    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    104 Posts 40 Posters 144.1k Views 39 Watching
      jtri
      I have some some great uses for this plugin in my modeling, thanks. But when using Drill thru with nested components I get expected results. When using carve I do not see the colors of the nested components. To see the colors I would need to go clean up the model. Is this to be expected with this plugin or operator error? Top model in my example has been cleaned up.
      Visuhole.skp
      • fredo6F
        Yes, when the carving has the same size that the component, you need some cleanup of the thin faces left over by VisuHole. Unfortunately, the intersection in Sketchup is not always predictable for these special cases, and also, since components are separate, you may not want the cleanup.
          jtri
          Thanks for all your plugins and your support!
          • G
            gnome_mo
            @pants said:
            Fredo,
            Hope you got time for this, because it feels so close...anyway, can you confirm that you're able to make up new stencils and have them work as "punches?" I've found this only works for me if I use your "stock" three sample stencils - the ones you provided as defaults. It lets me pick a new shape that turns yellow and shows all signs of being ready to make a hole, but when I double-click, or try to "orient," etc...no hole results...just a "time elapsed" display.
            I also have some Sketchucation plugins-vs-extensions issues/possible confusion. Plugin manager shows current 2/4 version. Later, after finding I was still having problems, I noticed the SUcation Extensions manager still showed the old version (now disabled). I keep thinking there's a need to delete/uninstall old versions, not just disable. Apparently one can disable a plugin and still find that it shows up as the old version, active, but in the SUcation extensions manager. Confusing, to me, anyway.
            Mahalo - Dave
            I have the very same problem. Haven't managed even all default shapes, circle yes and polygon yes, but rectangle doesn't drill. Neither does my shape. (Rougly - looks like letter "T").
            I'm trilling through a floor made of 700 planks.
            Pants, did you manage to drill yours?
              With any image or file it's difficult to say something! ๐Ÿ˜„
              Else I see no dificulties to make some drills on floors, walls etc...
              Just select before your objects then call the crazzy VisuHole! ๐Ÿ˜„
              One of my favorite when you can't use Boolean function who don't existing on the Make Versions! ๐Ÿ˜‰
              Here all object is a Group, and view Front Face
              (will be the same if wall was a floor ! So from View Top)
              Will be of course the same if the form was a "T" ๐Ÿ˜‰
              • G
                gnome_mo
                Here's the file:
                problem.skp
                Shared with Dropbox
                Dropbox (www.dropbox.com)
                  With a file its' very more easy to answer! โ˜€
                  Always post a file is the Golden Rule! ๐Ÿค“
                  It's because your objets are not VOLUMES!!! ๐Ÿ˜ฎ
                  They have no bottom! ๐Ÿ’š
                  They are not homogeneous!
                  It's more difficult for VisuHole!
                  Your objets must be "manifold" without space between us!
                  So draw them "pasted" like my drawing above then use VisuHole then Exploded view" X,Y! ๐Ÿ˜‰
                  • G
                    gnome_mo
                    I didn't think that was the problem, since it drilled simple circle, no problem.
                    But I really need those spaces between them, is it at all possible?
                      Seems you can't!
                      But if you draw a rectangular box between the 2 existing that will works! ๐Ÿ˜‰
                      So not a big deal if you know that from the beginning! ๐Ÿ˜„
                      Just erase the "Joint(s)" at the end! ๐Ÿ˜„
                        Something like this ๐Ÿ˜„
                          jeff1harmed
                          I downloaded and installed VisuHole_v1.4b. I got random results on curved surfaces, and frequent crashes on SU2017. Great potential but unrealised in my case and I had to uninstall
                            Did you also install the latest Lib Fredo ?
                            • K
                              kochmichi86
                              I have a problem with trying to bend small letters (1cm) on a cylinder as the picture shows in the attachement.
                              Could anyone help ?
                                No attachment !
                                If your object is too small, then SketchUp can't cope.
                                Points closer that 1/1000" - as might be created by your tiny sizes and processes - are deemed to be coincident.
                                Then the tiny edges aren't created and their faces are also lost !
                                Try Scaling things up x10 or more and see if that helps ??
                                  ACWN
                                  For some reason I'm having trouble making a stencil. It seems that when I attempt to make a multi-shaped stencil (such as to drill 4 holes of equal size and spacing through a tube), I cannot select the group. Or, if I'm able to, it does not correctly make the stencil.
                                  I've attached the most recent stencil I'm trying to make. The goal is to punch out the holes and leave behind what would be a frame. Yes, I now realize I can go about it a different way, but my problem with making a stencil still stands and I need to know if its something I'm doing thats incorrect or what. So to that end, I've also included a clip of what I'm doing to make the stencil and the results.
                                  So this current stencil is already 60' tall, so it should be large enough but as you can see in the clip, it doesnt trigger like it should.
                                  Can someone tell me whats going on? Thanks!
                                  Component_3.skp
                                  Visuhole.wmv
                                    Hello
                                    You must click a single face or a group or a component of something planed to the XY axes for make a stencil! ๐Ÿ˜‰
                                    Can be of course at any z but must be // to xy plane! โ—
                                    So your vertical one is impossible! ๐Ÿค“
                                    • fredo6F
                                      Actually, you can pick the stencil in any plane, which is given by the face you click.
                                      But don't click-drag, when you do that. Just click-release
                                        Cool! โ˜€ So I was half wrong! ๐Ÿ’š
                                          ACWN
                                          It doesnt show it very well, but I was actually doing just that right at the beginning of the video. Right around 12 - 14 seconds, when I put the mouse to the center of the group and suddenly get the demo shapes. If I click-release, nothing happens. Uploaded a new movie to show.
                                          However when I flip it so its laying flat like Pilou says to, I get it right away. ๐Ÿ˜•
                                          Visuhole2.wmv
                                          • fredo6F
                                            When the stencil is based on a group or component, I was lazy to assume that the Z axis was to be sued as the plan for the stencil.
                                            I made a change in LibFredo6 v9.5f to treat more general cases.
                                            • 4 / 6
