/Universal Importer/
                                    Select its icon - select it and right-click > context-menu > Properties > Security > Edit...
                                    Ensure that every entry listed has FULL permissions set...
                                    OK to save changes.
                                    Thereafter you should be able to read/write/delete files in that subfolder or its tmp folder...
                                    • F Offline
                                      fabrice
                                      great, it works THANKS !!!!
                                      • E Offline
                                        ekoek0999
                                        thanks a million!
                                        I was looking for a way to import pmx files into Sketchup, this one does the trick perfectly
                                        You are a lifesaver!!!
                                          Moltres Rider
                                          Plugin DOES NOT work with Sketchup 2020 😞 STILL NO OPTION to import obj files and fbx files. In fact, it did not add a single new file format to import. Still just the usual default stuff 😞
                                            https://i.imgur.com/pTrxpA5.png
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
