    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
      Why are the files .RBZ.SKP ??
      A downloaded .RBZ file from the PluginStore should be saved with that file-type.
      How did it get changed ?
      I suspect your web-browser settings for downloaded file-types are FUBAR...
      Alternatively try renaming it without the .SKP ending and then the .RBZ file might be usable...
      However, you need to fix your download options...
      • fredo6F
        NEW RELEASE: LibFredo6 v11.2a - 27 Sep 20
        LibFredo6 11.2a includes technical adjustments for some dialogs.
          mexicano31
          @fredo6 said:
          Iain
          One thing to check is whether the binary file has been successfully copied.
          Could you do the following in SU2019
          1. Open the RubyConsole
          2. Type File.join(Sketchup.temp_dir, 'Fredo6_LibFredo6_TemporaryFiles')
          3. The console should display the result, something like
            /var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles
          4. Open the Finder and use the menu Go > Go to Folder (or Shift-Command-G) and type the result of the previous step in the prompt dialog
          5. If you open the directory in the finder, could you check if there is
            • a subfolder: binaries
            • and within it a subfolder SU19 with a file bin_LibFredo6.bundle
          If there is no file, then we have the explanation. This might be a problem of security settings.
          If there is a file, then this is another problem.
          The same problem. But in the folder Binaries\SU19 i have a file bin_body_Lib6G6.so
          • fredo6F
            NEW RELEASE: LibFredo6 v11.2b - 09 Oct 20
            LibFredo6 11.2b includes technical adjustments for video generation used by Animator
            • fredo6F
              NEW RELEASE: LibFredo6 v11.2c - 11 Oct 20
              LibFredo6 11.2c fixes a bug in the generation of videos for Animator (.MOV format can now be excluded)
              • L
                loesshill
                I've installed several extensions plus Libfredo6 months ago, and they all worked well,(thank you).
                Today they do not work. Please advise.
                • fredo6F
                  Maybe you can indicate which one and give more info on the issues. This would help....
                    spablo
                    instale el plugin y no funciona
                      LibFredo no hace nada por sí solo, ayuda a sus otras extensiones ...
                      ¿Cómo no funcionó?
                      ¿Reiniciaste SketchUp para sincronizar cosas?
                      Ayuda a Fredo, ¡no es un psíquico!
                      The LibFredo does nothing on its own - it helps his other Extensions...
                      How did it not work ?
                      Did you restart SketchUp to sync things ?
                      Give Fredo some help - he is not a psychic !
                      • C
                        cleatus269
                        I am having issues with the animator. I have made animations in the past no problem. I try to make them now and i either get the hundreds of images OR nothing at ALL. I have uninstalled and reinstalled libfredo, FFFmpeg and it worked once, but now is not working.
                        Please advise.... thanks
                          manoamo
                          I really want to use your tools but I can't install Liebefredo6 .. 🤣
                          Whenever I install Liebefredo6, this message pops up
                          Error Loading File Fredo6_!LibFredo6.rb
                          Error: #<ArgumentError: invalid byte sequence in UTF-8>
                          c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                          c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                          c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                          C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                          Please help...
                          Thank you so much
                            manoamo
                            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                            C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                            I'm having an issue installing and loading LibFred6... please help
                            • fredo6F
                              NEW RELEASE: LibFredo6 v11.3a - 19 Nov 20
                              LibFredo6 11.3a is dedicated to
                              • Bug fixing
                              • Support of VRay 5 in Animator
                              • Some cosmetic adjustments
                              • Compatibility SU2021
                              • fredo6F
                                NEW RELEASE: LibFredo6 v11.3b - 21 Nov 20
                                LibFredo6 11.3b contains small adjustments over v11.3a
                                  roxcore
                                  Hello LibFredo6!! Just installed the new versions of animator and the library plugin. I use Vray next to render and i notice that after te first image is rendered Animator doesn't start with the second image. It just keeps counting the seconds even after the render is finished. I also noticed that in the menu, the preset dimensions are gone. I only have the viewport option.
                                  Greetings, Simon
                                  • fredo6F
                                    Could you open the Ruby Console before launching the video generation and check the traces and potential errors.
                                    Can you also confirm the version of VRay you use. Thanks.
                                      roxcore
                                      Hello Fredo! Thank you for answering!! This is what te ruby console showed when opening Animator and starting the generation of the movie:
                                      RENDERING INIT
                                      Status natural = {}
                                      Status thea = :not_supported
                                      Status ambient_occlusion = :not_supported
                                      Status sketchFX = :not_supported
                                      Status twilight = :not_supported
                                      VRAY4 Init
                                      Status vray4 = nil
                                      Status vray = :not_supported
                                      :beg_time => 0
                                      :end_time => 90.5
                                      :frame_rate => 25
                                      :speed_factor => 1.0
                                      :reversed_play => nil
                                      :transparent => false
                                      :dimX => 1920
                                      :dimY => 1080
                                      :dim_mode => "custom"
                                      :filter => {
                                      } (:filter)
                                      :root_dir => "C:/Users/Gebruiker/Desktop/PROJECTEN/CARPENTIER/7. MONTAGEFILM HOUTEN WAND PERGOLA/Animator Videos"
                                      :movie_dir => "BASIS ANIMATOR 4 - 23-Nov-2020 15-23-52"
                                      :movie_name => "Film 1"
                                      :date_modified => 1606130042.267186
                                      :break_aspect_ratio => true
                                      :movie_formats => {
                                      :mp4 => true
                                      :mov => false
                                      :img_seq => true
                                      } (:movie_formats)
                                      :rendering_method => :vray4
                                      MOVIE PX = 1920 PY = 1080 transpa = false
                                      FORMATTED===========================
                                      VRAY Movie frame 1
                                      Animation time = 0.00s
                                      AFTER launching Rendering and Timer: status = true
                                      VRAY Status check - status = 6
                                      VRay rendering not finished yet elapsed = 1.99s
                                      Error: #<NoMethodError: undefined method state' for nil:NilClass> c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:445:in vray_status_check'
                                      c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:553:in `block in vray4_status_check'
                                      INTERRUPT true
                                      VRAY STOP timer =
                                      VRAY STOP timer =
                                      My Version of Vray is: V-Ray for SketchUp 4.20.02
                                      Greetings
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v11.4a - 23 Nov 20
                                        LibFredo6 11.4a fixes a problem introduced with v11.3a in the support of VRay 4.2 for Animator
                                          roxcore
                                          Everything works fine with the update!! Thank you so much!! Greetz
                                            manoamo
                                            I'm having a " invalid byte sequence in UTF-8 error "
                                            I watched your installation video 4 times, Searched about this error for days.
                                            I found out that this might be a encoding problem, but I have no idea how to solve this problem.
                                            please help .. Below is error log(?) when I restart SU after Libfredo6 installation.
                                            c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                                            c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                                            c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                                            C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                                            • 81
                                            • 82
                                            • 83
                                            • 84
                                            • 85
                                            • 115
                                            • 116
                                            • 83 / 116
