    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 906.0k Views 144 Watching
    • fredo6F
      This is a limitation of Toposhaper. Vertical faces should be created after the 'natural' terrain has been generated. Vertical faces usually correspond to excavations, road borders, etc.. and should be created along with these objects.
      • L
        LTiNaTOwpole
        Understood, thanks.
        I'm curious whether there is another program out there that can create accurate models with vertically stacked contours.
        • Didier BurD
          Didier Bur
          MeshLab http://www.meshlab.net/
          DB
          • G
            gbelcik
            Hello,
            First off, your plugin is remarkable! The terrain from point cloud is working fantastic, but I am running into an issue with a crash to desktop on generation of the quad terrain from ISO-Contours. I tested the example files using the same method and it generates fine. I have attached my file, could anyone maybe explain what I am doing wrong?
            Land Plot.skp
            • fredo6F
              I don't have a problem
              • when generating the triangulated terrain from guide points
              • when generating the terrain in quadmesh, after extracting the iso-contours from the triangulated terrain
              I wonder also what is the object mixing guide points and edges on the right (picture below).
              Can you tell me where it crashes.
              Gbelcik - Land Plot.skp
              • G
                gbelcik
                The object is a triangulated point map DXF import.
                It crashes to desktop approximately 1 second after generating the terrain from ISO contours, I have attached images. I am going to test generation on a different PC today and see if that works.
                • V
                  VaVa0VaVa
                  Hi thanks a lot for this plug in, I've been looking for something of the sort for a very long time.
                  I have a question, and aware this might not be the right place but maybe you're able to address me to the right topic.
                  I've got the elevation data in a cad file (from a survey), but how do I import it into sketchup so that it recognises it as guide points?
                  • B
                    Beaver99
                    Fredo, your plugins give sketchup a huge lift and usefulness that without them sketchup would be second rate.
                    many thanks for all your plugins and thank you for offering them free... sketchup should be paying you.! im going to donate to you now,!
                    • pbacotP
                      Onto another project with the great TopoShaper! You know what I think would be nice (when you work on this again)--if Toposhaper made separate components of the contours and terrain models, and put them on new separate layers. These are things I do every time to be able to work with it thereafter. That's what I think anyway. ☀
                      Thank you for the great plugins!
                      • fredo6F
                        Contours and terrain are already created in separate groups.
                        I can however put them of specific layers if it helps.
                          As they are both made as Groups you can easily select each of those in turn - in the Model or using the Outliner, and then use Entity Info to assign another preferred Layer [Tag] to them...
                          • pbacotP
                            Thanks for the suggestion.It should be easy but I spent some time figuring out how to get the parts organized this time.
                              MTHPumps
                              Hi, I was successful in generating a terrain with skirt from my 2D contour map, however, I'm trying to export to Sweet Home 3D in DAE, 3DS, or OBJ formats but the only format that is working at all is the DAE format. Even so, the terrain is coming in as 3D contour lines only and no surfaces or skirt. I'd like to place the home I designed on the terrain, but can't seem to figure out how to bring the 3D model into Sweet Home in a useful way. Am I missing something in Toposhaper, Sketchup, or is the DAE file format a limiting factor?
                              Any thoughts would be appreciated....MTHPumps
                              • T
                                TeKnoel
                                Hi this is still a very valuable plugin and one of the most powerful ways of transforming CAD typographical information into 3d. It would be even more powerful if we could get it to output meshes that were compliant with the new Quad workflow that subdivision surfaces utilizes. I imagine you're familiar with the requirements. would it be a big job to update?
                                • fredo6F
                                  The problem might be in Sweet Home. The terrain generated by TopoShaper is just a regular group with a set of regular faces.
                                  • fredo6F
                                    Are you referring to the properties of the diagonal of quads?
                                    • pbacotP
                                      I wonder if there can be a solution to the effect of "stair-stepping"? In this image you see a couple of conditions. One is the long steps in line with the contours, for no apparent reason--the contours are fairly even. One low slope area becomes a little plateau followed by a "step" to the next contour.
                                      There's a dirt road traversing the slope. While i don't expect much definition in this case, the steps or pockets along the road are misleading.
                                      Is some interpolation required? The contours are at 2' intervals. Or is the resolution of the grid too high? I chose a grid that turns out to be about 2.5' (more fine that I generally use).
                                      • fredo6F
                                        I think it's always better to model the terrain without artefacts like roads or building foundations, when it is possible. Then you can carve the roads and building on a clean terrain.
                                        Do you have the isocontours lines. You should probably edit them and suppress the points that are corresponding to the road. TopoShaper is not too sensitive when contour are missing, and often gives a better smoothing when there are not too many contours or they are not too close.
                                        • pbacotP
                                          OK. thanks. I could probably take out the road. So closer intervals is not the answer.
                                            menes
                                            Hello,
                                            I need help!
                                            I'm puzzled and I can't get on top of this issue
                                            this great plugin from the time I've installed the new 2020 SU it's not working as it was effectively before...
                                            I attach some files maybe someone understands what's going on
                                            thanks, everybody will be going to help
                                            Alberto
                                            initial status of isolines
                                            preview
                                            terrain created...not correct!
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 19 / 23
