    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 911.4k Views 166 Watching
      Anton_S
      Cool news! By the way, I'm interested if you could possibly do a feature to place patterns on flat surfaces and then project it to hard, that is to say, such surfaces with which "flowify" or other similar plugins can not work. Look as an example my screenshot. Such a feature presents in Maya, see the video about https://www.youtube.com/watch?v=OeJEthJe6cQ. So how do you think is it possible to realize in SU or what? Thanks!
      Though it will make too many edges that SU will not be able to work with.
      Why not use Blender for wrapping?
      • summerson1990S
        summerson1990
        Yes, but first I need to study blender a little bit because I haven’t got yet any experience working in it.
          majmoonka
          Hello Anton! I've bought the licence to Clothworks but it not working correctly. But context menu didn't appear after activation ((
            Clothworks shows up in the Context menu when you right click on a group or component. It's not supposed to show up when you right click on a face.
            Read steps three and four under Draping Rectangular Table
            https://drive.google.com/file/d/1TXQk2AM0HE3BvFLalYPpxQD5YVLIp6fF/view
              majmoonka
              Thank you! I didn't understand instruction 😳
              • B
                Bifterx
                Hi I just don't get a context menu.
                Don't know what I am doing wrong - on 19.3
                Valid Licence on 1.7.2a
                https://www.dropbox.com/s/d7nf3x0v59kmgqx/Screen%20Shot.png?dl=0
                  Anton_S
                  Hello. It seems like you're trying to assign a Pin property to the selected object from within a group. If so, this is not exactly the way to do it. You must a assign a pin property to the outer, top-level group. The inner groups will be treated as sub-pins automatically.
                  The ClothWorks context menu is mostly available to top level groups and components. Let me know if this answers your question.
                  • K
                    kwoon
                    ClothWorks Korean language version
                    ClothWorks 한국어 언어 파일 입니다.
                      Anton_S
                      Thank you! Very much appreciated. I will include your translation with the next release.
                      • K
                        KostoK
                        Hi, Does this extension work in Sketchup2020? I am getting stuck already at creating the quadrilateral grid step (nothing is created).
                        Best regards,
                        Ksenia
                          Yes. It works in SketchUp 2020. Here it is caught in process.
                          Did you applying the grid to a component?
                          • iichiversiiI
                            iichiversii
                            Hope someone can help me out, I ran into this issue today when trying to activate my licence again as I haven't used Clothworks for quite sometime, so straight to the point, when I try to use Menu>Clothworks>Licence this message pops up, as you can see clothworks is installed but i cant activate my licence, any ideas as to why this is happening, please excuse me but im just a modeler and am computer literate when it comes to issues like this.
                            Bring on the Rain...
                              Have you tried reinstalling the SketchUcation Toolset - it includes the SCF_licensing stuff...
                              https://sketchucation.com/pluginstore?pln=SketchUcationTools
                              The file reported as missing is in its subfolder set ??
                              • iichiversiiI
                                iichiversii
                                Yes I did, still the same error every time
                                  Do you have the latest version of the SketchUcation Toolset installed ?
                                  Its RBZ is available from the PluginStore...
                                  The 'missing' .so file referred to in the error-message...
                                  If you manually open the folder referred to in the message is that file there ?
                                  If so, then am suspecting that there's a permissions issue and the license code/SketchUp can't read the required subfolder/file...
                                  When you installed SketchUp did you do it in the correct way ?
                                  You can always try to fix the installation as follows...
                                  Whilst logged into Windows as your normal user-account ensure that SketchUp is closed.
                                  Find the installer's exe file - usually in your Downloads folder.
                                  Select that exe file's icon, right-click > context-menu > "Run as administrator"
                                  When prompted choose "Repair"...
                                  When it completes try again...
                                  Installing any complex app in any other way can lead to unpredictable problems later - so never double-click an installer's exe file's icon to 'Run' it - even if your user account has admin-powers if is NOT the same thing...
                                  Preinstalled extensions etc should not be adversely affected by doing the 'Repair'
                                  But one issue that might arise is that some already installed files might have their permissions ruined thus far, you can try reinstalling them for current RBZs to see if that helps...
                                  • L
                                    LinKaye
                                    Does this work with SU 2020??
                                    thanks
                                    Lin
                                      Yes - as was explained a few posts earlier...
                                        Anton_S
                                        @iichiversii It is possible that you have SketchUcationTools installed in multiple plugin folders, which causes only one (and the unwanted one) to be loaded. Please perform the following steps to ensure that you have only one installation:
                                        1. Close SketchUp (if open)
                                        2. Open your File Explorer
                                        3. Paste the following into the address bar:
                                          %programdata%\SketchUp\SketchUp 2020\SketchUp\Plugins
                                          Replace 2020 with 2019 if you're using a prior SketchUp version. Press the enter key. This should navigate you the first plugins folder if the folder exists.
                                        4. If the folder exists, delete SketchUcationfolder and SketchUcation.rb file.
                                        5. Now, navigate to the other folder, by pasting the following into the address bar: %appdata%\SketchUp\SketchUp 2020\SketchUp\Plugins and also delete the SketchUcation folder and file.
                                          Upon performing the steps above, you should then do a fresh installation of the SketchUcationTools:
                                        • Download latest SketchUcationTools at the following URL: https://sketchucation.com/resources/plugin-store-download
                                        • Open SketchUp
                                        • Access and select (Menu) Extension Manager
                                        • Within the extension manager window, click on the Install Extension button
                                        • Select the downloaded pluginstore.rbz file and click Open.
                                          Upon performing the steps, your SketchUcationTools should start working again (unless the issue has to due with what TIG mentioned in the previous post).
                                        If this does work, ensure that you don't have any other duplicate plugins installed.
                                        Hope this helps.
                                        • JujuSKPJ
                                          JujuSKP Extension Creator
                                          I did not find a way to save my presets I already manage, like the one for pillows, an other for curtains ...
                                          If I stay on my sketchup drawing file I have my saved presets ok. But if I draw a cloth on an other sketchup file impossible to retrieve my clothworks presets.
                                          Do I miss something ? Will it be possible to manage them as personal datas we can share and use where we want ?
                                          thanks
                                            JamesLeese
                                            I have been trying to create another flag. The first one I create a year or so ago worked great. This time, however, my context menu is not showing ClothWorks → Make Cloth or ClothWorks → 1 Cloth → Apply Quadrilateral Grid. What am doing wrong? I am using Sketchup 2019 and have your latest plug-in as well as sketchucation's latest plug in. I have installed both and restarted SUP 2019. Still no context menu with Clothworks in it.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 35
                                            • 36
                                            • 23 / 36
