[Plugin] LordOfTheToolbars - v2.7b - 07 Apr 24
Hi All,
I have recently updated to SU2023 and this is my first time hearing about a UI limitation and it having a negative effect on LOTB.Since updating LOTB and SU, my personal buttons I've created, have stopped working. They are greyed out as if the extension/plugin is not associated with it.
When I 'edit' or create 'New' the next window that pops up should show all the extensions/plugins to associate with the icon/button - as you see, this is Blank. even when i search...
Is the UI limitation in SU2023 my problem ? or me doing it wrong? or something else, otherwise its working as expected.
Cheers in Advance
SU2023 has introduced a radical change of the UI technical framework (migrating to Qt).
As a result, all features related to Menu commands and Clear Screen cannot work and are disabled in SU2023.
Sorry for that. I don't think there will be a solution for the future, as there is no longer any API to access menus and screen visual elements.
I posted a workaround a few pages before
https://sketchucation.com/forums/viewtopic.php?f=323&t=73776&start=270#p687744
@fredo6 said:
This is indeed sad news! LOTB has speeded up my work. Its quick, easy and (was) very adapatble. I am still a keen fan and will be a tester if ever you need help with further developments.
Cheers for all your hard work
Chris -
Chrismy 2 cents: Just make ONE large vertical (say 6X30) palette, add separators\line breaks where needed - so everything is in one place perfectly organized on the 2nd monitor. No need in extra menus or palettes (maybe except history). the rest is shortcuts and tool search
Hi. Personally, I still haven't figured out how to use your method ((( Will you have the opportunity to write instructions in more detail for noobs
Thanks for the 2cents. Sounds great - Not sure if it helps me with the buttons I’d created for plugins that don’t have buttons. But I do take you’re point about short cuts. I have so many though it’s hard to keep them in my head, especially the ‘used occasionally’ variety. Also I am running out of suitable key combinations ! Ha ha. I tend to keep everything on the left hand side of the keyboard for speed and one hand.
@cmeed
My 2c are related to your disappeared menus, custom icons are aside -
NEW RELEASE: LordOfTheToolbars v2.7a - 02 Apr 24
Requirements
- LibFredo6: v14.3b or above
- Sketchup version: SU2017 and above
LordOfTheToolbars 2.7a is a maintenance release for:
- Future compatibility
Home Page of LordOfTheToolbars for information and Download.
NEW RELEASE: LordOfTheToolbars v2.7b - 07 Apr 24
Requirements
LordOfTheToolbars 2.7b is a maintenance release for:
- SU2024
- Fix for shortcuts
- Visual adjustment for palettes
@fredo6 Hello dear Fredo. I would like to ask you if you can expect to repair the "menu" tab in new versions of SU in your future updates?
Hello dear fredo, I am a heavy user of Lott. I upgraded from su2021 to 2024 and noticed some issues. When I right-click on an icon, only the system native icon like 1 will pop up a menu, while most icons like 2 will not pop up a menu. Is this my problem or is it a bug? I hope to receive your help. Thank you
No scroll bars?
can't get to the button at bottom of windows ?
With the 2024 version, I am trying to configure new palettes, how ever the ability to add line breaks, separators etc is missing from the right-click menu.
Do you see the commands if you right-click ON an icon?
@fredo6 If I right-click on an icon there are no commands shown. This is using Win 10 (if that makes a difference).
It seems that the problem might be related to the Text Scaling factor in Windows, as per this post on the Sketchup Forum.
@fredo6 My latest LOTT (win11, SU24) lost right click (on icons) menu shown by
17628046164 6 posts above. Might it be fixed please?
