    [Plugin] FredoTools - v4.6a - 21 Oct 26
    464 Posts 123 Posters 882.8k Views 121 Watching
      rv1974
      Many years I dream of ability to explicitly move the end vertex, run CurviShear and get desired slope (it means curve as required condition has to be ditched).
      • fredo6F
        Unless I am wrong, you can do it natively
        1. Launch the Move tool with no selection
        2. Hover an extremity, click and drag vertically.
        3. The curve should deform itself
          rv1974
          It won't happen (the curve will be deformed in plan view and it won't even remotely resemble a ramp). That's why CurviShear was created.
          • fredo6F
            In short, you would like an interactive version of CurviShear....
              rv1974
              No (although I wouldn't disagree). Take a look at TT's Edge tools (last 5 commands).
              https://sketchucation.com/pluginstore?pln=tt_edgetools
              I'm talking of CurviShear to adopt the similar way of input.
              I wouldn't call it interactive. I just feed Curvishear real geometry (bunch of connected edges or polyline) and get result without any input in modal window.
              • fredo6F
                But then tt_edgetools does the job.
                Do I miss something?
                Or do you want to keep the original curve?
                  rv1974
                  CurviShear generates right 'ramp' curve, TT's 'Make colinear' doesn't. That's the main difference 🙂
                  The only CurviShear's weak link is UI.
                  Group_728.skp
                  • fredo6F
                    Ok. Understood. I put it on my list, but this is what I mean by 'interactive'.
                      dalenster
                      Hello, Not sure if I'm posting in the correct location. I have a shape with an image as the face. I'm trying to round the corners and have a smooth transition. However, I'm getting the following results. Is there a workaround, I'm I doing something wrong. I don't think this was a problem in the previous version.
                      https://muzeoprints.com/wp-content/uploads/2020/01/Rounded-corner-with-image-fail.jpg
                      • fredo6F
                        It would be helpful to say which tool you use (RoundCorner, FredoCorner, or something else).
                        None of these tools have the objective to ensure texture continuity. In general, texture application should be done after the geometry is generated.
                        Anyway, posting the model would help.
                        • K
                          kubap
                          Hi Fredo,
                          It's a great plugin, especially ThruPaint. Thank you 😄
                          Is it possible to add an option to paint algong the shortest/lognest sides when painting whole groups/components?
                          It would be great for example for wood furniture so the texture always goes along the long side of a plank. For example when you have a cupboard made of many planks every plank is textured along the longer sides automatically, as it is in real furniture.
                          Now it's kind of random and the only way is to correct it manually face after face.
                          • fredo6F
                            @kubap said:
                            Is it possible to add an option to paint along the shortest/longest sides when painting whole groups/components?
                            Unfortunately, Sketchup does not provide any UV control for painting objects (groups or components). The positioning of textures is based on axes and position of the objects.
                            So, if you want control of orientation, you have to paint at the face level.
                            • fredo6F
                              NEW RELEASE: FredoTools v3.8b - 05 Feb 20
                              Requirement: LibFredo6 v9.5e or above
                              FredoTools 3.8b is a minor release for ReportLabelArea, allowing to count the material coming from object containers, when faces are painted with the dedfault material.:
                              See FredoTools plugin home page for Download.
                              See also main post of this thread for User Discussion.
                              • B
                                bharralure
                                Bonjour Fredo,
                                Je rencontre un problème avec "Volume Solide", aussi bien dans SU19 que SU20.
                                Je joins un Gif qui, j'espère sera plus explicite que ma mauvaise prose.
                                • fredo6F
                                  Je ne comprends pas trop ce qui se passe dans le Gif. Le modèle me serait plus utile.
                                  • B
                                    bharralure
                                    Bonjour Fredo,
                                    Je viens seulement de prendre connaissance de votre réponse, et je vous en remercie. Je ne comprends pas pourquoi je na'ai pas été automatiquement alerté ?
                                    Je cherche à connaître le volume de A (qui doit être de 0,00096 m³) que l'on peut obtenir en déduisant C (0,08502 m³) de B (0,08502 m³).
                                    "Volume Solides" indique 0,04080 m³ du fait de la présence de "96 faces orientées incorrectement", même après avoir utilisé "AutoReverseFaces", et alors que "Solid Inspector²" ne trouve pas d'erreur.
                                    Si j'inverse les faces sur C, "Volume Solides" trouve 241 Faces orientées incorrectement (ce qui est normal), et indique un volume faux. "AutoReverseFaces" corrige l'erreur parfaitement, et dans ce cas "Volume Solides" indique une valeur correcte.
                                    Ma question est donc : pourquoi cela ne fonctionne pas sur A ?
                                    Je viens de me souvenir qu'une version antérieure avais posé problème pour la volume des pièces crées "en miroir" (je n'ai pas retrouvé le post). Je viens donc de le rajouter à mon modèle que joins, le résultat est également faux.
                                    Test_VolumeSolide.19.skp
                                    • fredo6F
                                      NEW RELEASE: FredoTools v3.8c - 10 Feb 20
                                      FredoTools 3.8c is a minor release for SolidVolume, to fix and issue whereby the volume could be sensititive to the orientation of faces.
                                      • B
                                        bharralure
                                        Bonjour Fredo,
                                        Merci pour cette mise à jour rapide et efficace.
                                        Je viens de tester sur SU19 et SU20, et tout est rentré dans l'ordre, parfait.
                                        • V
                                          volker72
                                          Hello Fredo,
                                          is it possible to do the same with length as ReportLabelArea does with faces.
                                          Volker
                                          • fredo6F
                                            You need to tell which length...length of edges, length of object bounding boxes, ...
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 19 / 24
