    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    715 Posts 166 Posters 857.0k Views 165 Watching
      Anton_S
      Hi Jacob. Thank you for contacting us regarding the issue. I sent you a private message with your licence. Thanks!
        Jakob86
        Dear Anton_S,
        I received it, it works wonderful - this is a huge step in my "sketch up biography"
        thanks for your incredible work!
        • Y Offline
          yoon214
          win10 / clothworks v1.7.2 / sketchucation v3.1.8 / skechup 2019
          Hi, I bought a license today.
          But I can't register because there error.
          (msg_validation_error Request to Sketchucation = ERROR_A04)
          SCFLICenseSignature - Do not change or delete.
          I deleted the above file and re-registered it. But it still doesn't apply.
          I want you to give me a solution.
          i'm sorry that i am not good at english.
            Anton_S
            @yoon214 Are you following the activation instruction described in ClothWorks licensing manual? Please check out the manual: https://drive.google.com/open?id=14R6lDMZ-4VerlSS_33504qbXS2INzoXJ
            • Y Offline
              yoon214
              @Anton_S I read the manual and followed it again. However, it continues to fail to validate the license it received by mail, an error message appears.
              The contents of the error message are as follows.
              1. I have installed the latest version of SketchUcationTools.
              2. I registered for SketchUcation.
              No matter how many times I try again, the result is the same. I want another solution. T_T..
                Anton_S
                @yoon214 Just making sure. When you click on the Validate License button, are you opening the file ending with ".scflicense"? It may be the case that the file you're opening is different or corrupt. You should download a fresh copy of the file attached with the email you received upon purchasing ClothWorks and activate the file.
                • Y Offline
                  yoon214
                  @Anton_S Of course. The file ending with ".scflicense" is correct. I deleted the file from my computer.
                  And I downloaded the attached file from the mail again.
                  The file was run by pressing the Validate License button but is not valid
                    Gábor
                    Could you please try to erase the file C:\Users\username\AppData\Local\SCF Licenses\SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt and then re-try the activation? If fails again please PM me this file for further analysis.
                      PM = Private Message
                      Accessed through the icon below that user's avatar, on the left-hand side of the screen...
                      • Y Offline
                        yoon214
                        @Gábor
                        I erased the file and tried to activate it.
                        the results were the same.
                        What's PM? I am sorry that I am not good at English.
                        • Y Offline
                          yoon214
                          @TIG Thanks to you, I was able to send him a message.
                            Gábor
                            @yoon214: Thank you, I've received your PM and answered it.
                              Macon
                              Bonsoir et joyeuses fêtes de fin d'année!
                              Un grand merci pour ce plugin. J'ai pris la licence il y a quelques temps déjà, et je le trouve vraiment génial.
                              Merci à l'auteur!
                              • creativ02C Offline
                                creativ02
                                Hi there,
                                I have the ClothWorks Full plugin about you
                                Article No. WFULL bought. When and to which email address do I receive the email with the license file?
                                Please reply to Th.Edel@t-online.de
                                Mfg Th.Edel
                                  Anton_S
                                  @creativ02 said:
                                  Hi there,
                                  Mfg Th.Edel
                                  The licence should have arrived to your email address (the one you specified in the purchase steps) unless there are typos or something else. There is also a chance that it may have ended up in your spam folder. Regardless, I emailed your ClothWorks licence and instructions to the provided email address. Please check your email. Thank you for your purchase!
                                  • summerson1990S Offline
                                    summerson1990
                                    Loop subdivision in ClothWorks is a great function because it's easy to project a texture on a flat surface and then with the help of switching drape button see the result on a simulated surface. But I think it works badly. Because after applying loop subdivisions edges lose its vector what causes a texture to be deformed. Look the difference how subD plugin does it and how ClothWorks.
                                      Anton_S
                                      Thank you for your comment. I recall working on a fix a few months ago (and I believe I composed a couple of solutions). I had additional things planned for the new version, which I haven't got to yet, and figured to delay the release. When I get access to my desktop PC, I will re-prioritize the changes to allow for a sooner new release.
                                        summerson1990
                                        Cool news! By the way, I'm interested if you could possibly do a feature to place patterns on flat surfaces and then project it to hard, that is to say, such surfaces with which "flowify" or other similar plugins can not work. Look as an example my screenshot. Such a feature presents in Maya, see the video about https://www.youtube.com/watch?v=OeJEthJe6cQ. So how do you think is it possible to realize in SU or what? Thanks!
                                          summerson1990
                                          Though it will make too many edges that SU will not be able to work with.
                                            Anton_S
                                            Why not use Blender for wrapping?
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 35
                                            • 36
                                            • 22 / 36
