    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.4k Views 171 Watching
      Anton_S
      @bifterx said:
      Hi I just don't get a context menu.
      Don't know what I am doing wrong - on 19.3
      Valid Licence on 1.7.2a
      https://www.dropbox.com/s/d7nf3x0v59kmgqx/Screen%20Shot.png?dl=0
      Hello. It seems like you're trying to assign a Pin property to the selected object from within a group. If so, this is not exactly the way to do it. You must a assign a pin property to the outer, top-level group. The inner groups will be treated as sub-pins automatically.
      The ClothWorks context menu is mostly available to top level groups and components. Let me know if this answers your question.
      • K
        kwoon
        ClothWorks Korean language version
        ClothWorks 한국어 언어 파일 입니다.
          Anton_S
          Thank you! Very much appreciated. I will include your translation with the next release.
          • K
            KostoK
            Hi, Does this extension work in Sketchup2020? I am getting stuck already at creating the quadrilateral grid step (nothing is created).
            Best regards,
            Ksenia
              Yes. It works in SketchUp 2020. Here it is caught in process.
              Did you applying the grid to a component?
              • iichiversiiI
                iichiversii
                Hope someone can help me out, I ran into this issue today when trying to activate my licence again as I haven't used Clothworks for quite sometime, so straight to the point, when I try to use Menu>Clothworks>Licence this message pops up, as you can see clothworks is installed but i cant activate my licence, any ideas as to why this is happening, please excuse me but im just a modeler and am computer literate when it comes to issues like this.
                Bring on the Rain...
                  Have you tried reinstalling the SketchUcation Toolset - it includes the SCF_licensing stuff...
                  https://sketchucation.com/pluginstore?pln=SketchUcationTools
                  The file reported as missing is in its subfolder set ??
                  • iichiversiiI
                    iichiversii
                    Yes I did, still the same error every time
                      Do you have the latest version of the SketchUcation Toolset installed ?
                      Its RBZ is available from the PluginStore...
                      The 'missing' .so file referred to in the error-message...
                      If you manually open the folder referred to in the message is that file there ?
                      If so, then am suspecting that there's a permissions issue and the license code/SketchUp can't read the required subfolder/file...
                      When you installed SketchUp did you do it in the correct way ?
                      You can always try to fix the installation as follows...
                      Whilst logged into Windows as your normal user-account ensure that SketchUp is closed.
                      Find the installer's exe file - usually in your Downloads folder.
                      Select that exe file's icon, right-click > context-menu > "Run as administrator"
                      When prompted choose "Repair"...
                      When it completes try again...
                      Installing any complex app in any other way can lead to unpredictable problems later - so never double-click an installer's exe file's icon to 'Run' it - even if your user account has admin-powers if is NOT the same thing...
                      Preinstalled extensions etc should not be adversely affected by doing the 'Repair'
                      But one issue that might arise is that some already installed files might have their permissions ruined thus far, you can try reinstalling them for current RBZs to see if that helps...
                      • L
                        LinKaye
                        Does this work with SU 2020??
                        thanks
                        Lin
                          Yes - as was explained a few posts earlier...
                            Anton_S
                            @iichiversii It is possible that you have SketchUcationTools installed in multiple plugin folders, which causes only one (and the unwanted one) to be loaded. Please perform the following steps to ensure that you have only one installation:
                            1. Close SketchUp (if open)
                            2. Open your File Explorer
                            3. Paste the following into the address bar:
                              %programdata%\SketchUp\SketchUp 2020\SketchUp\Plugins
                              Replace 2020 with 2019 if you're using a prior SketchUp version. Press the enter key. This should navigate you the first plugins folder if the folder exists.
                            4. If the folder exists, delete SketchUcationfolder and SketchUcation.rb file.
                            5. Now, navigate to the other folder, by pasting the following into the address bar: %appdata%\SketchUp\SketchUp 2020\SketchUp\Plugins and also delete the SketchUcation folder and file.
                              Upon performing the steps above, you should then do a fresh installation of the SketchUcationTools:
                            • Download latest SketchUcationTools at the following URL: https://sketchucation.com/resources/plugin-store-download
                            • Open SketchUp
                            • Access and select (Menu) Extension Manager
                            • Within the extension manager window, click on the Install Extension button
                            • Select the downloaded pluginstore.rbz file and click Open.
                              Upon performing the steps, your SketchUcationTools should start working again (unless the issue has to due with what TIG mentioned in the previous post).
                            If this does work, ensure that you don't have any other duplicate plugins installed.
                            Hope this helps.
                            • JujuSKPJ
                              JujuSKP Extension Creator
                              I did not find a way to save my presets I already manage, like the one for pillows, an other for curtains ...
                              If I stay on my sketchup drawing file I have my saved presets ok. But if I draw a cloth on an other sketchup file impossible to retrieve my clothworks presets.
                              Do I miss something ? Will it be possible to manage them as personal datas we can share and use where we want ?
                              thanks
                                JamesLeese
                                I have been trying to create another flag. The first one I create a year or so ago worked great. This time, however, my context menu is not showing ClothWorks → Make Cloth or ClothWorks → 1 Cloth → Apply Quadrilateral Grid. What am doing wrong? I am using Sketchup 2019 and have your latest plug-in as well as sketchucation's latest plug in. I have installed both and restarted SUP 2019. Still no context menu with Clothworks in it.
                                  Anton_S
                                  Hi. Great question! ClothWorks shared materials (the ones you manage with Save and Rename buttons) are only bound to a SketchUp model creating them. To use the same materials in another model, simply export them from your previoous model and import them into your new model. Make use of:
                                  • (Menu) > Extensions > ClothWorks > Export Materials
                                  • (Menu) > Extensions > ClothWorks > Import Materials
                                    Anton_S
                                    Hi! Is your flag grouped and is it a top-level group? If so, is your ClothWorks installed? To check if ClothWorks is there, you should see ClothWorks in your Extension Manager window.
                                    • TutorialsUpT
                                      TutorialsUp
                                      Can you please add that feature. that allow us to Scale the Cloth X Y and Z axis separately. Right now cloth Scale option scale uniformly from all axis.
                                      bug in SketchUp 2020
                                      every time I select a cloth it's turn on "Show Hidden Objects" a new feature of SketchUp 2020.
                                        Anton_S
                                        Thank you for your report! I will look into the issue and noted your feature request.
                                          ricbower
                                          Hi Anton
                                          I am loving the potential of Clothworks but am struggling with it constantly crashing Sketchup when I press go on the simulation. I have tried reinstalling extension and simplifying my model. It seems to be connected with applying the grid prior to the simulation. I am using Sketchup Make 2017 on the following machine spec 16gb ram,
                                          Operating System
                                          Windows 10 Professional (x64) Version 1903 (build 18362.778)
                                          System Model
                                          Apple Inc. MacBookPro11,5 1.0
                                          Processor
                                          2.50 gigahertz Intel Core i7-4870HQ
                                          Thanks for your help
                                          Ric
                                            What graphics card? Typically crashes related to large amounts of geometry are related to graphics issues. And you're running Windows 10 on a MacBook Pro? Parallels? There have been other reports of issues with graphics by others using SketchUp in Windows on Macs. Maybe you're running into the same thing. What happens if you try Clothworks in SketchUp on Mac instead?
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 36
                                            • 37
                                            • 24 / 37
