    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 906.0k Views 144 Watching
      As they are both made as Groups you can easily select each of those in turn - in the Model or using the Outliner, and then use Entity Info to assign another preferred Layer [Tag] to them...
      • pbacotP
        Thanks for the suggestion.It should be easy but I spent some time figuring out how to get the parts organized this time.
          MTHPumps
          Hi, I was successful in generating a terrain with skirt from my 2D contour map, however, I'm trying to export to Sweet Home 3D in DAE, 3DS, or OBJ formats but the only format that is working at all is the DAE format. Even so, the terrain is coming in as 3D contour lines only and no surfaces or skirt. I'd like to place the home I designed on the terrain, but can't seem to figure out how to bring the 3D model into Sweet Home in a useful way. Am I missing something in Toposhaper, Sketchup, or is the DAE file format a limiting factor?
          Any thoughts would be appreciated....MTHPumps
          • T
            TeKnoel
            Hi this is still a very valuable plugin and one of the most powerful ways of transforming CAD typographical information into 3d. It would be even more powerful if we could get it to output meshes that were compliant with the new Quad workflow that subdivision surfaces utilizes. I imagine you're familiar with the requirements. would it be a big job to update?
            • fredo6F
              The problem might be in Sweet Home. The terrain generated by TopoShaper is just a regular group with a set of regular faces.
              • fredo6F
                Are you referring to the properties of the diagonal of quads?
                • pbacotP
                  I wonder if there can be a solution to the effect of "stair-stepping"? In this image you see a couple of conditions. One is the long steps in line with the contours, for no apparent reason--the contours are fairly even. One low slope area becomes a little plateau followed by a "step" to the next contour.
                  There's a dirt road traversing the slope. While i don't expect much definition in this case, the steps or pockets along the road are misleading.
                  Is some interpolation required? The contours are at 2' intervals. Or is the resolution of the grid too high? I chose a grid that turns out to be about 2.5' (more fine that I generally use).
                  • fredo6F
                    I think it's always better to model the terrain without artefacts like roads or building foundations, when it is possible. Then you can carve the roads and building on a clean terrain.
                    Do you have the isocontours lines. You should probably edit them and suppress the points that are corresponding to the road. TopoShaper is not too sensitive when contour are missing, and often gives a better smoothing when there are not too many contours or they are not too close.
                    • pbacotP
                      OK. thanks. I could probably take out the road. So closer intervals is not the answer.
                        menes
                        Hello,
                        I need help!
                        I'm puzzled and I can't get on top of this issue
                        this great plugin from the time I've installed the new 2020 SU it's not working as it was effectively before...
                        I attach some files maybe someone understands what's going on
                        thanks, everybody will be going to help
                        Alberto
                        initial status of isolines
                        preview
                        terrain created...not correct!
                        • fredo6F
                          I would suggest you do not select the quadrangular base contour, just the isocontours.
                          Best would be that you attach the model.
                            menes
                            Hello,
                            thank you very much for your reply...
                            "I would suggest you do not select the quadrangular base contour, just the isocontours.
                            Fredo"
                            I didn't included the base contour...but the problem remains
                            I add here the file , thank you
                            Best
                            Alberto
                            TOPO 3D CLEANED.skp
                            • fredo6F
                              Actually, it's a matter of scale. Your model is far too small (height is 30 cm).
                              So scale it by a factor of 1000 and it will give give normal results.
                                menes
                                LOL .... 🤣
                                you're right...sometimes we getting lost with the most stupid thing...
                                thank you very much...sorry.
                                Best regards
                                Alberto
                                  menes
                                  I've just imported from Autocad from a Topographer...and I didn't scale it at all 😆
                                  Thank you again
                                    menes
                                    ah ...by the way
                                    You are great Fredo ...admiration!
                                      sgb1456
                                      I keep getting an error while using the extension with Sketchup 2021. Ill post the text below:
                                      Date: 03-Mar-21 10:06:57
                                      An error occurred in CLEANSING
                                      The operation is fully aborted
                                      cannot hide layer that is a part of the active path
                                      body_lib6tool.rbe: 2538 -- visible=
                                      body_lib6tool.rbe: 2538 -- block in switch_to_temp_layer
                                      body_lib6tool.rbe: 2537 -- each
                                      body_lib6tool.rbe: 2537 -- switch_to_temp_layer
                                      toposhapertool.rbe: 1391 -- change_view
                                      toposhapertool.rbe: 1358 -- set_preview_working
                                      toposhapertool.rbe: 544 -- cleansing_processing
                                      toposhapertool.rbe: 523 -- after_selection
                                      toposhapertool.rbe: 493 -- notify_edge_picked
                                      body_lib6edgepicker.rbe: 539 -- call
                                      body_lib6edgepicker.rbe: 539 -- notify_action
                                      body_lib6edgepicker.rbe: 595 -- terminate_current_selection
                                      toposhapertool.rbe: 658 -- execute_validate
                                      toposhapertool.rbe: 387 -- handle_initial_selection
                                      toposhapertool.rbe: 319 -- activate
                                      toposhapertool.rbe: 133 -- select_tool
                                      toposhapertool.rbe: 133 -- action__mapping
                                      lib6plugin.rbe: 129 -- call
                                      lib6plugin.rbe: 129 -- launch_action
                                      lib6plugin.rbe: 227 -- launch_action
                                      bootstrap_toposhaper.rbe: 83 -- launch_action
                                      bootstrap_toposhaper.rbe: 136 -- block in startup
                                      lib6plugin.rbe: 1347 -- command_invoke
                                      lib6plugin.rbe: 1328 -- block (2 levels) in build_config_commands
                                      lib6traductor.rbe: 1377 -- block in add_command
                                      Should I just reinstall Sketchup 2020? I can't live without this extension!
                                      • fredo6F
                                        You do NOT need to reinstall Sketchup. Maybe relaunch it and try again.
                                        Otherwise, if you could post or PM me the model, this would help.
                                        • G
                                          Grey24601
                                          Hi Fredo,
                                          Brilliant plugin.
                                          What am I doing wrong here? When I select cloud I get a yellow triangle warning as if the guide points have not been selected? It worked earlier without any problems?
                                          Thanks in advance.
                                            Maybe you could upload the .skp file so we can see what you're working with?
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 19 / 23
