    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • fredo6F
      NEW RELEASE: LibFredo6 v11.2c - 11 Oct 20
      LibFredo6 11.2c fixes a bug in the generation of videos for Animator (.MOV format can now be excluded)
      • L
        loesshill
        I've installed several extensions plus Libfredo6 months ago, and they all worked well,(thank you).
        Today they do not work. Please advise.
        • fredo6F
          Maybe you can indicate which one and give more info on the issues. This would help....
            spablo
            instale el plugin y no funciona
              LibFredo no hace nada por sí solo, ayuda a sus otras extensiones ...
              ¿Cómo no funcionó?
              ¿Reiniciaste SketchUp para sincronizar cosas?
              Ayuda a Fredo, ¡no es un psíquico!
              The LibFredo does nothing on its own - it helps his other Extensions...
              How did it not work ?
              Did you restart SketchUp to sync things ?
              Give Fredo some help - he is not a psychic !
              • C
                cleatus269
                I am having issues with the animator. I have made animations in the past no problem. I try to make them now and i either get the hundreds of images OR nothing at ALL. I have uninstalled and reinstalled libfredo, FFFmpeg and it worked once, but now is not working.
                Please advise.... thanks
                  manoamo
                  I really want to use your tools but I can't install Liebefredo6 .. 🤣
                  Whenever I install Liebefredo6, this message pops up
                  Error Loading File Fredo6_!LibFredo6.rb
                  Error: #<ArgumentError: invalid byte sequence in UTF-8>
                  c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                  c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                  c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                  C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                  Please help...
                  Thank you so much
                    manoamo
                    c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                    c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                    c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                    C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                    I'm having an issue installing and loading LibFred6... please help
                    • fredo6F
                      NEW RELEASE: LibFredo6 v11.3a - 19 Nov 20
                      LibFredo6 11.3a is dedicated to
                      • Bug fixing
                      • Support of VRay 5 in Animator
                      • Some cosmetic adjustments
                      • Compatibility SU2021
                      • fredo6F
                        NEW RELEASE: LibFredo6 v11.3b - 21 Nov 20
                        LibFredo6 11.3b contains small adjustments over v11.3a
                          roxcore
                          Hello LibFredo6!! Just installed the new versions of animator and the library plugin. I use Vray next to render and i notice that after te first image is rendered Animator doesn't start with the second image. It just keeps counting the seconds even after the render is finished. I also noticed that in the menu, the preset dimensions are gone. I only have the viewport option.
                          Greetings, Simon
                          • fredo6F
                            Could you open the Ruby Console before launching the video generation and check the traces and potential errors.
                            Can you also confirm the version of VRay you use. Thanks.
                              roxcore
                              Hello Fredo! Thank you for answering!! This is what te ruby console showed when opening Animator and starting the generation of the movie:
                              RENDERING INIT
                              Status natural = {}
                              Status thea = :not_supported
                              Status ambient_occlusion = :not_supported
                              Status sketchFX = :not_supported
                              Status twilight = :not_supported
                              VRAY4 Init
                              Status vray4 = nil
                              Status vray = :not_supported
                              :beg_time => 0
                              :end_time => 90.5
                              :frame_rate => 25
                              :speed_factor => 1.0
                              :reversed_play => nil
                              :transparent => false
                              :dimX => 1920
                              :dimY => 1080
                              :dim_mode => "custom"
                              :filter => {
                              } (:filter)
                              :root_dir => "C:/Users/Gebruiker/Desktop/PROJECTEN/CARPENTIER/7. MONTAGEFILM HOUTEN WAND PERGOLA/Animator Videos"
                              :movie_dir => "BASIS ANIMATOR 4 - 23-Nov-2020 15-23-52"
                              :movie_name => "Film 1"
                              :date_modified => 1606130042.267186
                              :break_aspect_ratio => true
                              :movie_formats => {
                              :mp4 => true
                              :mov => false
                              :img_seq => true
                              } (:movie_formats)
                              :rendering_method => :vray4
                              MOVIE PX = 1920 PY = 1080 transpa = false
                              FORMATTED===========================
                              VRAY Movie frame 1
                              Animation time = 0.00s
                              AFTER launching Rendering and Timer: status = true
                              VRAY Status check - status = 6
                              VRay rendering not finished yet elapsed = 1.99s
                              Error: #<NoMethodError: undefined method state' for nil:NilClass> c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:445:in vray_status_check'
                              c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:553:in `block in vray4_status_check'
                              INTERRUPT true
                              VRAY STOP timer =
                              VRAY STOP timer =
                              My Version of Vray is: V-Ray for SketchUp 4.20.02
                              Greetings
                              • fredo6F
                                NEW RELEASE: LibFredo6 v11.4a - 23 Nov 20
                                LibFredo6 11.4a fixes a problem introduced with v11.3a in the support of VRay 4.2 for Animator
                                  roxcore
                                  Everything works fine with the update!! Thank you so much!! Greetz
                                    manoamo
                                    I'm having a " invalid byte sequence in UTF-8 error "
                                    I watched your installation video 4 times, Searched about this error for days.
                                    I found out that this might be a encoding problem, but I have no idea how to solve this problem.
                                    please help .. Below is error log(?) when I restart SU after Libfredo6 installation.
                                    c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                                    c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                                    c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                                    C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                                    • fredo6F
                                      @manoamo said:
                                      I'm having a " invalid byte sequence in UTF-8 error " .
                                      It's definitely related to your Windows user name not in ascii.
                                      Difficult to fix as there are so many situations.
                                      If you agree, we could try to troubleshoot together the problem (I would send you some small lines of Ruby to test).
                                      In the Ruby console, can you type (just copy / paste the statement and Enter)
                                      ENV["LOCALAPPDATA"].encoding.inspect
                                      Then tell me what you see as a response
                                        manoamo
                                        Thank you so much for your kind help! Much appreciated!!
                                        #Encoding:CP949
                                        This is what I got !
                                        • fredo6F
                                          #Encoding:CP949
                                          Could you now execute the following commands in the Ruby console, one after the other
                                          a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8")
                                          a.encoding.inspect
                                            manoamo
                                            #Encoding:CP949
                                            C:\Users\￈ᆱ﾿↓ᄎ￳\AppData\Local
                                            a.encoding.inspect
                                            #Encoding:UTF-8
                                            This is what I got
                                            • 81
                                            • 82
                                            • 83
                                            • 84
                                            • 85
                                            • 115
                                            • 116
                                            • 83 / 116
