    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      Did you try restarting SketchUp?
        markvladi
        Yes. After selecting a template, the Bugsplat window crashes. The button "View report data" is not active. After removing the "Fredo6_! LibFredo6 folders" and "Fredo6_! LibFredo6.rb folders" from the plugin directory, SketchUp18 opens. When upgrading to SketchUp19, the same thing happens.
          When you installed SketchUp from the downloaded installer, did you right click on it and choose Run as administrator from the Context menu?
            markvladi
            Yes.
            • Y Offline
              yonofun
              sh: /Users/Jonathan/Documents/Animator Videos/ffmpeg-4.2.2.cpgz: Permission denied
              mac high sierra 10.13.6 I've followed countless tutorials to get ffmpeg installed properly, starting with libfredo6 for animator in sketchup. After downloading the zip and or package file from ffmpeg.org, I don't get the same results from the step by step tutorials. Even in terminal I'm getting unsuccessful responses to line commands at a certain point. I found animator very user friendly and edited a great technical video very efficiently. I'm stuck not being able to generate an mp4 video file to share on my website. Please help
              • fredo6F Offline
                Did you see my answer in the Animator subforum?
                I give a link to the latest version of FFmpeg for Mac.
                • This points to a zip file.
                • Extract the file 'ffmpeg' located in the zip archive under 'bin'
                • put this file somewhere on your Mac where it's convenient to you
                • In the Animator video, Click on the button 'locate FFMpeg' and point to this local file.
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v9.5b - 08 Jan 20
                  LibFredo6 9.5b is a minor release for bug fixing and adjustments.
                    penumbra
                    On SU 2018 the new update (with LibFredo v9.5b) is not preserving the guides.
                    (Correction) posted in wrong forum, this comment was meant for Fredo Guides.
                    • fredo6F Offline
                      Could you open the Ruby Console when you protect guides and then when you delete them, in order to see if there are error messages. Thanks.
                        penumbra
                        Annotation 2020-01-09 132839.pngruby console is blank, doesn't show any activity.
                        • fredo6F Offline
                          @penumbra said:
                          [attachment=0:v3qajxdy]<!-- ia0 -->Annotation 2020-01-09 132839.png<!-- ia0 -->[/attachment:v3qajxdy]ruby console is blank, doesn't show any activity.
                          Does the problem happens with any model?
                            penumbra
                            Annotation 2020-01-09 164744.pnginterestingly, no it does not. starting a fresh model the plugin works fine.
                            but here is something that pops up on the ruby consol when i start the sketchup file where it doesn't work.
                            • fredo6F Offline
                              Could you post or PM me the model.
                              Because of this error, the process of protection does not start and thus is not active for this model.
                              • BoxB Offline
                                Hi Fredo,
                                I just updated libfredo and it seems to have caused an issue with Curvizard.
                                Any curve and any action creates stange edges between points.
                                • fredo6F Offline
                                  @box said:
                                  Hi Fredo,
                                  Many thanks for signaling the problem.
                                  Definitely a major bug, which I fixed in LibFredo6 v9.5c, just published.
                                  • fredo6F Offline
                                    NEW RELEASE: LibFredo6 v9.5c - 10 Jan 20
                                    LibFredo6 9.5c fixes a major regression bug affecting Curvizard. It is strongly advised to upgrade
                                    • BoxB Offline
                                      Thanks Fredo for being so proactive and responding so quickly on all your plugins. On my phone at the moment so will confirm as soon as I'm able.
                                      • BoxB Offline
                                        Thanks again Fredo.
                                          penumbra
                                          Hi Fredo
                                          Many thanks for looking at the issues with my file and FredoGuides. I sent you a separate PM with a WeTransfer link. Hopeful the file can shed some light and provide the necessary feedback.
                                            pibuz
                                            Hi Fredo!
                                            What a wonderful set of plugins you have done! I am grateful to you, your work is sparing me loads of time!!!
                                            I'd have a question: is there any chance your tool "area report by material" could take into account ALSO the faces which are painted from the outside of a group/component? Since I work a lot with DCs this would be a greatly useful add-on..
                                            Thanks in advance!
                                            WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                            • 77
                                            • 78
                                            • 79
                                            • 80
                                            • 81
                                            • 108
                                            • 109
                                            • 79 / 109
