[Plugin Library] LibFredo6 - v14.5a - 23 May 24
@cgarchitekt said:
I've a problem with FredoTools or LibFredo (i can't determine exactly what is causing the problem) because in my Sketchup 2018 installation the Fredo tools are not running. I get the Fredotools Icon in the program but when I click on it to select a tool only a window opens with the Javascript that comes with the LibFredo6.
Could you confirm you have installed the latest versions of LibFredo6 and FredoTools.
Could you also post or send me a screenshot of the "Javascript".
@dave r said:
What version of SketchUp are you actually using? Your profile says you are using 2018 Free/Make which does not exist.
If you are using SketchUp 2018 Pro, did you install it correctly by right clicking on the downloaded installer and selecting Run as administrator?
Thanks for your answer.
I installed everything with the Extension Manager inside of the program. And it is shown correctly in the installed plugins. I've got no error message during installation process.
That doesn't answer the question about having installed SketchUp correctly. If you didn't install it correctly you could have issues such as you describe. It also doesn't answer the question about which version of SketchUp you are actually using.
everything is fine. Installed it completely new as administrator. Seems this was the problem.Thought an installation is not possible if you are not logged in as administrator. Apparently I was wrong.
Thank you all for your appreciated help to solve my problem.
Regards
cgArchitekt -
Happy that fixed it. FWIW, you should be logged into Windows as your normal user but when you install programs, right click on the installer and choose Run as administrator. That is actually different from being the system admin anyway. If you don't use the Run as administrator option, Windows security features prevent some needed program stuff from being installed correctly and this results in various strange behaviors. Some of those behaviors don't become obvious right away.
As DaveR says [beat me to the post!]
SketchUp should always be installed on PC thus:For a new installation...
Log into Windows as your normal user-account [whether or not this has admin=powers is irrelevant]/
Find the installer's exe file - usually in your Downloads folder...
Select that installer's exe file.
Right-click > Context-menu > "Run as administrator"
When prompted choose to "Install"...
Permissions etc are set up properly.If it's already installed...
Close SketchUp.
Run as above
When prompted choose "Repair"...
Permissions etc are set up properly.Never 'Run' an installer's exe file by double-clicking it - even if that user has admin powers it is not the same.
Running SketchUp as 'the admin' [i.e. NOT a normal user (who might also have some admin-powers)] will result in SketchUp behaving oddly - e.g. drag-n-drop will not work because SketchUp is operating at an elevated permissions level compared to Windows-Explorer... -
NEW RELEASE: LibFredo6 v10.7a - 12 Jun 20
LibFredo6 10.7a is a maintenance release, with bug fixing, adjustments for Mac (dialogs) and better support of imperail units in VCB
Tried installing libfredo6 v10.7a to no avail.. extension manager says the plugin is unsigned and sketchup keeps saying C:\Users"user_name"\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins\Fredo6_!LibFredo6 is missing after I restart the software and even when the said directory actually exists.
@fredo6 said:
I actually forgot about the feature '/', and its dual '*'.
I found the problem, and it will go into LibFredo6 v10.4c.
Thanks for signaling.
Intall LibFredo6 v10.7a but plugins not running
Is it the first time you install LibFredo6?
If so, this may be related to the installation of Sketchup, which you must do with "Run as Administrator".
Do you have a menu entry Window > LibFredo6 settings...?
Not a critical issue but is there any way to tweak the font sizes for the interface windows? Seems like I was able to do that using standard Windows zoom keyboard commands. Here's some examples. Hard to read.
Strange. It seems you don't have some fonts installed and default to Arial Narrow Black.
Did this happen with v10.7a only ?
What do you get for dialog boxes used by other plugins than mine?
I have Arial Narrow. It's Windows 7 Pro if that matters. Was fine before v10.7a.
Other dialog boxes are fine.
Best would be Tahoma or Helvetica.
With Windows 7, there may be many problems. This one is related to the change I made for some dialog boxes (like Check Plugins for Update) to rely on the recent API (HtmlDialog), because the old one (WebDialog) is being deprecated.
So, there is little I can do with this.
Hi Fredo,
I installed LibFredo 10.7a on SU2017 & macOS 10.13.6 and when I try to 'Check Fredo6 Plugins for Update', SketchUp crash.
The rest of functions work fine and the Tools too. -
@oxer said:
Hi Fredo,
The rest of functions work fine and the Tools too.Thanks for advising. Actually I get it on Catalina too. I will investigate.
I converted some of the LibFredo6 dialogs to HtmlDialog (instead of WebDialog), which is the 'new' framework for web dialogs since SU2017 (and recommended). There are plenty of problems and this could be one more.
Ok, thanks for the info.
I found the issue. Another discrepancy in HtmlDialog between Mac and Windows, and only for SU2017.
I'll release tomorrow morning
Thanks again for signaling.
I have that problem.
Error Loading File Fredo6_!LibFredo6.rb
Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
C:/Users/usuario/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:65:inprocess' C:/Users/usuario/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:72:in
module:LibFredo6_Loader'
C:/Users/usuario/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'Several times I tried to reinstall sketchup as admin and tried to repair sketchup...
