    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • GD3DesignG
      GD3Design
      Great modeling, use of Subdiv and cartoon render...but just as important, full of character. Love it. πŸ˜„
      • HornOxxH
        HornOxx
        Thanks All πŸ˜‰ I very much appreciate that you like this little simple "character" fun πŸ˜„
        never trust a skinny cook
        • B
          Builder54
          Carpenter Ant
          I post my models here because I want illustrate to others who may be interested in Organic modelling that it's quite possible with Sketchup, largely because of the amazing extensions (QuadFace Tools, Vertex Tools 2, and SUbD) that ThomThom developed. The more I work with them the greater appreciation I have. Model on!
          The painted low poly model was later edited to improve on the leg detail. You can see in the Substance Painter example below how the legs had lost their definition after subdivision. I later used QuadFace Tools to add loops to maintain shape.
          Substance Painter
          I used the free trial of V Ray and Substance Painter to add some realism. I have not had any prior experience with either so the results are not good, but they do help to add some realism.
          V-Ray
          "Don't be afraid of working hard. There are No shortcuts to mastering something."
          Robh Ruppel
          • HornOxxH
            HornOxx
            Klasse! πŸ‘ Great work again. (I love these SketchUp illustrations even more than the rendered versions)
            • alvisA
              alvis
              A short biology lesson πŸ˜„ . Nice
              • B
                Builder54
                Thank you HornOxx. I tend to agree with you. The thing I like about Substance Painter is being able to stay in 3D. But I know what you mean about the raw modelling illustrations. Cheers
                Robh Ruppel
                • B
                  Builder54
                  Too funny πŸ˜† The reference photo helped me to redraw the legs to keep their shape and definition
                  Robh Ruppel
                  • tuna1957T
                    tuna1957
                    Don’t really like ants. But your ants β€œbitchin ” ! πŸ‘
                    • B
                      Builder54
                      A compliment of the highest order hahaha. Thanks tuna1957
                      Robh Ruppel
                      • B
                        Builder54
                        My favorite Sci-Fi character
                        Robh Ruppel
                        • tuna1957T
                          tuna1957
                          Builder54, Great job on a complex character ! πŸ‘
                          Now to return to earth..... as time allows I go back into my early SubD models and try to fix "rookie" mistakes. Reworked one of my first SubD sofas. Lots of mistakes in the first go round πŸ˜† . Second time around looks much better and even lower poly to boot.... 😎
                          • B
                            Builder54
                            Thanks very much!
                            Interesting you mention the lower poly count. I'm becoming increasingly aware that my models have way to many poly's, and the key is to keep it simple and strategic.
                            Robh Ruppel
                              ramonbastos
                              Hello! I noticed that when I use SubD, it creates some polygons that are not really necessary, making the file bigger. You can see in the example below:
                              Polygons generated by SubD
                              Here I erased some lines just to show that they were not necessary.
                              I tried using TT's cleanup, looks like it removes some "random" lines. Of course its not random, but it leaves a lot of lines that I can erase and keep the same geometry.
                              Any tips on how to optimize it?
                              • GD3DesignG
                                GD3Design
                                See if 'Fixit 101' will get you where you're going.
                                • cottyC
                                  cotty
                                  It's propably because of the SketchUp (inofficial) quad definition:
                                  "two triangles share an edge which is soft and smooth - with Cast Shadows turned off"
                                  [https://evilsoftwareempire.com/subd/quads]
                                  my SketchUp gallery
                                  • N
                                    nlipovac
                                    [attachment=1:1fj1e773]<!-- ia1 -->panela 01.png<!-- ia1 -->[/attachment:1fj1e773]
                                    [attachment=0:1fj1e773]<!-- ia0 -->Screenshot_53.png<!-- ia0 -->[/attachment:1fj1e773]
                                    I think this is the way Open SubDiv works, it subdivides polygons and does not care if they are coplanar after subdivision.
                                    If you use the Cleanup plugin after you are done with subdivision then you are actually doing decimation of that model by removing edges from coplanar polygons.
                                    Where you can get in trouble after you do Cleanup is texturing where there could be some distorted texture on those polygons.
                                    • B
                                      Builder54
                                      You could try tweaking with Vertex Tools Merging Close Vertices. It's demonstrated in this video
                                      Robh Ruppel
                                        ramonbastos
                                        Thanks! Great plugin by the way. It worked better than cleanup, but still left some coplanar edges, and looks random too, that will give me trouble when texturing. (See attachment)
                                        Unfortunately didn't work, some edges that I did not want to merge, got merged.
                                        • B
                                          Builder54
                                          On a hot summer's night you may hear the buzzing sound produced by a cicada.
                                          Cicadas Brood X 2021
                                          Sketchup Pro 2017
                                          QuadFace Tools, Vertex tools, SUbD
                                          Robh Ruppel
                                          • panixiaP
                                            panixia
                                            [attachment=1:155faezl]<!-- ia1 -->panela 01.png<!-- ia1 -->[/attachment:155faezl]
                                            [attachment=0:155faezl]<!-- ia0 -->Screenshot_53.png<!-- ia0 -->[/attachment:155faezl]
                                            The proper way to remove those quads triangulations when it is possible (for those quads which are coplanar, that's why you can erase them) would be, after you are done with modeling, to convert the mesh into "plain mesh" and then select all and run the "remove triangulation" command from QuadFaceTools.
                                            Please notice that you are visually erasing those triangulation at Sketchup interface level, but at "machine level" those triangles are still present, so the model will not perform any better in any render engine or game engine, because stuff need to be triangulated in GPU.
                                            What actually matters in therms of model performances are mainly the amount of vertices, the number of drawcalls, the size/compression of the textures, good UV's (if you have too many UV-islands the machine will see much more vertices than you see in the viewport).
                                            Actually I tend to keep those triangles, because they make for proper exporting files.
                                            If you don't triangulate, many external formats/engines/applications will triangulate them in some automated way and you can get weird results, in particular smoothing/texturing artifacts.
                                            If you are into unwrapping/game engine stuff, like I am, you have to love those triangulations and want to have full control over them, instead of having some weird algorithm doing unpredictable stuff in background.
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 83
                                            • 84
                                            • 74 / 84
