    Clothworks license
    extensions
    50 Posts 25 Posters 46.7k Views 25 Watching
    • W Offline
      woodsaj
      I purchased the clothworks license a week ago. I emailed and messaged support. Zip-nothing-not a word. FURIOUS. Where is my license? 😠
        Anton_S
        @woodsaj said:
        :x 😠 😠 😠 😠 😠
        Hey, I responded to your message. Thanks!
          ARUSHAMEHTA
          I have installed cloth plugin but not able to license it
            What version of SketchUp are you actually using? Your profile says 2019 Free/Make which does not exist.
            Have you installed the Sketchucation Extension Store tool?
            What did you do to try to license Clothworks?
              kstrungduc
              How can i buy the license, only buy license, not subscribe SketchUcation.
                togo
                Hi Anton,
                does ClothWorks work with SU 2021? (MacOS10.14)
                I just upgraded to SU2021 and receive error messages only regarding ClothWorks (files in plugins are missing and others require load or register etc.).
                1. I dragged&dropped all ams_ClothWorks plugins from the 2020 folder to the 2021 folder - error messages on startup
                2. deleted all ams_ClothWorks files and fresh installed from sketchUcation Extension Store - restart - error message as above
                  The procedure described in your license manual does not work, because the extension is not loaded on startup.
                  I purchased a license (see post No. 3)
                  Can you please help me? Thanks*togo
                  See Anton's post here:
                  https://sketchucation.com/forums/viewtopic.php?f=323&t=69485&start=480#p666103
                    Mariandrea
                    Hey I made a payment for my license and I haven't received any email with my license file, please help! Where can I find it?
                      Anton_S
                      Hello, please check your email. Thanks!
                      • AngiesolimanA Offline
                        Angiesoliman
                        Hello,
                        about a month ago I bought the full version of ClothWorks and recieved a zipped lecense file.
                        When I tried to unzip it, I got this message:
                        [pre:3a0a7ybw]Error - Cannot open file "SCF_Purchased_License_ClothWorks_NORMAL_20201219" as archive.[/pre:3a0a7ybw]
                        I emailed clothworks@sketchucation.com and never heard back, thought it was because of the holidays.
                        I tried emailing again today and recieved this email in return:
                        [pre:3a0a7ybw]mx.google.com rejected your message to the following email addresses:
                        clothworks@sketchucation.com (clothworks@sketchucation.com)
                        Your message wasn't delivered because the recipient's email provider rejected it.[/pre:3a0a7ybw]
                        what am I supposed to do now? πŸ˜•
                          Anton_S
                          @angiesoliman said:
                          Hello,
                          [pre:1wmg9e2g]Error - Cannot open file "SCF_Purchased_License_ClothWorks_NORMAL_20201219" as archive.[/pre:1wmg9e2g]
                          [pre:1wmg9e2g]mx.google.com rejected your message to the following email addresses:
                          Your message wasn't delivered because the recipient's email provider rejected it.[/pre:1wmg9e2g]
                          Hello,
                          You should not unzip the file. It's not a zip file. Just download the file, and provided you installed SketchUcationTools and ClothWorks, activate your license file.
                          You can refer to the instructions here:
                          • https://antonsynytsia.github.io/manuals/ClothWorks/installation_manual_v174.pdf
                          • https://antonsynytsia.github.io/manuals/ClothWorks/license_manual_v174.pdf
                          Also, I am not sure why your email is rejected.
                          Let us know if that works.
                          Thanks,
                          Anton
                            sonoratheatrewrx
                            Screen Shot 2021-03-18 at 3.08.00 PM.pngHello, Anton -
                            An excellent plug-in, I think. I've purchased Clothworks license and received the license file, but I receive this error message when I try to activate.
                            I've sent a request to change the number of seats (whatever that means) and haven't received a reply. Can you help?
                            Thanks,
                            Joe
                            sonoratheatrewrx
                              Anton_S
                              @sonoratheatrewrx said:
                              [attachment=0:2vsg0ae6]<!-- ia0 -->Screen Shot 2021-03-18 at 3.08.00 PM.png<!-- ia0 -->[/attachment:2vsg0ae6]Hello, Anton -
                              Thanks,
                              Joe
                              sonoratheatrewrx
                              Hi Joe,
                              The error means there is an issue with your licensing cache. Please delete the licensing cache and then try activating again. To delete the licensing cache, you can follow the steps in ClothWorks licensing manual, Known Issue section, #3: https://antonsynytsia.github.io/manuals/ClothWorks/license_manual_v174.pdf
                              Upon deleting the cache, try activation.
                              Let us know if this helps.
                              Thanks,
                              Anton
                              • H Offline
                                hydboxhydbox
                                Hello,
                                I just installed SketchUcation(newest version) and Clothworks. I purchased the license and got the License e-mail. But I am not able to validate it. I am using a Mac. I saw someone above had the same problem (same system) I never used the SKetchUcation extension before. It's the first time I purchase a license on it. So I don't know if the mac system is the problem.
                                I e-mailed back, don't know if there will be any answer.
                                Please help. Thanks!
                                  Anton_S
                                  Not sure what's the issue here. Can you confirm your SketchUcation version by selecting (Menu)Window->Extension Manager? See attached image.
                                  • H Offline
                                    hydboxhydbox
                                    some infomation:
                                    system: OS X 10.11.6
                                    SketchUp: SketchUp 2017 pro
                                    Cloth works: ClothWorks_v1.7.4
                                    SketchUcationTools_v4.1.1
                                    • H Offline
                                      hydboxhydbox
                                      Hi Anton,
                                      It's sorted. I updated my system to MacOS 10.13. and tried again. The validating message went through.
                                      Thanks.
                                      Best,
                                      Yida
                                      • soloS Offline
                                        I have updated to a new computer and all but Clothworks plugins work. I put in my name and serial number but got this response.
                                        I am connected to the internet, and I uninstalled clothworks from old PC.
                                          Did you install a fresh copy of the Sketcucation extension?
                                            You need to validate with the .scflicense file
                                            https://i.imgur.com/I7bkLAN.png
                                            There's no serial number you input. Click the Open License Location and see what .scflicense files you have
                                            • 2 / 3
