    [Plugin] Components to Grid
    22 Posts 7 Posters 25.6k Views 7 Watching
    • CadFatherC Offline
      CadFather
      thanks TIG - works great.
      i think there's a small typo here:
      %(#008000)[def self.compogrid()
      m=Sketchup.active_model;m.start_operation("ALL!");ds=m.definitions;ns=[];]s.to_a.find_all{|d|next if d.group?||
      should read ds
      what's interesting is how fast it is even with lots of components ๐Ÿ‘ ๐Ÿ‘
        You are right - I have now changed the original to ' ds'...
          CadFather
          Hi TIG - is it possible to have all the components placed along the red axis? i tried modifying the script but i always get the components on top of each other.. ๐Ÿ˜’
            This [simpler] version spaces the component-instances 2m apart along the red/x axis [no stacking into a 'square']
            require 'sketchup.rb'
            module CADfather
                  unless file_loaded?(File.basename(__FILE__))
                    UI.menu('Tools').add_item('Components to Grid'){self.compogrid()}
                  file_loaded(File.basename(__FILE__))
                    m=Sketchup.active_model;m.start_operation("ALL!"); ds=m.definitions; ns=[]; ds.to_a.find_all{|d|next if d.group?||d.image?; ns<<d.name}; ns.sort!; l=m.layers.add("ALL!");puts"\nLaying out ALL Components...\n\n"; es=m.active_entities; p=Geom;;Point3d.new(0,0,0); x=2.m; ns.length.times{|i|puts ns[i]; tr=Geom;;Transformation.new(p); n=es.add_instance(ds[ns[i]],tr);n.layer=l; p.x+=x};puts"\nDone.";m.commit_operation
                  end #def
            end #module
            If the Ruby Console is open it reports what it's doing...
            Change the x=2.m for a different spacing in red/x if desired...
              CadFather
              Thanks TIG - much appreciated - i'll try integrating it into the grid plugin.. ๐Ÿ‘ ๐Ÿ˜„
              • gullfoG Offline
                gullfo
                TIG script examples - an interesting side effect - if you have a component made of other components it pulls it apart and distributes them... in this example i have a DC component of an acoustic window which has frames and seals as sub-components. in a way, this could be handy for creating a "how to assemble" guide because it pulls it apart in order of nesting...
                otoh this may not be a desired effect for the script in the end...
                Glenn
                http://www.runnel.com
                  The OP asked for all components to be displayed on a grid.
                  The code is very adaptable.
                  It ignores Groups and Images although it could as easily display those as well, or instead.
                  This version displays just components that have instances that are either in the model's entities or inside a non-component-entities context [i.e. inside a group that is not itself inside a component definition]
                      module CADfather
                              UI.menu('Tools').add_item('Components to Grid'){self.compogrid_used()}
                            def self.compogrid_used()
                              ds=m.definitions
                              ns=[]
                              def self.recurse_parent(c)
                                begin
                                  return c.parent
                                rescue
                                  return nil
                                next unless d.instances[0]
                                next if d.group?
                                next if d.image?
                                skip=true
                                d.instances.each{|i|
                                  if i.parent==m
                                    skip=false
                                    break
                                  elsif i.parent.group?
                                    i.parent.instances.each{|g|
                                      c=g
                                      while c
                                        c=self.recurse_parent(c)
                                        if m==c
                                          skip=false
                                          c=nil
                                          break
                                next if skip
                                ns<<d.name
                              ns.sort!;
                              x=2.m
                              ns.length.times{|i|
                                puts ns[i]
                                n.layer=l
                                p.x+=x}
                              puts"\nDone."
                              m.commit_operation
                            end #def
                      end #module
                    Amazing Artist
                    TIG Thanks
                    [color=#FF40FF:20ov4k9m]T[/color:20ov4k9m][color=#FF40F9:20ov4k9m]h[/color:20ov4k9m][color=#FF40F2:20ov4k9m]a[/color:20ov4k9m][color=#FF40EC:20ov4k9m]t[/color:20ov4k9m][color=#FF40E5:20ov4k9m]'[/color:20ov4k9m][color=#FF40DF:20ov4k9m]s[/color:20ov4k9m] [color=#FF40D2:20ov4k9m]m[/color:20ov4k9m][color=#FF40CC:20ov4k9m]y[/color:20ov4k9m] [color=#FF40BF:20ov4k9m]s[/color:20ov4k9m][color=#F940B9:20ov4k9m]t[/color:20ov4k9m][color=#F240B2:20ov4k9m]o[/color:20ov4k9m][color=#EC40AC:20ov4k9m]r[/color:20ov4k9m][color=#E540A6:20ov4k9m]y[/color:20ov4k9m][color=#DF40A0:20ov4k9m],[/color:20ov4k9m] [color=#D24093:20ov4k9m]a[/color:20ov4k9m][color=#CC408D:20ov4k9m]n[/color:20ov4k9m][color=#C54086:20ov4k9m]d[/color:20ov4k9m] [color=#C53A7A:20ov4k9m]I[/color:20ov4k9m][color=#CC3373:20ov4k9m]'[/color:20ov4k9m][color=#D22D6D:20ov4k9m]m[/color:20ov4k9m] [color=#DF2060:20ov4k9m]s[/color:20ov4k9m][color=#E51A5A:20ov4k9m]t[/color:20ov4k9m][color=#EC1353:20ov4k9m]i[/color:20ov4k9m][color=#F20D4D:20ov4k9m]c[/color:20ov4k9m][color=#F90646:20ov4k9m]k[/color:20ov4k9m][color=#FF0040:20ov4k9m]i[/color:20ov4k9m][color=#F9004D:20ov4k9m]n[/color:20ov4k9m][color=#F20059:20ov4k9m]g[/color:20ov4k9m] [color=#E50073:20ov4k9m]t[/color:20ov4k9m][color=#DF0080:20ov4k9m]o[/color:20ov4k9m] [color=#D20099:20ov4k9m]i[/color:20ov4k9m][color=#CC00A6:20ov4k9m]t[/color:20ov4k9m][color=#C500B2:20ov4k9m]![/color:20ov4k9m]
                      For SU 2017 Make
                      Incompatible with LightUP! ๐Ÿ˜ฎ
                      Curiously icons of LightUp apear!
                      And LightUp Disconnected
                      don't take a selection but all components on the scene! ๐Ÿ˜ฎ
                      Here must be display only "XTE" Selected : that is not the case! ๐Ÿ˜‰
                      All is recalled! (even the top view text who is not visible at the Plugin call! )
                      • jujuJ Offline
                        juju
                        @pilou said:
                        For SU 2017 Make
                        [attachment=1:2yvqwupx]<!-- ia1 -->bizarrerie.jpg<!-- ia1 -->[/attachment:2yvqwupx]
                        [attachment=0:2yvqwupx]<!-- ia0 -->biz4.jpg<!-- ia0 -->[/attachment:2yvqwupx]
                        Pilou, are you OK? I don't see what this has to do with the thread above? Perhaps start your own thread or look for the thread this is supposed to be in?
                          It's not the thread about Plugin "Components to Grid"?
                          What better place to report that it is not compatible (for me in any case) with Light UP ?
                          And it has curious behavior with the selection Components ? (for me in any case)
                          Out of that i just reinstall SketchUp and must verify if above is always true!
                          It will be my first Plugin to reload from a little thousand! ๐Ÿ˜„
                            Alas not better ! ๐Ÿ˜ข
                            My SketchUp is absolutly new! Only "Component on Grid" installed! ๐Ÿค“
                            So no conflict possible! (like Light Up above) ๐Ÿ˜‰
                            If i add new volumes : the same! that is making snowball ! All is redrawn! ๐Ÿ˜ฎ
