    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    617 Posts 155 Posters 590.8k Views 154 Watching
    • H Offline
      hugoakio
      I need a help. I'm trying to export an object and experimenting the folling error at the "erase coplanar edges":
      An error occurred in Round Push Pull
      Error in generation of the geometry
      reference to deleted Entity
      jointpushpullgeometry.rbe: 1023 -- entityID
      jointpushpullgeometry.rbe: 1023 -- block in geometry_coplanar_edges
      jointpushpullgeometry.rbe: 1020 -- each
      jointpushpullgeometry.rbe: 1020 -- geometry_coplanar_edges
      jointpushpullgeometry.rbe: 366 -- block in geometry_robot_erase_coplanar_edges
      jointpushpullgeometry.rbe: 362 -- each
      jointpushpullgeometry.rbe: 362 -- geometry_robot_erase_coplanar_edges
      jointpushpullgeometry.rbe: 220 -- robot_call_action
      jointpushpullgeometry.rbe: 183 -- geometry_robot_exec
      jointpushpullgeometry.rbe: 166 -- geometry_robot
      jointpushpullgeometry.rbe: 81 -- block in geometry_execute
      lib6operation.rbe: 370 -- step_geometry
      lib6operation.rbe: 305 -- block in yield?
      What i'm doing wrong?
      • fredo6F Offline
        Nothing a priori.
        I have fixed the problem itself (to go in a next version of JPP), but that does not mean you will get a correct result, because you must likely be in a special situation of topology (which RoundPushPull is very sensitive to).
        It would help if you posted the model and indicate which operation you were trying to perform.
          daniabreu1
          Hi, I am having a problem with this plugin SU2020 - Trying to use the jointpushpull= and a little grade surface keep showing up and the tool doesn't work. Any solutions?
            You've given no useful information making it impossible to help. Share your SketchUp file and give a clear description of what you are trying to accomplish. Also show us what settings you are using with the extension.
              daniabreu1
              Thanks Dave. Somehow I uninstall it and installed again and it works. Thank you for trying to help tho! πŸ˜„
                daniabreu1
                Good evening everybody,
                Again I am having problem ith the thickener.
                Date: 15-Apr-20 20:31:28
                An error occurred in Thickener
                Cannot convert argument to Geom::Point3d
                jointpushpullgeometry.rbe:: 531 -- vector_to
                jointpushpullgeometry.rbe:: 531 -- geometry_block_reversal
                jointpushpullgeometry.rbe:: 243 -- geometry_robot_prepare_mesh
                jointpushpullgeometry.rbe:: 212 -- robot_call_action
                jointpushpullgeometry.rbe:: 183 -- geometry_robot_exec
                jointpushpullgeometry.rbe:: 166 -- geometry_robot
                jointpushpullgeometry.rbe:: 81 -- block in geometry_execute
                lib6operation.rbe:: 370 -- step_geometry
                lib6operation.rbe:: 419 -- start_execution
                jointpushpullgeometry.rbe:: 81 -- geometry_execute
                jointpushpulltool.rbe:: 1118 -- go_preview_or_geom
                jointpushpulltool.rbe:: 844 -- dragging_stop
                jointpushpulltool.rbe:: 1399 -- execute_validate
                jointpushpulltool.rbe:: 1590 -- onReturn
                I have LibFredo6v9.5k and using SU2020. There is a post describing almost the same thing:
                "It's a fairly complex surface - a piece of terrain that is a hill with sections cut out of it (I draped a road onto the surface so that counts as a separate surface, for example)."
                It was solve with Libfredo 9.0 but I have 9.5 version.
                Any idea?
                Thank you all.
                • fredo6F Offline
                  I fixed the error in the code, but somehow this reflects a problem or complexity in the generated geometry. It may be helpful to get the model where it happens.
                  I am no longer able to publish updates to my plugins, pending Sketchup changes to their releasing process for developers.
                  So the fix will go in the next version whenever I can resume publishing.
                    rv1974
                    Hi Fredo,
                    Say I have a surface cut to non-coplanar patches by visible edges.
                    I can't find a proper combination of Borders+Surface selection settings to perform a global JPP so every patch would get an independent border by contour (BTW there's some negative molding).
                    I'm able to JJP manually patch-by-patch (demonstrated in attached gif) but there's no way to process all surface en-masse instantly.
                    Would it be possible to implement please?
                    • fredo6F Offline
                      First, you could select the 4 surfaces at once
                      • select the first surface
                      • Move over the other surfaces with SHIFT pressed
                      • Release Shift
                      Second, if you do it surface by surface, you should toggle on the button "Neighbour influence" in the 'Misc' sub-palette.
                        rv1974
                        Fredo, I don't understand. Could you please show 'one click' procedure (not strip by strip clicks). thank you in advance.
                        Untitled.skp
                        • fredo6F Offline
                          I am not clear. Do you want a 'valley' between each surface or have them joined.
                          If you wish the valleys, then you have to select the surfaces one by one. Otherwise, you would mold the whole terrain.
                            rv1974
                            πŸ˜† you just exactly reproduced the way I created the 'wanted' model.
                            Originally I just wanted clarity (or request πŸ˜‰) maybe there's some combination of settings that allows to achieve the 'wanted' result without tedious 'one by one' clicking
                            • fredo6F Offline
                              @rv1974 said:
                              :lol: you just exactly reproduced the way I created the 'wanted' model.
                              Many things can be done, but it would make the UI more complex...
                                rv1974
                                something like this
                                  rv1974
                                  Ok, I'm just suggesting to tweak the plugin's behavior without UI changing:
                                  If face selection = surface,
                                  molding not equal 0,
                                  borders = grid,
                                  Then
                                  'moldings' to be created between surfaces (and not along contour only)?
                                    a_pusen
                                    This does not work in Sketchup 2020 after installing the latest Fredotools. When will this be fixed?
                                      It should work OK.
                                      You need the latest RBZs installing for the Fredo Extensions and his LibFredo.
                                      Note that the JPP Extension is separate from FredoTools Extension ???
                                      After installing them you'll also need to restart SketchUp to sync everything.
                                      When you say, "it doesn't work", what is the problem ? what are the error messages ? etc - providing those [if any] would help us to help you...
                                        Tymnastik
                                        Please I have installed fredo jpits shows on the tool bar but it won't work
                                          Did you also install LibFredo6?
                                          What version of SketchUp are you actually using? Your profile says 2018 Free/Make but there is no such version. Knowing the right version could help us help you.
                                            AISmebel
                                            hi Fredo.
                                            I ran into such a problem, I cannot make a uniform indentation around the entire perimeter on a model with an irregular shape. I couldn't find any plugin that could do this.
                                            I have a big request to you to consider this improvement in the next versions of your excellent plugin. Thank you so much for your work!
                                            https://youtu.be/wCsli3Ps7xc
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 30
                                            • 31
                                            • 15 / 31
