    [Plugin Library] LibFredo6 - v15.9d - 09 Jul 26
    2.2k Posts 580 Posters 5.7m Views 582 Watching
      markvladi
      After installing LibFredo6_v9.4b, an error appears.
        Did you try restarting SketchUp?
          markvladi
          Yes. After selecting a template, the Bugsplat window crashes. The button "View report data" is not active. After removing the "Fredo6_! LibFredo6 folders" and "Fredo6_! LibFredo6.rb folders" from the plugin directory, SketchUp18 opens. When upgrading to SketchUp19, the same thing happens.
            When you installed SketchUp from the downloaded installer, did you right click on it and choose Run as administrator from the Context menu?
              markvladi
              Yes.
              • Y Offline
                yonofun
                sh: /Users/Jonathan/Documents/Animator Videos/ffmpeg-4.2.2.cpgz: Permission denied
                mac high sierra 10.13.6 I've followed countless tutorials to get ffmpeg installed properly, starting with libfredo6 for animator in sketchup. After downloading the zip and or package file from ffmpeg.org, I don't get the same results from the step by step tutorials. Even in terminal I'm getting unsuccessful responses to line commands at a certain point. I found animator very user friendly and edited a great technical video very efficiently. I'm stuck not being able to generate an mp4 video file to share on my website. Please help
                • fredo6F Offline
                  Did you see my answer in the Animator subforum?
                  I give a link to the latest version of FFmpeg for Mac.
                  • This points to a zip file.
                  • Extract the file 'ffmpeg' located in the zip archive under 'bin'
                  • put this file somewhere on your Mac where it's convenient to you
                  • In the Animator video, Click on the button 'locate FFMpeg' and point to this local file.
                  • fredo6F Offline
                    NEW RELEASE: LibFredo6 v9.5b - 08 Jan 20
                    LibFredo6 9.5b is a minor release for bug fixing and adjustments.
                      penumbra
                      On SU 2018 the new update (with LibFredo v9.5b) is not preserving the guides.
                      (Correction) posted in wrong forum, this comment was meant for Fredo Guides.
                      • fredo6F Offline
                        Could you open the Ruby Console when you protect guides and then when you delete them, in order to see if there are error messages. Thanks.
                          penumbra
                          Annotation 2020-01-09 132839.pngruby console is blank, doesn't show any activity.
                          • fredo6F Offline
                            @penumbra said:
                            [attachment=0:v3qajxdy]<!-- ia0 -->Annotation 2020-01-09 132839.png<!-- ia0 -->[/attachment:v3qajxdy]ruby console is blank, doesn't show any activity.
                            Does the problem happens with any model?
                              penumbra
                              Annotation 2020-01-09 164744.pnginterestingly, no it does not. starting a fresh model the plugin works fine.
                              but here is something that pops up on the ruby consol when i start the sketchup file where it doesn't work.
                              • fredo6F Offline
                                Could you post or PM me the model.
                                Because of this error, the process of protection does not start and thus is not active for this model.
                                • BoxB Offline
                                  Hi Fredo,
                                  I just updated libfredo and it seems to have caused an issue with Curvizard.
                                  Any curve and any action creates stange edges between points.
                                  • fredo6F Offline
                                    @box said:
                                    Hi Fredo,
                                    Many thanks for signaling the problem.
                                    Definitely a major bug, which I fixed in LibFredo6 v9.5c, just published.
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v9.5c - 10 Jan 20
                                      LibFredo6 9.5c fixes a major regression bug affecting Curvizard. It is strongly advised to upgrade
                                      • BoxB Offline
                                        Thanks Fredo for being so proactive and responding so quickly on all your plugins. On my phone at the moment so will confirm as soon as I'm able.
                                        • BoxB Offline
                                          Thanks again Fredo.
                                            penumbra
                                            Hi Fredo
                                            Many thanks for looking at the issues with my file and FredoGuides. I sent you a separate PM with a WeTransfer link. Hopeful the file can shed some light and provide the necessary feedback.
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 111
                                            • 112
                                            • 74 / 112
