    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    712 Posts 165 Posters 809.1k Views 165 Watching
    • Y Offline
      yoon214
      @Anton_S Of course. The file ending with ".scflicense" is correct. I deleted the file from my computer.
      And I downloaded the attached file from the mail again.
      The file was run by pressing the Validate License button but is not valid
        Gábor
        Could you please try to erase the file C:\Users\username\AppData\Local\SCF Licenses\SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt and then re-try the activation? If fails again please PM me this file for further analysis.
          PM = Private Message
          Accessed through the icon below that user's avatar, on the left-hand side of the screen...
          • Y Offline
            yoon214
            @Gábor
            I erased the file and tried to activate it.
            the results were the same.
            What's PM? I am sorry that I am not good at English.
            • Y Offline
              yoon214
              @TIG Thanks to you, I was able to send him a message.
                Gábor
                @yoon214: Thank you, I've received your PM and answered it.
                  Macon
                  Bonsoir et joyeuses fêtes de fin d'année!
                  Un grand merci pour ce plugin. J'ai pris la licence il y a quelques temps déjà, et je le trouve vraiment génial.
                  Merci à l'auteur!
                  • creativ02C Offline
                    creativ02
                    Hi there,
                    I have the ClothWorks Full plugin about you
                    Article No. WFULL bought. When and to which email address do I receive the email with the license file?
                    Please reply to Th.Edel@t-online.de
                    Mfg Th.Edel
                      Anton_S
                      @creativ02 said:
                      Hi there,
                      Mfg Th.Edel
                      The licence should have arrived to your email address (the one you specified in the purchase steps) unless there are typos or something else. There is also a chance that it may have ended up in your spam folder. Regardless, I emailed your ClothWorks licence and instructions to the provided email address. Please check your email. Thank you for your purchase!
                      • summerson1990S Offline
                        summerson1990
                        Loop subdivision in ClothWorks is a great function because it's easy to project a texture on a flat surface and then with the help of switching drape button see the result on a simulated surface. But I think it works badly. Because after applying loop subdivisions edges lose its vector what causes a texture to be deformed. Look the difference how subD plugin does it and how ClothWorks.
                          Anton_S
                          Thank you for your comment. I recall working on a fix a few months ago (and I believe I composed a couple of solutions). I had additional things planned for the new version, which I haven't got to yet, and figured to delay the release. When I get access to my desktop PC, I will re-prioritize the changes to allow for a sooner new release.
                            summerson1990
                            Cool news! By the way, I'm interested if you could possibly do a feature to place patterns on flat surfaces and then project it to hard, that is to say, such surfaces with which "flowify" or other similar plugins can not work. Look as an example my screenshot. Such a feature presents in Maya, see the video about https://www.youtube.com/watch?v=OeJEthJe6cQ. So how do you think is it possible to realize in SU or what? Thanks!
                              summerson1990
                              Though it will make too many edges that SU will not be able to work with.
                                Anton_S
                                Why not use Blender for wrapping?
                                  summerson1990
                                  Yes, but first I need to study blender a little bit because I haven’t got yet any experience working in it.
                                    majmoonka
                                    Hello Anton! I've bought the licence to Clothworks but it not working correctly. But context menu didn't appear after activation ((
                                      Clothworks shows up in the Context menu when you right click on a group or component. It's not supposed to show up when you right click on a face.
                                      Read steps three and four under Draping Rectangular Table
                                      https://drive.google.com/file/d/1TXQk2AM0HE3BvFLalYPpxQD5YVLIp6fF/view
                                        majmoonka
                                        Thank you! I didn't understand instruction 😳
                                          Bifterx
                                          Hi I just don't get a context menu.
                                          Don't know what I am doing wrong - on 19.3
                                          Valid Licence on 1.7.2a
                                          https://www.dropbox.com/s/d7nf3x0v59kmgqx/Screen%20Shot.png?dl=0
                                            Anton_S
                                            Hello. It seems like you're trying to assign a Pin property to the selected object from within a group. If so, this is not exactly the way to do it. You must a assign a pin property to the outer, top-level group. The inner groups will be treated as sub-pins automatically.
                                            The ClothWorks context menu is mostly available to top level groups and components. Let me know if this answers your question.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 35
                                            • 36
                                            • 23 / 36
