    Belly Tank Racer
    40 Posts 8 Posters 17.1k Views 8 Watching
      Marvelous, ready for the salt flats mate.
      • Bryan KB Offline
        Coming along really good!
        • tuna1957T Online
          tuna1957
          Mike, Thanks. Not quite flats ready yet . We would have to push. No motor πŸ˜† .
          Bryan , Thanks and slow but sure it's moving along....
          • N Offline
            nlipovac
            Maybe electric?
            https://youtu.be/v68j01KiLG8
              I'll give the link a nul point score, repeated ads to the point of nausea. The concepts is good tho' as is some of the tech used in the switch to electric power. Very little weight in that hotrod.
              • tuna1957T Online
                tuna1957
                A little more progress. Have the body pretty well squared away..... I think .... Frame starting to come together. Figured I'd work from front to back. Front suspension worked out.for the most part. Going to leave cutting clearance holes in the body until all the drivetrain is in place. 😎
                • tuna1957T Online
                  tuna1957
                  Slow but steady , piece by piece I might get there.... Changed how the front canopy works. Hinging the whole thing at the front. Inspired to change based on vintage pics I've dug up. A lot of the front end stuff in place. Sort of scratching my head over just how much detail to do. Darn I'm ready to drive this thing... Susan better get the heck out of the way , I'll darn sure run her over 😎
                  • Bryan KB Offline
                    Oh my. Looking damn good!
                    • tuna1957T Online
                      tuna1957
                      Thanks Bryan. πŸ‘
                        Brilliant mate cool as. πŸ‘
                        • N Offline
                          nlipovac
                          Awsome looking speedster. πŸ‘
                          • tuna1957T Online
                            tuna1957
                            Mike , nlipavoc , thanks for the support. πŸ‘ A few more bits done. Worked out the hand brake. Good start on the instrument panel and gauges. Went back and tweaked on a few other existing parts. 😎
                            • Bryan KB Offline
                              That detail is fantastic!
                              • aviz770A Offline
                                aviz770
                                This is some phenomenal modeling Tuna! I'm loving all the little details. I have a car lighting rig I'm working on if you feel like sharing the model πŸ˜‰ Id love to test it out on this. Again, great work!!!
                                • tuna1957T Online
                                  tuna1957
                                  Bryan , Avi , thanks for the complements. πŸ‘
                                    shawb
                                    Tremendous modelling! Really like the tube work.
                                    • tuna1957T Online
                                      tuna1957
                                      Thanks shawb ,
                                      Here's a few more pics... things are coming together piece by piece. Before you all pat me on the back about the engine... be warned it's a model from TurboSquid. Hours of online searching turned up nothing in the way of good dimension drawings for a motor and transmission..... so went looking for a engine model. It's a pretty fair model, got a little messed up on import I think ( it was an .obj file. ). Don't get to close or you might see some problems here and there but worked well for final fitting out of the frame. Plenty more bits and bobs to do....
                                      • Bryan KB Offline
                                        Wow! πŸ‘
                                        • aviz770A Offline
                                          aviz770
                                          Simply magnificent πŸ‘
                                          • tuna1957T Online
                                            tuna1957
                                            Thanks Bryan , Avi , Heres a tease of more to come ( I hope ) . Did a quickie test render just to check some of my material set ups. Darn how many more parts left to do... I think this is getting a little out of hand. 😎
                                            • 2 / 2
