    SkecthUp 2020.1 - anyone using it already?
    17 Posts 7 Posters 2.3k Views 7 Watching
    • GD3DesignG
      GD3Design
      Just installed today. Working on a 650mb model and really impressed with the increased performance, specially with Outliner open. This model had been killing me before...(I should note that I moved straight from 2019 to 2020.1) (I should also note that I haven't installed any plugins yet, the 5 bazillion plugins i use could have been slowing down 2019...so we'll see) But anyway, no problems so far. πŸ˜„
      • utilerU
        utiler
        Works fine for me..... enhancements to Layout is particularly cool.
        No selecting the model when you want to perform simple move / select tasks!! πŸ‘ πŸ‘ πŸ‘
        Just Curious...
        • K
          kaas
          thanks for the replies. will install as well now.
            Make sure when you install it you right click on the downloaded installer and choose Run as administrator.
            • K
              kaas
              Thanks Dave. No problem installing the R1.
                Does that mean you installed it as above?
                • K
                  kaas
                  yes, SU install always as admin after the first suggestions to do so a few years ago.
                  • kimi kimiK
                    kimi kimi
                    SketchUp works fine for me, but LayOut does not. I can't save a file if it has hybrid style drawing in it, and I can't generate a PDF. I have to turn everything into raster, then I can save and export PDF files. It worked fine in previous versions. I don't know if anyone else is having this problem?
                    • K
                      kaas
                      You're installation is bugged maybe? LO drawing with vector + hybrid + images saves fine for me, also exports fine with native pdf export.
                        I haven't had any difficulty with exports from LayOut 2020 or 2020.1 Hybrid rendered viewports don't cause any problem. I'd be curious whether SketchUp and LayOut were properly installed and what graphics card is involved.
                        • GD3DesignG
                          GD3Design
                          Yeah, everything still running fine for me. Except one small issue I'm having: When I right click on skp or layout files, Sketchup/Layout 2020 aren't showing as an openning option in the context menu...(all other installed versions show up still...(2017-2019). I've tried setting default through windows control panel/settings, and also through file properties, change default program. no luck... (yes, installed SU by right click install as admin...even tried a 'repair'.)
                            rv1974
                            Looks like a few nice changes. Anyone already tried? Any Bugs / annoyances?
                            'Invert selection' in RMB menu in emptyarea is so idiotic. It's like 'un-explode' instead of 'group'
                              Invert Selection in empty space = Select All.
                                rv1974
                                Exactly, and it looks like one of Monty Python sketches.
                                The onlyplace this 3 line menu can happen is empty area, and the onlything you can 'select inverse' in empty area is 'Select All'. Now 2 questions arise:
                                Why just don't call things by their names?
                                And generally, why 'select all' is so essential in empty area?
