    Belly Tank Racer
    40 Posts 8 Posters 15.4k Views 8 Watching
    • tuna1957T Offline
      tuna1957
      Mike, Thanks. Not quite flats ready yet . We would have to push. No motor πŸ˜† .
      Bryan , Thanks and slow but sure it's moving along....
      • N Offline
        nlipovac
        Maybe electric?
        https://youtu.be/v68j01KiLG8
          I'll give the link a nul point score, repeated ads to the point of nausea. The concepts is good tho' as is some of the tech used in the switch to electric power. Very little weight in that hotrod.
          • tuna1957T Offline
            tuna1957
            A little more progress. Have the body pretty well squared away..... I think .... Frame starting to come together. Figured I'd work from front to back. Front suspension worked out.for the most part. Going to leave cutting clearance holes in the body until all the drivetrain is in place. 😎
            • tuna1957T Offline
              tuna1957
              Slow but steady , piece by piece I might get there.... Changed how the front canopy works. Hinging the whole thing at the front. Inspired to change based on vintage pics I've dug up. A lot of the front end stuff in place. Sort of scratching my head over just how much detail to do. Darn I'm ready to drive this thing... Susan better get the heck out of the way , I'll darn sure run her over 😎
              • Bryan KB Offline
                Oh my. Looking damn good!
                • tuna1957T Offline
                  tuna1957
                  Thanks Bryan. πŸ‘
                    Brilliant mate cool as. πŸ‘
                    • N Offline
                      nlipovac
                      Awsome looking speedster. πŸ‘
                      • tuna1957T Offline
                        tuna1957
                        Mike , nlipavoc , thanks for the support. πŸ‘ A few more bits done. Worked out the hand brake. Good start on the instrument panel and gauges. Went back and tweaked on a few other existing parts. 😎
                        • Bryan KB Offline
                          That detail is fantastic!
                          • aviz770A Offline
                            aviz770
                            This is some phenomenal modeling Tuna! I'm loving all the little details. I have a car lighting rig I'm working on if you feel like sharing the model πŸ˜‰ Id love to test it out on this. Again, great work!!!
                            • tuna1957T Offline
                              tuna1957
                              Bryan , Avi , thanks for the complements. πŸ‘
                                shawb
                                Tremendous modelling! Really like the tube work.
                                • tuna1957T Offline
                                  tuna1957
                                  Thanks shawb ,
                                  Here's a few more pics... things are coming together piece by piece. Before you all pat me on the back about the engine... be warned it's a model from TurboSquid. Hours of online searching turned up nothing in the way of good dimension drawings for a motor and transmission..... so went looking for a engine model. It's a pretty fair model, got a little messed up on import I think ( it was an .obj file. ). Don't get to close or you might see some problems here and there but worked well for final fitting out of the frame. Plenty more bits and bobs to do....
                                  • Bryan KB Offline
                                    Wow! πŸ‘
                                    • aviz770A Offline
                                      aviz770
                                      Simply magnificent πŸ‘
                                      • tuna1957T Offline
                                        tuna1957
                                        Thanks Bryan , Avi , Heres a tease of more to come ( I hope ) . Did a quickie test render just to check some of my material set ups. Darn how many more parts left to do... I think this is getting a little out of hand. 😎
                                        • ntxdaveN Offline
                                          ntxdave
                                          But looking really good. πŸ‘
                                          Press F1...thank me later
                                          • aviz770A Offline
                                            aviz770
                                            Looking sweeeeeet! Can't wait to see the tires get beefed up πŸ˜‰
                                            • 2 / 2
