    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 630.8k Views 155 Watching
      Model.entityID is a weird one it always returns "Model", so unsure why it's used... 😲
      You can trap it with something like:
      if defined?(Sketchup.active_model.entityID)
        mid = Sketchup.active_model.entityID
      else
        mid = "Model"
      BUT then mid = "Model" is always right - so why not use the simplest fix !
      • JQLJ Offline
        JQL
        @Tig and Fredo
        You have the notion you look like aliens with superpowers to the rest of us mortals down here...don't you?
        www.casca.pt
        Visit us on facebook!
        • fredo6F Offline
          @TIG:
          Now I know this is not a native method, I will be careful. In fact this method is convenient because you can use entityID on a parent whether Group, ComponentInstance or active model.
            j03150315
            This tool is amazing! However, I encountered some error with the follow push/pull.
            When I tried to use follow push/pull, the following error occurred:
            undefined method `angle_between' for nil:NilClass
            Ruby File Line Method
            JointPushPullAlgo.rb 1339 vertex_average_factor
            JointPushPullAlgo.rb 1089 follow_compute_direction
            JointPushPullAlgo.rb 1056 block in block_prepare_vertices_F
            JointPushPullAlgo.rb 1056 each
            JointPushPullAlgo.rb 1056 block_prepare_vertices_F
            JointPushPullAlgo.rb 890 block in block_prepare_vertices_all
            JointPushPullAlgo.rb 890 each
            JointPushPullAlgo.rb 890 block_prepare_vertices_all
            JointPushPullAlgo.rb 500 algo_prepare_calculation_exec
            JointPushPullAlgo.rb 477 algo_prepare_calculation
            JointPushPullTool.rb 692 dragging_start
            JointPushPullTool.rb 1190 onMouseMove
            22-Feb-15 14:56:56
            Does anyone know why?? I followed exactly what the video showed, push/pull the top of a cone shaped object.
            Would love some help! Thank you!!
            • fredo6F Offline
              It may depend on your model.
              So the best is to post it or PM it to me.
              • cottyC Offline
                cotty
                Hi Fredo, I've experienced this round push pull error for this simple geometry...
                rpperror.txt
                my SketchUp gallery
                • erkanE Offline
                  erkan
                  I'm getting the same error in a specific geometry, any plans of implementing the safer generation method?
                  @fredo6 said:
                  @stamatispsarras said:
                  I am also getting this error in a complex model.
                  Any ideas what I should avoid when modeling, so it wont happen again?
                  Unfortunately, these kind of errors may happen with complex models where the generated offset surface contains overlaps. This is due to the fast method of generation. I have the plan to have a default safe generation method to takeover when there are such errors. Should go in a next release.
                    littleche
                    HI fredo
                    this face have problem with joint pull push plugin but easily work with puss pull tool in sketchup !
                    It was very surprising for me! Since this face is very Simple !
                    I uploud this file . I thank you for the review explained above.
                    P&P.skp
                      It's poorly drawn at the end near the red axis. If you did a better job of drawing it, Joint Push/Pull wouldn't fail.
                        littleche
                        HI Dave
                        I had not checked the lines For this reason,The main tool push&pull was not any problem.
                        I did not know that fredo plugin is more sensitive.
                        thank you ...
                          I don't know that it's more sensitive but since you have that little triangular loop with no face in it, i'd guess that causes problems. Try this: Scale the entire geometry up by a factor of 1000. make a face on that triangle by tracing one edge of it with the Line tool. Then trying running Joint Push/Pull on the result.
                          • dereiD Offline
                            derei
                            Hy, I am a bit confused on how to PROPERLY use this plugin... Ok, I understood that I should keep the mouse button pressed while pulling the face, because click will only select/deselect (which is a bit annoying, honestly). But there is a funny behavior AFTER I do the push pull... sometimes (couldn't figure out in which conditions), when I press ENTER it actually CANCEL my pushpull.
                            Until now, every successful pushpull i did was out of luck... I have no idea how I confirmed the operation, because apparently I do the same thing like when it's canceled.
                            In my opinion it should do better use of ESC and ENTER keys (first to cancel, second to confirm). Also, selection of faces would be best to be key-assisted, as in regular SU behavior.
                            Is very confusing when plugins ask for different commands to do similar SU actions... is like two different programs. Select should be performed the same in native Su and under plugins (same key+mouse combinations), other operations should be similar.
                            Wish you best.
                            • fredo6F Offline
                              I know it is a change of habit, but JPP is not designed to replace the native SU Pushpull either.
                              SU PushPull only acts on a single face. So when you click, the next action is PushPull.
                              In multiface seelction, you cannot do the same, because when you click on the first face, then this face would move / pushpull with the mouse when you will try to select a second face.
                              The only possibility remain is to select with NO click:
                              • if the mouse if over a face and you click, this face is PushPulled
                              • if you press CTRL why hovering over faces (.ie. no click), then these faces are added to the selection. If you then click, the Push Pull applies to all faces selected.
                              This method is also different from Sketchup, which does not have a multi-element selection capability in implicit selection (i.e. just hovering the mouse).
                              Note that I use this method in FredoScale, but I am pretty sure few users noticed or use it.
                              I'll have anyway another look and reflection to see if I can improve the face selection process (the best, when applicable, is to select the faces and then just type the offset, if you don't need a placement by target).
                              • dereiD Offline
                                derei
                                I completely understand that this tool is not meant to replace a native SU tool. I was merely talking about the way of use of the similar commands (eg. selecting faces).
                                But this is not the biggest problem I got into. I could accommodate to it. The problem is that ENTER cancels the push-pull. I do it, i set custom value in VCB, then i press ENTER. And voila: no pushhpull. 😕 And I get confused: did I pressed ESC?
                                Unless there is any reason to assign a canceling to ENTER key.
                                By the way... "before" JPP wasn't behaving like this. It's like this change was introduced recently...couldn't tell which release.
                                Thank you very much, Fredo
                                • fredo6F Offline
                                  I will have a look.
                                  The latest version of JPP is dated 9 Jan 15, so it's not recent, unless there is a side effect from LibFredo6.
                                  Did the problem happens when you are extruding a few faces or a lot of faces (with many faces, you have a preview mode)?
                                    I just did some quick testing and I'm not seeing any weird behavior with the Enter key. When I type a JPP distance and hit Enter, it makes the adjustment just like the native Push/Pull tool does. Maybe there's something else causing a conflict?
                                    FWIW, I updated LibFredo and the other extensions that got recent updates and according to the Plugin Store and LibFredo, everything is up to date.
                                    • dereiD Offline
                                      derei
                                      I tried to reproduce it now, Couldn't. Will keep an eye on it, as it happened many times while working.
                                      • dereiD Offline
                                        derei
                                        UNDO issue ...
                                        sometimes when I cancel JPP it lets the geometry with missing faces. Then I undo to get it back to its previous state...the problem is that i have to hit A LOT of UNDOs.
                                        Maybe the undo function should be reviewed and pack multiple phases in a single undo command.
                                          Ciacnorris
                                          Hi, I tried to install it on my PC, and I think it doesn't work on Windows 8.1.
                                          Are you gonna make it work on Windows 8.1 too?
                                          Really wanna try your plugin! 😄
                                            peterromao
                                            Hail to a very reliable extension which I have used countless times so far to give thickness to my sheets! Good Job!
                                            Today is the first time that I found an error with it.
                                            For some reason I cannot give this form a thickness.
                                            The ruby error I get is the following:
                                            Date: 07-Aug-15 19:49:31
                                            An error occurred in Joint Push Pull
                                            Error in generation of the geometry
                                            reference to deleted Entity
                                            JointPushPullGeometry.rb: 1027 -- entityID
                                            JointPushPullGeometry.rb: 1027 -- block in geometry_coplanar_edges_overhang
                                            JointPushPullGeometry.rb: 1025 -- each
                                            JointPushPullGeometry.rb: 1025 -- geometry_coplanar_edges_overhang
                                            JointPushPullGeometry.rb: 354 -- block in geometry_robot_erase_coplanar_edges
                                            JointPushPullGeometry.rb: 352 -- each
                                            JointPushPullGeometry.rb: 352 -- geometry_robot_erase_coplanar_edges
                                            JointPushPullGeometry.rb: 214 -- robot_call_action
                                            JointPushPullGeometry.rb: 177 -- geometry_robot_exec
                                            JointPushPullGeometry.rb: 160 -- geometry_robot
                                            JointPushPullGeometry.rb: 75 -- block in geometry_execute
                                            Lib6Operation.rb: 325 -- call
                                            Lib6Operation.rb: 325 -- step_geometry
                                            Lib6Operation.rb: 367 -- start_execution
                                            JointPushPullGeometry.rb: 75 -- geometry_execute
                                            JointPushPullTool.rb: 891 -- go_preview_or_geom
                                            JointPushPullTool.rb: 697 -- dragging_stop
                                            JointPushPullTool.rb: 1319 -- onLButtonUp
                                            I have attached the object.
                                            Single sheet with openings.
                                            • 11
                                            • 12
                                            • 13
                                            • 30
                                            • 31
                                            • 11 / 31
