    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 629.0k Views 113 Watching
    • MikeG73M
      MikeG73
      Hello Samuel,
      I installed your latest release on sketchupmake2017 and can not use it as it is unsigned, please update your extension with a signed version. ๐Ÿ˜Ž
      Cheers Mate!
        @mikeg73 said:
        I installed your latest release on sketchupmake2017 and can not use it as it is unsigned...
        Unsigned does not make it unusable unless you set the loading policy to prevent it.
        Please update your profile. It says you are using Sketchup 8.
        • MikeG73M
          MikeG73
          Thank you for your reply, however, I do I know or turn off this loading policy? So I won't have any issues?? And I have updated my profile, thank you!
          Cheers Mate! ๐Ÿ˜Ž
            I presume you mean, "I do not know how to turn off this loading policy." Is that correct. Go to Window>Extension Manager and click on the gear icon in the upper right corner. Choose Unrestricted for the loading policy. Restart SketchUp.
            • MikeG73M
              MikeG73
              Hello Samuel/folks,
              It appears that I am having the same issue with converting models, I looked at previous posts but still can't make sense of it all; as the file I downloaded from the warehouse was a 2017skp I tried to reduce the size but kept getting the same error messages as above.
              I then exported the original skp file to 3ds and tried it again and got the same error message, as it looks like UI is still looking at this file as an obj and not a 3ds import. Is there a video/fix to this ongoing issue or am I just missing something!? ๐Ÿ˜ฎ ๐Ÿ˜•
              Cheers! ๐Ÿ˜Ž
              • samuel_tS
                samuel_t
                Hello Mike,
                Don't mind about OBJ ๐Ÿ˜‰ It's used as intermediate format during process...
                Could you please provide us the link to the tank you're trying to simplify?
                Did you try with other models?
                • MikeG73M
                  MikeG73
                  Hello Samuel,
                  Here is the link to the Panther, and no I haven't tried your extension on any other model as of yet as I was immersed in this model at the time of my postings; but I will try it again soon.
                  Cheers Mate! ๐Ÿ˜Ž
                  3D Warehouse
                  (3dwarehouse.sketchup.com)
                  • MikeG73M
                    MikeG73
                    Hello Samuel,
                    Were we able to find out anything on this model? or do I need to download something similar and try that route?
                    Cheers Mate!
                    • samuel_tS
                      samuel_t
                      Hello Mike,
                      On my Windows 10 computer with SketchUp 2017, process hangs at 50% when plugin imports simplified "Panther" model. So yes, I suggest you to try with other models.
                      • B
                        BklynBoy
                        Samuel - I have had a great deal of difficulty importing obj files into Sketchup. Here are two examples of error messages. Can you help? I tried to upload the obj files but I couldn't. Thanks.
                        • samuel_tS
                          samuel_t
                          @BklynBoy, could you please upload these OBJ files somewhere? This way I could also try on my PC.
                          • MikeG73M
                            MikeG73
                            Hello Samuel.
                            I'm sorry but I am having another issue with your importer and need your advice, I recently bought some models from Turbosquid and downloaded/saved them as obj files which thankfully I can convert them over with your wonderful extension; however when I try to convert the models your extension seems to only use some textures and not all of them. ๐Ÿ˜ฒ
                            So should/can I upload the mtl files when I am converting these models? ๐Ÿ˜ณ ๐Ÿ˜Ž
                            Cheers Mate
                            • samuel_tS
                              samuel_t
                              Hello Mike, Could you please send me a (temp) link to these OBJ and MTL files in a private message?
                                autumnwind
                                Hello Samuel,
                                First, thanks for the plugin, the idea is very cool.
                                The only problem I encountered is that when I try to reduce the polygon count, instead they will increase (together with the size of the 3D model) and it's the opposite result of what I'm trying to achieve. What do you suggest?
                                Face count before reduction: 261609
                                Face count after reduction: 4544015
                                My target was 80000
                                  rv1974
                                  Samuel, thanks for creating and sharing this plugin.
                                  Question: is it possible to to implement the original scale, units and origin respect (in fbx at least)?
                                  • samuel_tS
                                    samuel_t
                                    @autumnwind said:
                                    Hello Samuel,
                                    My target was 80000
                                    Hello Autumn Wind,
                                    Try to start with a greater target (eg. 200000) then decrease...
                                    • samuel_tS
                                      samuel_t
                                      I don't think so... ๐Ÿ˜• The scale is lost during model conversion. I'd study the question if I find the time ๐Ÿ˜‰
                                      • C
                                        coro28
                                        How do I install your Universal Importer plugin in Sketchup 2021 Pro?
                                        • samuel_tS
                                          samuel_t
                                          Follow instructions given in Universal Importer plugin documentation.
                                            If you use the PluginStore you login, find and download an RBZ archive for an extension.
                                            Typically you save it in your Downloads folder.
                                            In SketchUp use the Extension Manager and in its dialog use the Install... button, select the RBZ and it auto-installs for you...
                                            Alternatively, if you have the SketchUcation Toolset installed then you find an extension's entry in its ExtensionStoreยณ dialog [red toolbar button opens that] and click the button against its entry in the dialog to install it automatically... [essentially skipping the need to manually download an RBZ file...]
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 22
                                            • 23
                                            • 13 / 23
