    Belly Tank Racer
    40 Posts 8 Posters 15.9k Views 8 Watching
    • tuna1957T Offline
      tuna1957
      Mike , Box , thanks for the tips. I do use all of the mentioned methods... for me anyway it can be somewhat of a struggle when working on parts that have pretty severe compound curves. Most usual when two very differently shaped panels have been intersected into one shape. Just takes patience on my part and sometimes a certain amount of fiddling about and trying different approaches until I get the result I want.
      • Bryan KB Offline
        Looking great!
        • tuna1957T Offline
          tuna1957
          Thanks Bryan, hope to have some more progress pics later today.... πŸ‘
          Edit.... A few more shots. Reworked some panels , got side scoops in the rear body Fairing. Canopy pretty well shaped up. Need to put on my driveway engineer hat and figure out some hinges for the canopy.... 😎
            Marvelous, ready for the salt flats mate.
            • Bryan KB Offline
              Coming along really good!
              • tuna1957T Offline
                tuna1957
                Mike, Thanks. Not quite flats ready yet . We would have to push. No motor πŸ˜† .
                Bryan , Thanks and slow but sure it's moving along....
                • N Offline
                  nlipovac
                  Maybe electric?
                  https://youtu.be/v68j01KiLG8
                    I'll give the link a nul point score, repeated ads to the point of nausea. The concepts is good tho' as is some of the tech used in the switch to electric power. Very little weight in that hotrod.
                    • tuna1957T Offline
                      tuna1957
                      A little more progress. Have the body pretty well squared away..... I think .... Frame starting to come together. Figured I'd work from front to back. Front suspension worked out.for the most part. Going to leave cutting clearance holes in the body until all the drivetrain is in place. 😎
                      • tuna1957T Offline
                        tuna1957
                        Slow but steady , piece by piece I might get there.... Changed how the front canopy works. Hinging the whole thing at the front. Inspired to change based on vintage pics I've dug up. A lot of the front end stuff in place. Sort of scratching my head over just how much detail to do. Darn I'm ready to drive this thing... Susan better get the heck out of the way , I'll darn sure run her over 😎
                        • Bryan KB Offline
                          Oh my. Looking damn good!
                          • tuna1957T Offline
                            tuna1957
                            Thanks Bryan. πŸ‘
                              Brilliant mate cool as. πŸ‘
                              • N Offline
                                nlipovac
                                Awsome looking speedster. πŸ‘
                                • tuna1957T Offline
                                  tuna1957
                                  Mike , nlipavoc , thanks for the support. πŸ‘ A few more bits done. Worked out the hand brake. Good start on the instrument panel and gauges. Went back and tweaked on a few other existing parts. 😎
                                  • Bryan KB Offline
                                    That detail is fantastic!
                                    • aviz770A Offline
                                      aviz770
                                      This is some phenomenal modeling Tuna! I'm loving all the little details. I have a car lighting rig I'm working on if you feel like sharing the model πŸ˜‰ Id love to test it out on this. Again, great work!!!
                                      • tuna1957T Offline
                                        tuna1957
                                        Bryan , Avi , thanks for the complements. πŸ‘
                                          shawb
                                          Tremendous modelling! Really like the tube work.
                                          • tuna1957T Offline
                                            tuna1957
                                            Thanks shawb ,
                                            Here's a few more pics... things are coming together piece by piece. Before you all pat me on the back about the engine... be warned it's a model from TurboSquid. Hours of online searching turned up nothing in the way of good dimension drawings for a motor and transmission..... so went looking for a engine model. It's a pretty fair model, got a little messed up on import I think ( it was an .obj file. ). Don't get to close or you might see some problems here and there but worked well for final fitting out of the frame. Plenty more bits and bobs to do....
