    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.8m Views 589 Watching
    • jujuJ
      juju
      It looks like I completely missed LibFredo6 v11.1b, thanks for the update.
      • Y
        yhjeong
        Error Loading File Fredo6_!LibFredo6.rb
        Error: #<ArgumentError: invalid byte sequence in UTF-8>
        c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
        c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
        c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/정영호/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
        C:/Users/정영호/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/정영호/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
        i experienced load errors.
        Plz tell me how to fix it
          @yhjeong
          Fredo will reply in detail, but it looks like your Korean user-name [정영호] is causing the issue.
          Ruby expects any text-strings to be UTF-8 encoded.
          In earlier Ruby versions non-ASCII characters always caused problems.
          In the newer versions of SketchUp there is text-encoding possibilities.
          I know Fredo uses these latest methods.
          But somehow your Korean user-name is almost certainly causing the problem...
            Arkitekto1994
            Hi. Im having a trouble finding the file via extension manager. The files are in .rbz.skp, how can I convert it to purely .rbz file?
              Why are the files .RBZ.SKP ??
              A downloaded .RBZ file from the PluginStore should be saved with that file-type.
              How did it get changed ?
              I suspect your web-browser settings for downloaded file-types are FUBAR...
              Alternatively try renaming it without the .SKP ending and then the .RBZ file might be usable...
              However, you need to fix your download options...
              • fredo6F
                NEW RELEASE: LibFredo6 v11.2a - 27 Sep 20
                LibFredo6 11.2a includes technical adjustments for some dialogs.
                  mexicano31
                  @fredo6 said:
                  Iain
                  One thing to check is whether the binary file has been successfully copied.
                  Could you do the following in SU2019
                  1. Open the RubyConsole
                  2. Type File.join(Sketchup.temp_dir, 'Fredo6_LibFredo6_TemporaryFiles')
                  3. The console should display the result, something like
                    /var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles
                  4. Open the Finder and use the menu Go > Go to Folder (or Shift-Command-G) and type the result of the previous step in the prompt dialog
                  5. If you open the directory in the finder, could you check if there is
                    • a subfolder: binaries
                    • and within it a subfolder SU19 with a file bin_LibFredo6.bundle
                  If there is no file, then we have the explanation. This might be a problem of security settings.
                  If there is a file, then this is another problem.
                  The same problem. But in the folder Binaries\SU19 i have a file bin_body_Lib6G6.so
                  • fredo6F
                    NEW RELEASE: LibFredo6 v11.2b - 09 Oct 20
                    LibFredo6 11.2b includes technical adjustments for video generation used by Animator
                    • fredo6F
                      NEW RELEASE: LibFredo6 v11.2c - 11 Oct 20
                      LibFredo6 11.2c fixes a bug in the generation of videos for Animator (.MOV format can now be excluded)
                      • L
                        loesshill
                        I've installed several extensions plus Libfredo6 months ago, and they all worked well,(thank you).
                        Today they do not work. Please advise.
                        • fredo6F
                          Maybe you can indicate which one and give more info on the issues. This would help....
                            spablo
                            instale el plugin y no funciona
                              LibFredo no hace nada por sí solo, ayuda a sus otras extensiones ...
                              ¿Cómo no funcionó?
                              ¿Reiniciaste SketchUp para sincronizar cosas?
                              Ayuda a Fredo, ¡no es un psíquico!
                              The LibFredo does nothing on its own - it helps his other Extensions...
                              How did it not work ?
                              Did you restart SketchUp to sync things ?
                              Give Fredo some help - he is not a psychic !
                              • C
                                cleatus269
                                I am having issues with the animator. I have made animations in the past no problem. I try to make them now and i either get the hundreds of images OR nothing at ALL. I have uninstalled and reinstalled libfredo, FFFmpeg and it worked once, but now is not working.
                                Please advise.... thanks
                                  manoamo
                                  I really want to use your tools but I can't install Liebefredo6 .. 🤣
                                  Whenever I install Liebefredo6, this message pops up
                                  c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                                  c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                                  c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                                  C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                                  Please help...
                                  Thank you so much
                                    manoamo
                                    c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                                    c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                                    c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                                    C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                                    I'm having an issue installing and loading LibFred6... please help
                                    • fredo6F
                                      NEW RELEASE: LibFredo6 v11.3a - 19 Nov 20
                                      LibFredo6 11.3a is dedicated to
                                      • Bug fixing
                                      • Support of VRay 5 in Animator
                                      • Some cosmetic adjustments
                                      • Compatibility SU2021
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v11.3b - 21 Nov 20
                                        LibFredo6 11.3b contains small adjustments over v11.3a
                                          roxcore
                                          Hello LibFredo6!! Just installed the new versions of animator and the library plugin. I use Vray next to render and i notice that after te first image is rendered Animator doesn't start with the second image. It just keeps counting the seconds even after the render is finished. I also noticed that in the menu, the preset dimensions are gone. I only have the viewport option.
                                          Greetings, Simon
                                          • fredo6F
                                            Could you open the Ruby Console before launching the video generation and check the traces and potential errors.
                                            Can you also confirm the version of VRay you use. Thanks.
                                            • 81
                                            • 82
                                            • 83
                                            • 84
                                            • 85
                                            • 113
                                            • 114
                                            • 83 / 114
