    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 375.1k Views 57 Watching
    • fredo6F Offline
      I can reproduce it. Strange. I am looking into the issue and will come back.
      • fredo6F Offline
        Problem of Sketchup curves not constructed fixed with LibFredo6 v9.5d.
        • BoxB Offline
          Thanks Fredo, a very timely fix as always.
          • fredo6F Offline
            Thanks for signaling the problem. Strange that nobody complained before, as this comes from a bug in LibFredo6 v9.5c, released on 10 January.
              AISmebel
              Good afternoon. I had a problem while working with smooth_curve. What can I do to treat him?
              • fredo6F Offline
                There seems to be a bug there, but I cannot reproduce it.
                Could you open the Ruby console to check if there are errors.
                  AISmebel
                  Good afternoon. I hope that I did everything right.
                  In SketchUp 2018, I had no such problem.
                  I think that the problem arose due to the transfer of plugins to SketchUp 2020.
                  Removing Curvizard, LibFredo and installing it again did not solve the problem.
                    @AISmebel
                    How is your Plugins folder within the ProgramData folder-path ?
                    The user's Plugins folder in within that user's AppData/Roaming path...
                    I hope you haven't made it manually ??
                    Can you try this in the Ruby Console [copy+paste+enter]:
                    Sketchup.find_support_file('Plugins')
                    It should return something like:
                    C:/Users/YOURUSERNAME/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins
                    If you have not installed SketchUp properly sometimes folder permissions gets messed up...
                    Close SketchUp/Layout, find the SketchUp installer exe file's icon [probably in Downloads]
                    Select it, right-click > context-menu > "Run as administrator"
                    When prompted choose 'Repair'
                    This should sort out permissions and paths etc...
                    Any other way of installing - e.g. double-clicking the exe file to simply 'Run' it is NOT the same thing and can result in weird errors...
                      AISmebel
                      Fredo, thank you very much for your help, everything worked for me. I was very pleased that you were able to help me so quickly.
                      Thank you for your plugins, they are very strong and very useful for many people.
                       Take this opportunity to answer me another question =>
                      404 Not Found
                      (sketchucation.com)
                      Thanks.
                      • fredo6F Offline
                        NEW RELEASE: Curvizard v2.4b - 10 Feb 20
                        Curvizard 2.4b is for some bug fixing.
                        Requirement: LibFredo6 9.5 or above
                        See Home Page of Curvizard for information and Download.
                        See Main post of this Curvizard thread for discussion, bug reports and suggestions.
                        • fredo6F Offline
                          @AISmebel
                          Could you make the test with the same model and configuration with this updated version of Curvizard.
                          EDIT: release as v2.4b on Sketchucation Extension Store.
                          Please leave the Ruby console open for potential error messages.
                          Many thanks
                          Fredo6_Curvizard - v2.4b - 10 Feb 20 - certified - encrypted.rbz
                            AISmebel
                            @tig said:
                            @AISmebel
                            Hey.
                            I use the SketchUcationTool plugin. It helps me quickly and easily expose my plugins. But I noticed that it works correctly when the plugins are located at the address:
                            😄 \ ProgramData \ SketchUp \ SketchUp 2018 \ SketchUp \ Plugins
                            Fredo fixed the bug. Perhaps it was not the location of the plugin.
                              AISmebel
                              Good afternoon. I have a problem with Curviloft and Curvizard plugins.
                              Perhaps the problem arose after updating LibFredo6.
                              Reinstalling the plugins did not help.
                              Delivered an earlier version of LibFredo6, the problem is not fixed.
                              Here is the link to the video: https://youtu.be/H06P-Fcx0Go
                              • fredo6F Offline
                                This is clearly a bug, and present since v10.0. Thanks for catching.
                                Could you try on the same model with LibFredo6 v10.3a, just published.
                                Many thanks
                                  AISmebel
                                  Fredo you are a magician !!! 😄))
                                  It was not me who caught the error, but rather she me;))
                                  I work in SketchUp and the slightest mistake in plugins makes my work uncomfortable. So thank you very much again!
                                  The second time I turned to you with a problem, and the second time we pleased me with its speed of solving it.
                                  P.S. The new version of LibFredo6_v10.3a fixed everything. So far, I do not see any errors.
                                  • E Offline
                                    Einstein
                                    Hi, Fredo,
                                    I have noticed that for all sub-tools of Curvizard settings are not updated until I exit the tool, and call it again.
                                    For example, Smooth Contours: if I change average angle, I can't see any change on the curve till I exit and call the tool again.
                                    Is this supposed behaviour? It's not too convenient. Do you think you could fix it?
                                    Tested on SketchUp 2021, Curvizard 2.4b, LibFredo 12.2a
                                    • F Offline
                                      fabain
                                      que pasara con mi curvizard instalado? me empieza a salir una mensaje que expirara enl 27 de julio. en 6 años que use el pluguin jasma me salio ese aviso
                                      • fredo6F Offline
                                        My plugins have become paid plugins since March.
                                        Please see this post for instructions on licensing.
                                        • E Offline
                                          Einstein
                                          Hello,
                                          I feel like I need some clarification here.
                                          I have downloaded Curvizard v2.4b on December 2021. I think it wasn't a paid plugin back then. Can I still use it for free without a time limit, or will it just stop working one day and ask me for paying?
                                            You'll have to wait and see. Just don't update any of Fredo6's extensions.
                                            Or better, since they seem to be so important to you, buy the permanent licenses for them and you won't have to worry about ever again. Besides, the cost of the licenses, especially the bundle, is trivial. Especially if your time has any value at all.
                                            • 10 / 10
