    [Plugin] Components to Grid
    22 Posts 7 Posters 25.6k Views 7 Watching
      You are right - I have now changed the original to ' ds'...
      • CadFatherC Offline
        CadFather
        Hi TIG - is it possible to have all the components placed along the red axis? i tried modifying the script but i always get the components on top of each other.. ๐Ÿ˜’
          This [simpler] version spaces the component-instances 2m apart along the red/x axis [no stacking into a 'square']
          require 'sketchup.rb'
          module CADfather
                unless file_loaded?(File.basename(__FILE__))
                  UI.menu('Tools').add_item('Components to Grid'){self.compogrid()}
                file_loaded(File.basename(__FILE__))
                def self.compogrid()
                  m=Sketchup.active_model;m.start_operation("ALL!"); ds=m.definitions; ns=[]; ds.to_a.find_all{|d|next if d.group?||d.image?; ns<<d.name}; ns.sort!; l=m.layers.add("ALL!");puts"\nLaying out ALL Components...\n\n"; es=m.active_entities; p=Geom;;Point3d.new(0,0,0); x=2.m; ns.length.times{|i|puts ns[i]; tr=Geom;;Transformation.new(p); n=es.add_instance(ds[ns[i]],tr);n.layer=l; p.x+=x};puts"\nDone.";m.commit_operation
                end #def
          end #module
          If the Ruby Console is open it reports what it's doing...
          Change the x=2.m for a different spacing in red/x if desired...
            CadFather
            Thanks TIG - much appreciated - i'll try integrating it into the grid plugin.. ๐Ÿ‘ ๐Ÿ˜„
            • gullfoG Offline
              gullfo
              TIG script examples - an interesting side effect - if you have a component made of other components it pulls it apart and distributes them... in this example i have a DC component of an acoustic window which has frames and seals as sub-components. in a way, this could be handy for creating a "how to assemble" guide because it pulls it apart in order of nesting...
              otoh this may not be a desired effect for the script in the end...
              Glenn
              http://www.runnel.com
                The OP asked for all components to be displayed on a grid.
                The code is very adaptable.
                It ignores Groups and Images although it could as easily display those as well, or instead.
                This version displays just components that have instances that are either in the model's entities or inside a non-component-entities context [i.e. inside a group that is not itself inside a component definition]
                    module CADfather
                            UI.menu('Tools').add_item('Components to Grid'){self.compogrid_used()}
                          def self.compogrid_used()
                            ds=m.definitions
                            ns=[]
                            def self.recurse_parent(c)
                              begin
                                return c.parent
                              rescue
                                return nil
                              next unless d.instances[0]
                              next if d.group?
                              next if d.image?
                              skip=true
                              d.instances.each{|i|
                                if i.parent==m
                                  skip=false
                                  break
                                elsif i.parent.group?
                                  i.parent.instances.each{|g|
                                    c=g
                                    while c
                                      c=self.recurse_parent(c)
                                      if m==c
                                        skip=false
                                        c=nil
                                        break
                              next if skip
                              ns<<d.name
                            ns.sort!;
                            x=2.m
                            ns.length.times{|i|
                              puts ns[i]
                              n.layer=l
                              p.x+=x}
                            puts"\nDone."
                            m.commit_operation
                          end #def
                    end #module
                  Amazing Artist
                  TIG Thanks
                  [color=#FF40FF:20ov4k9m]T[/color:20ov4k9m][color=#FF40F9:20ov4k9m]h[/color:20ov4k9m][color=#FF40F2:20ov4k9m]a[/color:20ov4k9m][color=#FF40EC:20ov4k9m]t[/color:20ov4k9m][color=#FF40E5:20ov4k9m]'[/color:20ov4k9m][color=#FF40DF:20ov4k9m]s[/color:20ov4k9m] [color=#FF40D2:20ov4k9m]m[/color:20ov4k9m][color=#FF40CC:20ov4k9m]y[/color:20ov4k9m] [color=#FF40BF:20ov4k9m]s[/color:20ov4k9m][color=#F940B9:20ov4k9m]t[/color:20ov4k9m][color=#F240B2:20ov4k9m]o[/color:20ov4k9m][color=#EC40AC:20ov4k9m]r[/color:20ov4k9m][color=#E540A6:20ov4k9m]y[/color:20ov4k9m][color=#DF40A0:20ov4k9m],[/color:20ov4k9m] [color=#D24093:20ov4k9m]a[/color:20ov4k9m][color=#CC408D:20ov4k9m]n[/color:20ov4k9m][color=#C54086:20ov4k9m]d[/color:20ov4k9m] [color=#C53A7A:20ov4k9m]I[/color:20ov4k9m][color=#CC3373:20ov4k9m]'[/color:20ov4k9m][color=#D22D6D:20ov4k9m]m[/color:20ov4k9m] [color=#DF2060:20ov4k9m]s[/color:20ov4k9m][color=#E51A5A:20ov4k9m]t[/color:20ov4k9m][color=#EC1353:20ov4k9m]i[/color:20ov4k9m][color=#F20D4D:20ov4k9m]c[/color:20ov4k9m][color=#F90646:20ov4k9m]k[/color:20ov4k9m][color=#FF0040:20ov4k9m]i[/color:20ov4k9m][color=#F9004D:20ov4k9m]n[/color:20ov4k9m][color=#F20059:20ov4k9m]g[/color:20ov4k9m] [color=#E50073:20ov4k9m]t[/color:20ov4k9m][color=#DF0080:20ov4k9m]o[/color:20ov4k9m] [color=#D20099:20ov4k9m]i[/color:20ov4k9m][color=#CC00A6:20ov4k9m]t[/color:20ov4k9m][color=#C500B2:20ov4k9m]![/color:20ov4k9m]
                    For SU 2017 Make
                    Incompatible with LightUP! ๐Ÿ˜ฎ
                    Curiously icons of LightUp apear!
                    And LightUp Disconnected
                    don't take a selection but all components on the scene! ๐Ÿ˜ฎ
                    Here must be display only "XTE" Selected : that is not the case! ๐Ÿ˜‰
                    All is recalled! (even the top view text who is not visible at the Plugin call! )
                    • jujuJ Offline
                      juju
                      @pilou said:
                      For SU 2017 Make
                      [attachment=1:2yvqwupx]<!-- ia1 -->bizarrerie.jpg<!-- ia1 -->[/attachment:2yvqwupx]
                      [attachment=0:2yvqwupx]<!-- ia0 -->biz4.jpg<!-- ia0 -->[/attachment:2yvqwupx]
                      Pilou, are you OK? I don't see what this has to do with the thread above? Perhaps start your own thread or look for the thread this is supposed to be in?
                        It's not the thread about Plugin "Components to Grid"?
                        What better place to report that it is not compatible (for me in any case) with Light UP ?
                        And it has curious behavior with the selection Components ? (for me in any case)
                        Out of that i just reinstall SketchUp and must verify if above is always true!
                        It will be my first Plugin to reload from a little thousand! ๐Ÿ˜„
                          Alas not better ! ๐Ÿ˜ข
                          My SketchUp is absolutly new! Only "Component on Grid" installed! ๐Ÿค“
                          So no conflict possible! (like Light Up above) ๐Ÿ˜‰
                          If i add new volumes : the same! that is making snowball ! All is redrawn! ๐Ÿ˜ฎ
                          • 2 / 2
