    Flowify problems
    extensions
    70 Posts 25 Posters 48.2k Views 25 Watching
    • T
      taydavid03
      Wow you are amazing. Thank you!
      This was very helpful... Again, thank you Pilou!
      • H
        hellolouise
        I am really struggling to get Flowify to work. I don't understand why so any help would be appreciated.
        I have attached the file πŸ˜„
        help.skp
        • H
          hellolouise
          what does raw faces mean?
            You must don't have Group of Groups for the objects to be projected!
            Only one Group of faces! (raw face) πŸ€“
            But in your case there are also something with all modules!
            Maybe some overlapings somewhere!
            I investigate! πŸ˜„
            In fact some connections between modules are very bad!
            (if only one is existing Flowify will refuse to work! πŸ˜„
            You must have very prΓ©cise ones! πŸ˜‰
            Redraw precisely your modules between them and you will have no problem! πŸ˜‰
            Here with 2 different modules from side of your model.
            • H
              hellolouise
              Thank you so much that is very helpful!
              I will try again πŸ˜„)
              • O
                optimaforever
                I have a strange behaviour too...
                The flowify command generates a huge model, with an array of sectional faces.
                The source material
                First the source material: Group 1 composed of A target surface / B source surface / C projection vectors and D the source mesh (exploded)
                And the result
                The resulting groups from the flowify command
                I succeeded all the other meshes with the same method but here I've got a bug...
                The skp
                • newnoobN
                  newnoob
                  I am using flowify for the first time with very simple geometry but I get the error message
                  " INPUT ERROR: Error while parsing the projection grid".
                  https://sketchucation.com/forums/download/file.php?mode=view&id=158854&sid=d47475267b2b642d948ff06d550663e6
                  I have checked my model several times but I don't understand what I do wrong. I have also named all the groups like Pilou in his first post.
                  If someone could tell me what i do wrong I'd appreciate it.
                  flowify.skp
                    Your Start Surface C must be a "rectangular" form and not the same surface as the original object ! πŸ˜‰
                    • newnoobN
                      newnoob
                      Ahhh, "rectangular", got it. Now it's working. I somehow missed that. I thought "plane".
                      Many Thanks Pilou! I'm glad you are still around!
                      • C
                        CREATIVE WIERDO
                        Hello.
                        I have a problem with Flowify tool. Please check my file because i have made my groups correctly i think and when i choose the command flowify -> impose grid, the grid doesnt appear.
                        What am i doing wrong? I saw a video on youtube that says that if i have done my groups correctly a grid must appear.
                        Thanks for the help.
                        Help needed.skp
                          What version of SketchUp? Your profile says 2018 Free/Make but that doesn't exist.
                            Can you post your skp file in "save as" V6 for more compatibilities with previous version for have some help! πŸ˜‰
                            • jujuJ
                              juju
                              I'm not sure how useful this would be these days, the earliest version I've seen people working on (recently) is version 8, rather ask people to post in SU 2017 version / format. Plus you're already on SU 2017 Make...
                                Better to cover the maximum range! πŸ˜‰
                                It's the same time to make (1 second) πŸ€“
                                • jujuJ
                                  juju
                                  Yeah, but if you ask something that seems outrageous then people will be less likely to follow the advise.
                                    They want advices so they will make all for that! πŸ˜„
                                      aamirkaiser
                                      @pilou said:
                                      But before use the Curviloft by Fredo , use other Tools by Fredo for transform your 4 curves of the ending surface! (Bezier tools (?) )
                                      Don't touch the 2 verticals (depend of number of segments you want but as it's vertical straight lines...)
                                      Transform Curve in PolyLine (Right Click / ) (upper & bottom curves)
                                      then Segmentor of Polyline (upper & bottom curves)
                                      (for example take 10 segments for upper and bottom Polylines - you can move some points if you want)
                                      then you will obtain that in Curviloft (third icon "Skin contour" )
                                      [attachment=3:26d9tppe]<!-- ia3 -->segmentor.jpg<!-- ia3 -->[/attachment:26d9tppe]
                                      You will obtain a better result! β˜€ ( 1 minute & 30 seconds) (start surface (C) can be the exact straight rectangle projection of the start volumes (E))
                                      [attachment=2:26d9tppe]<!-- ia2 -->yours better.jpg<!-- ia2 -->[/attachment:26d9tppe]
                                      Ps You must also clean your original object! πŸ˜„
                                      [attachment=1:26d9tppe]<!-- ia1 -->clean_line.jpg<!-- ia1 -->[/attachment:26d9tppe]
                                      I have a problem utilizing the flowify plugin, and I think its the density that's the problem, can you tell me a work around for that issue... I have used flowify successfully multiple times so I know the selection or the group isn't the problem... It would be wonderful If you could help me out...
                                      Please help
                                        akash das
                                        hi i am really struggling to use flowify, inspite of making sure of all the group of
                                        1. curve surface
                                        2. flat surface (a rectangle)
                                        3. connecting lines
                                        4. the module with raw surface
                                        i have checked all the perimeters it doesn't work with all kind of models i feel.
                                        kindly help
                                        • cottyC
                                          cotty
                                          You can upload an example model so that we can have a deeper look...
                                          my SketchUp gallery
                                          • Y
                                            yashmishra
                                            a request for help : have been trying to get this right for past 2 hours everytime a different error is coming up. please could anyone help me out.
                                            help me flowify
                                            • 1 / 4
