    Flowify problems
    extensions
    70 Posts 25 Posters 46.8k Views 25 Watching
      But before use the Curviloft by Fredo , use other Tools by Fredo for transform your 4 curves of the ending surface! (Bezier tools (?) )
      Don't touch the 2 verticals (depend of number of segments you want but as it's vertical straight lines...)
      Transform Curve in PolyLine (Right Click / ) (upper & bottom curves)
      then Segmentor of Polyline (upper & bottom curves)
      (for example take 10 segments for upper and bottom Polylines - you can move some points if you want)
      then you will obtain that in Curviloft (third icon "Skin contour" )
      You will obtain a better result! β˜€ ( 1 minute & 30 seconds) (start surface (C) can be the exact straight rectangle projection of the start volumes (E))
      Ps You must also clean your original object! πŸ˜„
        If you draw a simple line(s) as vertical(s) (so no middle segments) that will work also ! πŸ€“
        and calculus will be some more speedy! 13 seconds! πŸ’š
          I took your file but with a little changement! πŸ˜„
          Always use the Hidden geometry for validate your choice! πŸ˜‰
          Will work but in a little big time! Because your start object is very dense!
          And little deformations on the extremities due difference of segmentation!
            taydavid03
            Wow you are amazing. Thank you!
            This was very helpful... Again, thank you Pilou!
            • H Offline
              hellolouise
              I am really struggling to get Flowify to work. I don't understand why so any help would be appreciated.
              I have attached the file πŸ˜„
              help.skp
              • H Offline
                hellolouise
                what does raw faces mean?
                  You must don't have Group of Groups for the objects to be projected!
                  Only one Group of faces! (raw face) πŸ€“
                  But in your case there are also something with all modules!
                  Maybe some overlapings somewhere!
                  I investigate! πŸ˜„
                  In fact some connections between modules are very bad!
                  (if only one is existing Flowify will refuse to work! πŸ˜„
                  You must have very prΓ©cise ones! πŸ˜‰
                  Redraw precisely your modules between them and you will have no problem! πŸ˜‰
                  Here with 2 different modules from side of your model.
                  • H Offline
                    hellolouise
                    Thank you so much that is very helpful!
                    I will try again πŸ˜„)
                    • O Offline
                      optimaforever
                      I have a strange behaviour too...
                      The flowify command generates a huge model, with an array of sectional faces.
                      The source material
                      First the source material: Group 1 composed of A target surface / B source surface / C projection vectors and D the source mesh (exploded)
                      And the result
                      The resulting groups from the flowify command
                      I succeeded all the other meshes with the same method but here I've got a bug...
                      The skp
                      • newnoobN Offline
                        newnoob
                        I am using flowify for the first time with very simple geometry but I get the error message
                        " INPUT ERROR: Error while parsing the projection grid".
                        https://sketchucation.com/forums/download/file.php?mode=view&id=158854&sid=d47475267b2b642d948ff06d550663e6
                        I have checked my model several times but I don't understand what I do wrong. I have also named all the groups like Pilou in his first post.
                        If someone could tell me what i do wrong I'd appreciate it.
                        flowify.skp
                          Your Start Surface C must be a "rectangular" form and not the same surface as the original object ! πŸ˜‰
                          • newnoobN Offline
                            newnoob
                            Ahhh, "rectangular", got it. Now it's working. I somehow missed that. I thought "plane".
                            Many Thanks Pilou! I'm glad you are still around!
                              CREATIVE WIERDO
                              Hello.
                              I have a problem with Flowify tool. Please check my file because i have made my groups correctly i think and when i choose the command flowify -> impose grid, the grid doesnt appear.
                              What am i doing wrong? I saw a video on youtube that says that if i have done my groups correctly a grid must appear.
                              Thanks for the help.
                              Help needed.skp
                                What version of SketchUp? Your profile says 2018 Free/Make but that doesn't exist.
                                  Can you post your skp file in "save as" V6 for more compatibilities with previous version for have some help! πŸ˜‰
                                  • jujuJ Offline
                                    juju
                                    I'm not sure how useful this would be these days, the earliest version I've seen people working on (recently) is version 8, rather ask people to post in SU 2017 version / format. Plus you're already on SU 2017 Make...
                                      Better to cover the maximum range! πŸ˜‰
                                      It's the same time to make (1 second) πŸ€“
                                      • jujuJ Offline
                                        juju
                                        Yeah, but if you ask something that seems outrageous then people will be less likely to follow the advise.
                                          They want advices so they will make all for that! πŸ˜„
                                            aamirkaiser
                                            [attachment=3:26d9tppe]<!-- ia3 -->segmentor.jpg<!-- ia3 -->[/attachment:26d9tppe]
                                            [attachment=2:26d9tppe]<!-- ia2 -->yours better.jpg<!-- ia2 -->[/attachment:26d9tppe]
                                            [attachment=1:26d9tppe]<!-- ia1 -->clean_line.jpg<!-- ia1 -->[/attachment:26d9tppe]
                                            I have a problem utilizing the flowify plugin, and I think its the density that's the problem, can you tell me a work around for that issue... I have used flowify successfully multiple times so I know the selection or the group isn't the problem... It would be wonderful If you could help me out...
                                            Please help
                                            • 1 / 4
