    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 951.0k Views 155 Watching
    • fredo6F
      On the multiple selection, the problem is the following:
      If you click/release on face and if it was to activate the 'free' drag push-pull, then whenever you move the mouse, the initial face would be push-pulled interactively. This would make it impossible to select a second face.
      Illustration with the Standard Sketchup Push Pull.
      In most cases you don't need to drag faces. Just select them, make sure the cursor is on one of the selected face and type the offset in the VCB (or just Return or Double-click is the offset value is already OK).
      It is only when you want to set the face with respect to a reference point in the model that you need to interactively drag the faces.
      • JQLJ
        JQL
        This is probably why I'm the one bringing up the subject. This the process I use 90% of the time with sketchup native tools and JPP. The fact is that the functionallity you offer is flawless. There is nothing to point on that regard, so I actually feel ashamed of myself by seeming that I'm somehow bragging about UI.
        The thing is that the way I always worked on Architecture is all about references to other geometry - alignements, porportions, visual axis, middle points, endpoints,... - as that adds geometric rule to space. I almos never think of space as an addition/subtraction of numbers. The thing that made me fall in love with Sketchup is no other than the inference system wich is an almost perfect system for the way I study space. I bet even if inference.
        I feel that if there was a way to toggle selection on/off that free movement could break temporarily and then continue freely.
        But don't mind about this questions of mine though, The functionality is there and I've been using your tools long enough already to know what to expect. An though they're feeling different from SU they do work! They do facilitate our life tremendously! And that is the purpose after all!
        Thanks again,
        João
        www.casca.pt
        Visit us on facebook!
          schnydix
          Thank you very much Fredo
          Happy and good new year to you
          and a little German german quick card
          Esense 3d
            schnydix
            Quick card German
              rv1974
              It appears RoundPP refuses to deal with obtuse angle geometry.
              round.skp
              Ruby Error - Round Push Pull - 14-Jan-15 10_10_15.txt
              • ely862meE
                ely862me
                Hi guys.
                Do you have any idea why JPP is not working ?(for a friend)
                The other tools from you (Fredo) , are working but this one doesn't .
                I have the latest Libfredo, I use Sketchup 2015 64 bit . I have also tested it with no other plugins in the Plugins folder. In vain.
                The plugin seems installed, all the incons are alright . When I select one of its tools and try to run it on a face it just highlights a polygon or a triangle and then nothing. Somehow it doesn's select the surface as it should !
                The Face selection is set to Surface, but it does not select the surface, it is only highlighting a polygon that is under the surface .
                I ran out of ideas.
                EDITED
                I have read back and found out about the DC being disabled. I have checked the behavior on my own Sketchup with them turned off and this seems to be it . Lets see if it works for my friend. I am not sure if it is written in the documentation about this, but could you post it at the conflicts ? Thank you !
                Elisei (sketchupper)
                Come and See EliseiDesign
                • fredo6F
                  What is "DC"? Is it Dynamic components?
                  I don't know why there would be a conflict.
                  Thanks for feedback
                    DC rubies add several additional methods into the base Sketchup and related Classes.
                    If you have used any of these methods in your code, then IF those DC rubies have not loaded you will get errors.
                    These include:
                    ` Geom::Transformation.rotx
                    Geom::Transformation.roty
                    Geom::Transformation.rotz
                    Geom::Transformation.xscale
                    Geom::Transformation.yscale
                    Geom::Transformation.zscale
                    UI::WebDialog.last_width
                    UI::WebDialog.last_width=
                    UI::WebDialog.last_height
                    UI::WebDialog.last_height=
                    Sketchup::ComponentInstance.copy
                    Sketchup::ComponentInstance.description
                    Sketchup::Drawingelement.local_transformation
                    Sketchup::Drawingelement.scaled_size
                    Sketchup::Drawingelement.unscaled_size
                    Sketchup::Drawingelement.set_last_size
                    Sketchup::Drawingelement.last_scaling_factors
                    Model.typename
                    Model.entityID
                    Model.delete_attribute
                    Model.layer`
                    There are other " DC..." classes too, but I'd expect you won't have used those !
                    • fredo6F
                      TIG,
                      Thanks for clarification.
                      I think I may use model.entityID. Actually I thought it was a native method (which would make sense).
                      I have to check my code to track these instances.
                        Model.entityID is a weird one it always returns "Model", so unsure why it's used... 😲
                        You can trap it with something like:
                        if defined?(Sketchup.active_model.entityID)
                          mid = Sketchup.active_model.entityID
                        else
                          mid = "Model"
                        BUT then mid = "Model" is always right - so why not use the simplest fix !
                        • JQLJ
                          JQL
                          @Tig and Fredo
                          You have the notion you look like aliens with superpowers to the rest of us mortals down here...don't you?
                          www.casca.pt
                          • fredo6F
                            @TIG:
                            Now I know this is not a native method, I will be careful. In fact this method is convenient because you can use entityID on a parent whether Group, ComponentInstance or active model.
                              j03150315
                              This tool is amazing! However, I encountered some error with the follow push/pull.
                              When I tried to use follow push/pull, the following error occurred:
                              undefined method `angle_between' for nil:NilClass
                              Ruby File Line Method
                              JointPushPullAlgo.rb 1339 vertex_average_factor
                              JointPushPullAlgo.rb 1089 follow_compute_direction
                              JointPushPullAlgo.rb 1056 block in block_prepare_vertices_F
                              JointPushPullAlgo.rb 1056 each
                              JointPushPullAlgo.rb 1056 block_prepare_vertices_F
                              JointPushPullAlgo.rb 890 block in block_prepare_vertices_all
                              JointPushPullAlgo.rb 890 each
                              JointPushPullAlgo.rb 890 block_prepare_vertices_all
                              JointPushPullAlgo.rb 500 algo_prepare_calculation_exec
                              JointPushPullAlgo.rb 477 algo_prepare_calculation
                              JointPushPullTool.rb 692 dragging_start
                              JointPushPullTool.rb 1190 onMouseMove
                              22-Feb-15 14:56:56
                              Does anyone know why?? I followed exactly what the video showed, push/pull the top of a cone shaped object.
                              Would love some help! Thank you!!
                              • fredo6F
                                It may depend on your model.
                                So the best is to post it or PM it to me.
                                • cottyC
                                  cotty
                                  Hi Fredo, I've experienced this round push pull error for this simple geometry...
                                  rpperror.txt
                                  my SketchUp gallery
                                  • erkanE
                                    erkan
                                    I'm getting the same error in a specific geometry, any plans of implementing the safer generation method?
                                    @fredo6 said:
                                    @stamatispsarras said:
                                    I am also getting this error in a complex model.
                                    Any ideas what I should avoid when modeling, so it wont happen again?
                                    Unfortunately, these kind of errors may happen with complex models where the generated offset surface contains overlaps. This is due to the fast method of generation. I have the plan to have a default safe generation method to takeover when there are such errors. Should go in a next release.
                                    • L
                                      littleche
                                      HI fredo
                                      this face have problem with joint pull push plugin but easily work with puss pull tool in sketchup !
                                      It was very surprising for me! Since this face is very Simple !
                                      I uploud this file . I thank you for the review explained above.
                                      P&P.skp
                                        It's poorly drawn at the end near the red axis. If you did a better job of drawing it, Joint Push/Pull wouldn't fail.
                                        • L
                                          littleche
                                          HI Dave
                                          I had not checked the lines For this reason,The main tool push&pull was not any problem.
                                          I did not know that fredo plugin is more sensitive.
                                          thank you ...
                                            I don't know that it's more sensitive but since you have that little triangular loop with no face in it, i'd guess that causes problems. Try this: Scale the entire geometry up by a factor of 1000. make a face on that triangle by tracing one edge of it with the Line tool. Then trying running Joint Push/Pull on the result.
                                            • 11
                                            • 12
                                            • 13
                                            • 30
                                            • 31
                                            • 11 / 31
