    [Plugin] ImageTrimmer
    364 Posts 58 Posters 243.3k Views 58 Watching
    • N Offline
      nixchambers1
      So I temporarily switched off Anti-Virus Protector (Kaspersky) and it worked. Hooray! πŸŽ‰
      Weirdly, no matter what I did (allow, remember my preferences etc etc) it kept re-prompting me.
      I've had plenty of issues with it being over-zealous. I guess that's preferential to being under-enthusiastic at protecting my computer, just a bit of a faff. πŸ˜†
      Only issue I have now is that when I change the axis in the lovely new component it moves the texture around but that's not a big worry. Can sort that out myself I reckon.
      Thanks a mill for your help. 😎
      @tig said:
      What you have done so far seems fine.
      I repeated it with your PNG and got this result attached...
      My SKP was on my Desktop, but ones in my Documents folder work fine too...
      The main difference seems to be your over-zealous AntiVirus tool which attempts to block the JAR files running - not seen that before !
      Do you tick the box to remember the allowance ?
      You must allow it to create the files [obviously], when first run you might be causing a glitch by the interruption - but after that if you told it to ignore the JAR's actions it should be OK ??
      You could also try switching off the AntiVirus briefly while running the tool and see if that is indeed the culprit...
      What s your AntiVirus app ?
      [attachment=0:dc4tca6g]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:dc4tca6g]
        Why do you need to move the axes ?
        If the image has become a component, then select that and explode then remake the component this time setting its axes where you want - at that point the texture shouldn't 'jump' ??
        Use the same name to overwrite the original...
        • N Offline
          nixchambers1
          Will do, thanks.
          I move the axes upwards slightly for most shrubs so that they "sit" on the planting surface in a more credible way - essentially planting them slightly buried. πŸ€“
          • F Offline
            flyboy308
            Hi Tig,
            As with many I am having problems with the EdgeTrimmer. I am using Google Sketchup Pro 8. Windows 10. Recently installed the latest version of JAVA. All of the Jar files have the JAVA logo which I would guess that it should work. Checked all of the files and their locations and the ToolBox loaded correctly. Full permissions are granted for the plugin folder and subfolders. It does not perform as the directions would indicate. No edges, did not give messages to tilt up, etc.
            The following is the Ruby Console output when I ran the ImageTrimmer tool. Any idea what is happening?
            Error: #<NoMethodError: undefined method material' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/image_class.rb:316:in use_as_material'
            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/image_class.rb:599:in save_imagefile' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:191:in process_image'
            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:170:in initialize' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:834:in new'
            Thank you for your help.
            Ron
              Please attach the PNG image file that you want to trim...
              If the JAR files are working OK, then I suspect that perhaps the PNG itself has some transparency [alpha] assigned for all of its pixels - which means all pixels are ignored and the result is 'empty'...
              Also even PNGs with some solid pixels can fail if they are in 'filaments' of only 1 pixel wide - again these get skipped in the trimming...
              Only the 'background' you want to remove can have any transparent pixels, the ones to be kept must be 100% solid.
              But seeing the actual PNG will help confirm the problem... otherwise we have to guess...
              • F Offline
                flyboy308
                Attached is the file that has the transparency. Ron
                  You need to fix the PNG...
                  Then it works OK.
                  The PNG has an alpha defined for all pixels - although the main background is transparent the remainder are also slightly transparent.
                  Here's how I fixed it...
                  Open the PNG in Gimp [or a similar app].
                  Flatten the image [no alpha at all].
                  Add an alpha channel layer.
                  Select the black background using the magic wand.
                  Note that that tool's sensitivity might need downgrading as her suit is also in shades of black.
                  Delete those to show a transparent background.
                  Select a few remaining black islands - e.g. between her calves, in her hair etc...
                  Delete those too.
                  You also need to crop the PNG's content - otherwise thousands of background pixels will be inspected without any real effect - other than extending the processing time unnecessarily.
                  I've attached the reworked PNG... and a screenshot of it inside a SKP model...
                  • F Offline
                    flyboy308
                    Then it works OK.
                    Delete those too.
                    Thank you so much!!
                    • F Offline
                      flyboy308
                      @flyboy308 said:
                      Then it works OK.
                      Delete those too.
                      Thank you so much!!
                      Tig. Even using your FIXED version of the image, I still could not get it to work. After further investigation, I found that the program would not run with my Google Sketchup Pro version 8, 32-bit, on my Windows 10 64-bit operating system. Go figure. But it does work perfectly on my original image using both Sketchup 2015 and Sketchup 2017 Make. I could not find a 64-bit version of Sketchup 8 to see if that would work. This might help someone else or maybe someone who has success with the older version might respond.
                      Once again thank you for looking at this issue for me. Ron
                        Might be a link here ?
                        https://forums.sketchup.com/t/sketchup-pro-8-installer-download/43749
                        or here
                        http://software.oldversion.com/windows/google-sketchup-8-0-16846
                        or here
                        https://www.techspot.com/downloads/2525-google-sketchup.html
                        or here
                        https://designerhacks.com/skp-download-all/
                          There is no such thing.
                            Bluejay23
                            Hello All. I'm having trouble with ImageTrimmer. When I click on a png file, the plugin opens Adobe Illustrator. Adobe doesn't know what to do with the jar file. I believe I selected Adobe when I first installed the SKM Tools plugin when it asked for an external editor. I can't figure out how to change that. Thanks for any help you can give.
                              @Bluejay23
                              Please read the recent posts in this thread about this issue...
                              Sometimes your computer's apps can 'hijack' the .JAR file-type and then they try to open it.
                              The .JAR file-type should only be assigned to be opened in Java.
                              When the Ruby code tries to 'open' the JAR file and another app intervenes it will fail.
                              So make sure that your computer's app are not trying to do this...
                              Typically the apps that do this are 'compression' apps, but others - like your 'Adobe' - can also balls-up the file-type assignments !
                              Having 'Adobe' set as your image-editor in SketchUp's preferences should not be an issue.
                                Timagin
                                Hello, first of all, thank you so much for this wonderfull extension πŸ˜‰
                                Like most of my friends before, i got an issue using it.
                                The set up is correct, i did everything. So it might be an issue with the png file ?
                                It comes from illustrator, i did it by myself, here it is.
                                I'm a bit lost, some help would be wonderfull πŸ˜‰
                                Thank you ❀
                                  What version of SketchUp are you using? Your profile indicates a version that does not exist.
                                    I assume you have JAR files set to open properly in Java and not some compression apps... ?
                                    I assume you want the PNG's black parts solid and the rest as the punched-holes ?
                                    I took too long - suggesting there's something wrong with the PNG's pixels...
                                    I remade the PNG with total opacity and then added back in an alpha-layer for the deleted holes...
                                    I still takes ages to process... But it worked.
                                    Here's an image taken of from my SKP.
                                    I've also attached the redone PNG for you to retry...
                                      dfinchermd
                                      Can anyone explain why when I initiate ImageTrimmer on a the raw .png in Sketchup it opens CS Photoshop on top and gives me an unrecognizable file error message? In the SU command line IT says its processing edges ( its not frozen) but then nothing else happens. Im sure the errors are related. Any help is appreciated.
                                      dfinchermd
                                        Dekorte
                                        Hello,
                                        I'm trying to use this great plugin for cutting out 2D png trees, so I can cast a more realistic shadow.
                                        I'm using mac catalina + latest version of JAVA is installed.
                                        For some reason the plugin (that is installed correctly) will not work for me.
                                        And for the life of me, I cannot figure out why that is.
                                        Error 1 : "1 javax.imageio.IIOException: Can't create an ImageInputStream!"
                                        Error 2 : "The Java-JAR file 'EdgeDetector.jar'can't be started"
                                        (Default language for my Sketchup is Dutch, so I translated)
                                        I attached the Ruby script to this post also
                                        If anybody has some ideas to make this plugin work i'm happy to hear.
                                        Boris
                                        Mac folder
                                        Error message 1
                                        Error message 2
                                        Ruby
                                          @Boris
                                          Without seeing your PNG files I'm guessing...
                                          You seem to have got Java set up to run the JAR files which is a good start, but I suspect that your PNG needs editing in Gimp or PhotoShop to ensure it's properly constructed...
                                          Usually having the wrong transparency causes issues.
                                          ImageTrimmer uses any transparent pixels to find edges, so that only non-transparent pixels are kept.
                                          Even if a pixel has some slight transparency it is ignored.
                                          I'm guessing that in your case all pixels have some degree of transparency !
                                          Hence an empty file to process...
                                          Here's an explanation of what's needed [mentioned in this thread several times already]...
                                          Edit your PNG with your graphics app.
                                          Flatten it to remove ALL transparency in all pixels.
                                          Add an alpha-channeled layer for the transparency.
                                          Use its magic-wand tool to pick all pixels you want to be transparent - e.g. the background.
                                          Delete them, now you should see what's gone...
                                          Next use the editor to crop the extent of the image's pixels tight to the 'solid' pixels - this will speed up processing because all pixels have to be considered and having hundreds of unnecessary transparent ones will simply extend the processing time fruitlessly.
                                          If this fix doesn't work please attach one PNG tree image and I'll check it over...
                                            Dekorte
                                            Thank you for your input TIG.
                                            However, that didn't fix my problem 😞
                                            I attached an oak tree with this message.
                                            Any luck with you ?
                                            • 11
                                            • 18
                                            • 19
                                            • 9 / 19
