    [Plugin] Components to Grid
    22 Posts 7 Posters 25.8k Views 7 Watching
    • CadFatherC
      CadFather
      while i'm at it i might ask another question (for which there surely there isn't an old easy answer..)
      any way to distribute ALL the components present in the component browser 'in model' - to an imaginary grid in model space?
        I already recently did something like this in another thread, where the OP wanted to import SKPs and then show the components laid out.
        What you could do with a model's components in code is to iterate the list of definition names 'ns' [as all set/got in my earlier example] and then place an instance of each on a special layer [it makes later deletions easier], thus:
        m=Sketchup.active_model;m.start_operation("ALL!");ds=m.definitions;ns=[];ds.to_a.find_all{|d|next if d.group?||d.image?;ns<<d.name};ns.sort!; l=m.layers.add("ALL!");puts"\nLaying out ALL Components...\n\n"; es=m.active_entities; p=Geom;;Point3d.new(0,0,0);x=1.m;y=1.m;r=(Math.sqrt(ns.length)+0.5).to_i;c=0; ns.length.times{|i|puts ns[i]; tr=Geom;;Transformation.new(p); n=es.add_instance(ds[ns[i]],tr);n.layer=l;c+=1;if c>=r;p.x=0;p.y+=y;c=0;else;p.x+=x;end};puts"\nDone.";m.commit_operation
        The x/y set for a 1m 'square' grid starting from [0,0,0] - with any odd ones on the final row - so adjust this as desired; these new instances are put onto a layer name 'ALL!'; this one-liner is one-step undoable...
        • CadFatherC
          CadFather
          wow...thank you TIG - just tried it and it's fab! ๐Ÿ˜„ ๐Ÿ‘
          tried to make it into a command but no success and yet i'm sure i wrapped it up properly (just in case others find it useful)
          compogrid.rb
            You miss called the module/method... try it this way
            require 'sketchup.rb'
            module CADfather
              unless file_loaded?(File.basename(__FILE__))
                UI.menu('Tools').add_item('Components to Grid'){self.compogrid()}
              file_loaded(File.basename(__FILE__))
              def self.compogrid()
                m=Sketchup.active_model;m.start_operation("ALL!");ds=m.definitions;ns=[]; ds.to_a.find_all{|d|next if d.group?||d.image?;ns<<d.name};ns.sort!; l=m.layers.add("ALL!");puts"\nLaying out ALL Components...\n\n"; es=m.active_entities; p=Geom;;Point3d.new(0,0,0);x=2.m;y=2.m;r=(Math.sqrt(ns.length)+0.5).to_i;c=0; ns.length.times{|i|puts ns[i]; tr=Geom;;Transformation.new(p); n=es.add_instance(ds[ns[i]],tr);n.layer=l;c+=1;if c>=r;p.x=0;p.y+=y;c=0;else;p.x+=x;end};puts"\nDone.";m.commit_operation
              end #def
            end #module
            ... OR something similar ... ๐Ÿ˜‰
            EDIT: typo fixed !
            • CadFatherC
              CadFather
              thanks TIG - works great.
              i think there's a small typo here:
              %(#008000)[def self.compogrid()
              m=Sketchup.active_model;m.start_operation("ALL!");ds=m.definitions;ns=[];]s.to_a.find_all{|d|next if d.group?||
              should read ds
              what's interesting is how fast it is even with lots of components ๐Ÿ‘ ๐Ÿ‘
                You are right - I have now changed the original to ' ds'...
                • CadFatherC
                  CadFather
                  Hi TIG - is it possible to have all the components placed along the red axis? i tried modifying the script but i always get the components on top of each other.. ๐Ÿ˜’
                    This [simpler] version spaces the component-instances 2m apart along the red/x axis [no stacking into a 'square']
                    module CADfather
                            m=Sketchup.active_model;m.start_operation("ALL!"); ds=m.definitions; ns=[]; ds.to_a.find_all{|d|next if d.group?||d.image?; ns<<d.name}; ns.sort!; l=m.layers.add("ALL!");puts"\nLaying out ALL Components...\n\n"; es=m.active_entities; p=Geom;;Point3d.new(0,0,0); x=2.m; ns.length.times{|i|puts ns[i]; tr=Geom;;Transformation.new(p); n=es.add_instance(ds[ns[i]],tr);n.layer=l; p.x+=x};puts"\nDone.";m.commit_operation
                          end #def
                    end #module
                    If the Ruby Console is open it reports what it's doing...
                    Change the x=2.m for a different spacing in red/x if desired...
                    • CadFatherC
                      CadFather
                      Thanks TIG - much appreciated - i'll try integrating it into the grid plugin.. ๐Ÿ‘ ๐Ÿ˜„
                      • gullfoG
                        gullfo
                        TIG script examples - an interesting side effect - if you have a component made of other components it pulls it apart and distributes them... in this example i have a DC component of an acoustic window which has frames and seals as sub-components. in a way, this could be handy for creating a "how to assemble" guide because it pulls it apart in order of nesting...
                        otoh this may not be a desired effect for the script in the end...
                        Glenn
                        http://www.runnel.com
                          The OP asked for all components to be displayed on a grid.
                          The code is very adaptable.
                          It ignores Groups and Images although it could as easily display those as well, or instead.
                          This version displays just components that have instances that are either in the model's entities or inside a non-component-entities context [i.e. inside a group that is not itself inside a component definition]
                              module CADfather
                                      UI.menu('Tools').add_item('Components to Grid'){self.compogrid_used()}
                                    def self.compogrid_used()
                                      ds=m.definitions
                                      ns=[]
                                      def self.recurse_parent(c)
                                        begin
                                          return c.parent
                                        rescue
                                          return nil
                                        next unless d.instances[0]
                                        next if d.group?
                                        next if d.image?
                                        skip=true
                                        d.instances.each{|i|
                                          if i.parent==m
                                            skip=false
                                            break
                                          elsif i.parent.group?
                                            i.parent.instances.each{|g|
                                              c=g
                                              while c
                                                c=self.recurse_parent(c)
                                                if m==c
                                                  skip=false
                                                  c=nil
                                                  break
                                        next if skip
                                        ns<<d.name
                                      ns.sort!;
                                      x=2.m
                                      ns.length.times{|i|
                                        puts ns[i]
                                        n.layer=l
                                        p.x+=x}
                                      puts"\nDone."
                                      m.commit_operation
                                    end #def
                              end #module
                            Amazing Artist
                            TIG Thanks
                            [color=#FF40FF:20ov4k9m]T[/color:20ov4k9m][color=#FF40F9:20ov4k9m]h[/color:20ov4k9m][color=#FF40F2:20ov4k9m]a[/color:20ov4k9m][color=#FF40EC:20ov4k9m]t[/color:20ov4k9m][color=#FF40E5:20ov4k9m]'[/color:20ov4k9m][color=#FF40DF:20ov4k9m]s[/color:20ov4k9m] [color=#FF40D2:20ov4k9m]m[/color:20ov4k9m][color=#FF40CC:20ov4k9m]y[/color:20ov4k9m] [color=#FF40BF:20ov4k9m]s[/color:20ov4k9m][color=#F940B9:20ov4k9m]t[/color:20ov4k9m][color=#F240B2:20ov4k9m]o[/color:20ov4k9m][color=#EC40AC:20ov4k9m]r[/color:20ov4k9m][color=#E540A6:20ov4k9m]y[/color:20ov4k9m][color=#DF40A0:20ov4k9m],[/color:20ov4k9m] [color=#D24093:20ov4k9m]a[/color:20ov4k9m][color=#CC408D:20ov4k9m]n[/color:20ov4k9m][color=#C54086:20ov4k9m]d[/color:20ov4k9m] [color=#C53A7A:20ov4k9m]I[/color:20ov4k9m][color=#CC3373:20ov4k9m]'[/color:20ov4k9m][color=#D22D6D:20ov4k9m]m[/color:20ov4k9m] [color=#DF2060:20ov4k9m]s[/color:20ov4k9m][color=#E51A5A:20ov4k9m]t[/color:20ov4k9m][color=#EC1353:20ov4k9m]i[/color:20ov4k9m][color=#F20D4D:20ov4k9m]c[/color:20ov4k9m][color=#F90646:20ov4k9m]k[/color:20ov4k9m][color=#FF0040:20ov4k9m]i[/color:20ov4k9m][color=#F9004D:20ov4k9m]n[/color:20ov4k9m][color=#F20059:20ov4k9m]g[/color:20ov4k9m] [color=#E50073:20ov4k9m]t[/color:20ov4k9m][color=#DF0080:20ov4k9m]o[/color:20ov4k9m] [color=#D20099:20ov4k9m]i[/color:20ov4k9m][color=#CC00A6:20ov4k9m]t[/color:20ov4k9m][color=#C500B2:20ov4k9m]![/color:20ov4k9m]
                              For SU 2017 Make
                              Incompatible with LightUP! ๐Ÿ˜ฎ
                              Curiously icons of LightUp apear!
                              And LightUp Disconnected
                              don't take a selection but all components on the scene! ๐Ÿ˜ฎ
                              Here must be display only "XTE" Selected : that is not the case! ๐Ÿ˜‰
                              All is recalled! (even the top view text who is not visible at the Plugin call! )
                              • jujuJ
                                juju
                                @pilou said:
                                For SU 2017 Make
                                [attachment=1:2yvqwupx]<!-- ia1 -->bizarrerie.jpg<!-- ia1 -->[/attachment:2yvqwupx]
                                [attachment=0:2yvqwupx]<!-- ia0 -->biz4.jpg<!-- ia0 -->[/attachment:2yvqwupx]
                                Pilou, are you OK? I don't see what this has to do with the thread above? Perhaps start your own thread or look for the thread this is supposed to be in?
                                  It's not the thread about Plugin "Components to Grid"?
                                  What better place to report that it is not compatible (for me in any case) with Light UP ?
                                  And it has curious behavior with the selection Components ? (for me in any case)
                                  Out of that i just reinstall SketchUp and must verify if above is always true!
                                  It will be my first Plugin to reload from a little thousand! ๐Ÿ˜„
                                    Alas not better ! ๐Ÿ˜ข
                                    My SketchUp is absolutly new! Only "Component on Grid" installed! ๐Ÿค“
                                    So no conflict possible! (like Light Up above) ๐Ÿ˜‰
                                    If i add new volumes : the same! that is making snowball ! All is redrawn! ๐Ÿ˜ฎ
