    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 757.6k Views 121 Watching
    • fredo6F Offline
      @rv1974 said:
      Take a look at TT's Edge tools (last 5 commands).
      https://sketchucation.com/pluginstore?pln=tt_edgetools
      But then tt_edgetools does the job.
      Do I miss something?
      Or do you want to keep the original curve?
        rv1974
        CurviShear generates right 'ramp' curve, TT's 'Make colinear' doesn't. That's the main difference 🙂
        The only CurviShear's weak link is UI.
        Group_728.skp
        • fredo6F Offline
          Ok. Understood. I put it on my list, but this is what I mean by 'interactive'.
            dalenster
            Hello, Not sure if I'm posting in the correct location. I have a shape with an image as the face. I'm trying to round the corners and have a smooth transition. However, I'm getting the following results. Is there a workaround, I'm I doing something wrong. I don't think this was a problem in the previous version.
            https://muzeoprints.com/wp-content/uploads/2020/01/Rounded-corner-with-image-fail.jpg
            • fredo6F Offline
              It would be helpful to say which tool you use (RoundCorner, FredoCorner, or something else).
              None of these tools have the objective to ensure texture continuity. In general, texture application should be done after the geometry is generated.
              Anyway, posting the model would help.
                kubap
                Hi Fredo,
                It's a great plugin, especially ThruPaint. Thank you 😄
                Is it possible to add an option to paint algong the shortest/lognest sides when painting whole groups/components?
                It would be great for example for wood furniture so the texture always goes along the long side of a plank. For example when you have a cupboard made of many planks every plank is textured along the longer sides automatically, as it is in real furniture.
                Now it's kind of random and the only way is to correct it manually face after face.
                • fredo6F Offline
                  @kubap said:
                  Is it possible to add an option to paint along the shortest/longest sides when painting whole groups/components?
                  Unfortunately, Sketchup does not provide any UV control for painting objects (groups or components). The positioning of textures is based on axes and position of the objects.
                  So, if you want control of orientation, you have to paint at the face level.
                  • fredo6F Offline
                    NEW RELEASE: FredoTools v3.8b - 05 Feb 20
                    Requirement: LibFredo6 v9.5e or above
                    FredoTools 3.8b is a minor release for ReportLabelArea, allowing to count the material coming from object containers, when faces are painted with the dedfault material.:
                    See FredoTools plugin home page for Download.
                    See also main post of this thread for User Discussion.
                      bharralure
                      Bonjour Fredo,
                      Je rencontre un problème avec "Volume Solide", aussi bien dans SU19 que SU20.
                      Je joins un Gif qui, j'espère sera plus explicite que ma mauvaise prose.
                      • fredo6F Offline
                        Je ne comprends pas trop ce qui se passe dans le Gif. Le modèle me serait plus utile.
                          bharralure
                          Bonjour Fredo,
                          Je viens seulement de prendre connaissance de votre réponse, et je vous en remercie. Je ne comprends pas pourquoi je na'ai pas été automatiquement alerté ?
                          Je cherche à connaître le volume de A (qui doit être de 0,00096 m³) que l'on peut obtenir en déduisant C (0,08502 m³) de B (0,08502 m³).
                          "Volume Solides" indique 0,04080 m³ du fait de la présence de "96 faces orientées incorrectement", même après avoir utilisé "AutoReverseFaces", et alors que "Solid Inspector²" ne trouve pas d'erreur.
                          Si j'inverse les faces sur C, "Volume Solides" trouve 241 Faces orientées incorrectement (ce qui est normal), et indique un volume faux. "AutoReverseFaces" corrige l'erreur parfaitement, et dans ce cas "Volume Solides" indique une valeur correcte.
                          Ma question est donc : pourquoi cela ne fonctionne pas sur A ?
                          Je viens de me souvenir qu'une version antérieure avais posé problème pour la volume des pièces crées "en miroir" (je n'ai pas retrouvé le post). Je viens donc de le rajouter à mon modèle que joins, le résultat est également faux.
                          Test_VolumeSolide.19.skp
                          • fredo6F Offline
                            NEW RELEASE: FredoTools v3.8c - 10 Feb 20
                            FredoTools 3.8c is a minor release for SolidVolume, to fix and issue whereby the volume could be sensititive to the orientation of faces.
                              bharralure
                              Bonjour Fredo,
                              Merci pour cette mise à jour rapide et efficace.
                              Je viens de tester sur SU19 et SU20, et tout est rentré dans l'ordre, parfait.
                              • V Offline
                                volker72
                                Hello Fredo,
                                is it possible to do the same with length as ReportLabelArea does with faces.
                                Volker
                                • fredo6F Offline
                                  You need to tell which length...length of edges, length of object bounding boxes, ...
                                  • V Offline
                                    volker72
                                    I am interested in the length of edges. The goal is to add up these lengths by layers. That would be wonderful.
                                      @jmdrla said:
                                      Unfortunately it is not in my extension menu and I cannot access the tools... What is the issue?
                                      First things first. FredoTools aren't supposed to show up in the Extension menu. They are supposed to show up in the Tools menu. Did you look there? Also did you restart SketchUp after installing the extensions?
                                      There's also a toolbar that can be made visible via View>Toolbars.
                                      @jmdrla said:
                                      I am assuming that this is not a version that can be used on SU2020 even though it shows as compatible with 2020.
                                      Not so. FredoTools work just fine in SketchUp 2020. Here is a screen shot from SU2020 showing the menu.
                                      Out of curiosity, when you installed SketchUp 2020, did you right click on the downloaded installer file and choose Run as administrator? BTW, maybe you could update your profile. It still shows you are using SU2017.
                                        jmdrla
                                        I loaded the FredoTools-v3.8c this morning in my SketchUp Pro along with the required library. I have tried to add the tools to the program about ten times now and it is showing up in the extension manager as installed and activated. Unfortunately it is not in my extension menu and I cannot access the tools. When I look at the details for the tools on the extension manager I can see that it is signed but there is no other information in the details. I am assuming that this is not a version that can be used on SU2020 even though it shows as compatible with 2020. What is the issue?
                                        OK I should have used the word tools instead of extensions. However the program is not in the tools menu. I did restart the SU2020 when I did the install and nothing appeared in my tools menu. I am uploading a screen shot so you can see what I have
                                        • E Offline
                                          edjul04
                                          If I generate area report, it shows all areas on the plugin screen but if I export to CSV it gives me an error and only shows the information of one of the entities.
                                          How can I fix the mistake?
                                          • fredo6F Offline
                                            What is the error?
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 19 / 24
