    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v11.1c - 08 Sep 20
      LibFredo6 11.1c includes various bug fixes.
      • jujuJ Offline
        juju
        It looks like I completely missed LibFredo6 v11.1b, thanks for the update.
        • Y Offline
          yhjeong
          Error Loading File Fredo6_!LibFredo6.rb
          Error: #<ArgumentError: invalid byte sequence in UTF-8>
          c:/users/์ •์˜ํ˜ธ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/์ •์˜ํ˜ธ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
          c:/users/์ •์˜ํ˜ธ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/์ •์˜ํ˜ธ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
          c:/users/์ •์˜ํ˜ธ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/์ •์˜ํ˜ธ/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
          C:/Users/์ •์˜ํ˜ธ/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/์ •์˜ํ˜ธ/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
          i experienced load errors.
          Plz tell me how to fix it
            @yhjeong
            Fredo will reply in detail, but it looks like your Korean user-name [์ •์˜ํ˜ธ] is causing the issue.
            Ruby expects any text-strings to be UTF-8 encoded.
            In earlier Ruby versions non-ASCII characters always caused problems.
            In the newer versions of SketchUp there is text-encoding possibilities.
            I know Fredo uses these latest methods.
            But somehow your Korean user-name is almost certainly causing the problem...
              Arkitekto1994
              Hi. Im having a trouble finding the file via extension manager. The files are in .rbz.skp, how can I convert it to purely .rbz file?
                Why are the files .RBZ.SKP ??
                A downloaded .RBZ file from the PluginStore should be saved with that file-type.
                How did it get changed ?
                I suspect your web-browser settings for downloaded file-types are FUBAR...
                Alternatively try renaming it without the .SKP ending and then the .RBZ file might be usable...
                However, you need to fix your download options...
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v11.2a - 27 Sep 20
                  LibFredo6 11.2a includes technical adjustments for some dialogs.
                    mexicano31
                    @fredo6 said:
                    Iain
                    One thing to check is whether the binary file has been successfully copied.
                    Could you do the following in SU2019
                    1. Open the RubyConsole
                    2. Type File.join(Sketchup.temp_dir, 'Fredo6_LibFredo6_TemporaryFiles')
                    3. The console should display the result, something like
                      /var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles
                    4. Open the Finder and use the menu Go > Go to Folder (or Shift-Command-G) and type the result of the previous step in the prompt dialog
                    5. If you open the directory in the finder, could you check if there is
                      • a subfolder: binaries
                      • and within it a subfolder SU19 with a file bin_LibFredo6.bundle
                    If there is no file, then we have the explanation. This might be a problem of security settings.
                    If there is a file, then this is another problem.
                    The same problem. But in the folder Binaries\SU19 i have a file bin_body_Lib6G6.so
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v11.2b - 09 Oct 20
                      LibFredo6 11.2b includes technical adjustments for video generation used by Animator
                      • fredo6F Offline
                        NEW RELEASE: LibFredo6 v11.2c - 11 Oct 20
                        LibFredo6 11.2c fixes a bug in the generation of videos for Animator (.MOV format can now be excluded)
                          loesshill
                          I've installed several extensions plus Libfredo6 months ago, and they all worked well,(thank you).
                          Today they do not work. Please advise.
                          • fredo6F Offline
                            Maybe you can indicate which one and give more info on the issues. This would help....
                              spablo
                              instale el plugin y no funciona
                                LibFredo no hace nada por sรญ solo, ayuda a sus otras extensiones ...
                                ยฟCรณmo no funcionรณ?
                                ยฟReiniciaste SketchUp para sincronizar cosas?
                                Ayuda a Fredo, ยกno es un psรญquico!
                                The LibFredo does nothing on its own - it helps his other Extensions...
                                How did it not work ?
                                Did you restart SketchUp to sync things ?
                                Give Fredo some help - he is not a psychic !
                                  cleatus269
                                  I am having issues with the animator. I have made animations in the past no problem. I try to make them now and i either get the hundreds of images OR nothing at ALL. I have uninstalled and reinstalled libfredo, FFFmpeg and it worked once, but now is not working.
                                  Please advise.... thanks
                                    manoamo
                                    I really want to use your tools but I can't install Liebefredo6 .. ๐Ÿคฃ
                                    Whenever I install Liebefredo6, this message pops up
                                    c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                                    c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                                    c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                                    C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                                    Please help...
                                    Thank you so much
                                      manoamo
                                      c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                                      c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                                      c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                                      C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                                      I'm having an issue installing and loading LibFred6... please help
                                      • fredo6F Offline
                                        NEW RELEASE: LibFredo6 v11.3a - 19 Nov 20
                                        LibFredo6 11.3a is dedicated to
                                        • Bug fixing
                                        • Support of VRay 5 in Animator
                                        • Some cosmetic adjustments
                                        • Compatibility SU2021
                                        • fredo6F Offline
                                          NEW RELEASE: LibFredo6 v11.3b - 21 Nov 20
                                          LibFredo6 11.3b contains small adjustments over v11.3a
                                            roxcore
                                            Hello LibFredo6!! Just installed the new versions of animator and the library plugin. I use Vray next to render and i notice that after te first image is rendered Animator doesn't start with the second image. It just keeps counting the seconds even after the render is finished. I also noticed that in the menu, the preset dimensions are gone. I only have the viewport option.
                                            Greetings, Simon
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 109
                                            • 110
                                            • 61 / 110
