    Belly Tank Racer
    40 Posts 8 Posters 17.7k Views 8 Watching
      Great progress mate. I am doing the thickness of the panels right now and it is a pain. Best method I have found, with the hump behind your driver for example, would be to make a copy and a separate group. modify the group and delete the faces. Weld all the lines so you have the arcs and then allow for the thickness you want, move the arcs to these locations and remake the surface.
        Better like this.
        Picture shows inner and outer skins as mirrored which would not be the case but is easier to show.
        The model is there I hope, just a quick example, with more complex shapes Sketchup does the 'cannot make a face so bogoff' thing.
        Double Skinned Panels.skp
        • BoxB
          You know you can generally make thickness by scaling a copy and joining the dots. Doesn't work for every shape and sometimes you need to trim back flush, but it's not difficult.
          https://i.imgur.com/9EXUfqX.gif
          There is also good old Fredo's jpp as well for thickness.
          • tuna1957T
            tuna1957
            Mike , Box , thanks for the tips. I do use all of the mentioned methods... for me anyway it can be somewhat of a struggle when working on parts that have pretty severe compound curves. Most usual when two very differently shaped panels have been intersected into one shape. Just takes patience on my part and sometimes a certain amount of fiddling about and trying different approaches until I get the result I want.
            • Bryan KB
              Looking great!
              • tuna1957T
                tuna1957
                Thanks Bryan, hope to have some more progress pics later today.... πŸ‘
                Edit.... A few more shots. Reworked some panels , got side scoops in the rear body Fairing. Canopy pretty well shaped up. Need to put on my driveway engineer hat and figure out some hinges for the canopy.... 😎
                  Marvelous, ready for the salt flats mate.
                  • Bryan KB
                    Coming along really good!
                    • tuna1957T
                      tuna1957
                      Mike, Thanks. Not quite flats ready yet . We would have to push. No motor πŸ˜† .
                      Bryan , Thanks and slow but sure it's moving along....
                      • N
                        nlipovac
                        Maybe electric?
                        https://youtu.be/v68j01KiLG8
                          I'll give the link a nul point score, repeated ads to the point of nausea. The concepts is good tho' as is some of the tech used in the switch to electric power. Very little weight in that hotrod.
                          • tuna1957T
                            tuna1957
                            A little more progress. Have the body pretty well squared away..... I think .... Frame starting to come together. Figured I'd work from front to back. Front suspension worked out.for the most part. Going to leave cutting clearance holes in the body until all the drivetrain is in place. 😎
                            • tuna1957T
                              tuna1957
                              Slow but steady , piece by piece I might get there.... Changed how the front canopy works. Hinging the whole thing at the front. Inspired to change based on vintage pics I've dug up. A lot of the front end stuff in place. Sort of scratching my head over just how much detail to do. Darn I'm ready to drive this thing... Susan better get the heck out of the way , I'll darn sure run her over 😎
                              • Bryan KB
                                Oh my. Looking damn good!
                                • tuna1957T
                                  tuna1957
                                  Thanks Bryan. πŸ‘
                                    Brilliant mate cool as. πŸ‘
                                    • N
                                      nlipovac
                                      Awsome looking speedster. πŸ‘
                                      • tuna1957T
                                        tuna1957
                                        Mike , nlipavoc , thanks for the support. πŸ‘ A few more bits done. Worked out the hand brake. Good start on the instrument panel and gauges. Went back and tweaked on a few other existing parts. 😎
                                        • Bryan KB
                                          That detail is fantastic!
                                          • aviz770A
                                            aviz770
                                            This is some phenomenal modeling Tuna! I'm loving all the little details. I have a car lighting rig I'm working on if you feel like sharing the model πŸ˜‰ Id love to test it out on this. Again, great work!!!
