    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • H
      Ha Kyoung
      I've tried several times to use the plugin you've developed, But everytime I download this'Libfredo6' extension and open sketchup pro, there's a 'Load Error' window saying
      'Error Loading File Fredo6_!LibFredo6.rb
      Error: #<ArgumentError: invalid byte sequence in UTF-8>
      c:/users/오하경/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:52:in gsub' c:/users/오하경/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:52:in get_dir_from_ENV'
      c:/users/오하경/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:415:in `dir_appdata'
      ... and the plugins didn't work
      How can I fix it?
        It is your Korean Windows user-name.
        Ruby used to fail with any text that was not pure ASCII [UTF-8], newer versions have some ways of forcing strings from different alphabets into usable UTF-8 formats.
        Clearly things are failing in your case...
        Can you try the following in your Ruby Console, and report back what it prints - it might help Fredo refine his code...
        Copy/paste this code + <enter>
        plugins = Sketchup.find_support_file('Plugins') puts plugins puts plugins.encoding
        It should print the full path to your plugins folder, and also its encoding...
        • fredo6F
          NEW RELEASE: LibFredo6 v9.3a - 02 Nov 19
          LibFredo6 9.3a is a major release for FredoTools v3.7:
          • FredoTools::ColorByAltitude --> cosmetic adjustments and bug fixing.
          • FredoTools::ColorPaint --> support of transparency, cosmetic adjustments, bug fixing.
          • FredoTools::ReportLabelArea --> cosmetic adjustments and bug fixing.
          It also includes various bug fixing and cosmetic adjustments useful for my other plugins
          • fredo6F
            NEW RELEASE: LibFredo6 v9.4a - 18 Nov 19
            LibFredo6 9.4a is a major release for FredoPortrait v2.0 and FredoTools v3.8:
            • FredoPortrait::Screenshot --> New plugin to generate images at specified dimensions.
            • FredoTools::ColorFlatMode --> New plugin to switch to minimum color shading
            • fredo6F
              NEW RELEASE: LibFredo6 v9.4b - 25 Nov 19
              LibFredo6 9.4b is a minor release for FredoPortrait v2.0:
              • for FredoPortrait v2.0b
              • add a new color palette ('SVG') for FredoTools::ColorPaint
              • fredo6F
                NEW RELEASE: LibFredo6 v9.5a - 23 Dec 19
                LibFredo6 9.5a is a major release for FredoGuides v1.1.
                  markvladi
                  After installing LibFredo6_v9.4b, an error appears.
                    Did you try restarting SketchUp?
                      markvladi
                      Yes. After selecting a template, the Bugsplat window crashes. The button "View report data" is not active. After removing the "Fredo6_! LibFredo6 folders" and "Fredo6_! LibFredo6.rb folders" from the plugin directory, SketchUp18 opens. When upgrading to SketchUp19, the same thing happens.
                        When you installed SketchUp from the downloaded installer, did you right click on it and choose Run as administrator from the Context menu?
                          markvladi
                          Yes.
                          • Y
                            yonofun
                            sh: /Users/Jonathan/Documents/Animator Videos/ffmpeg-4.2.2.cpgz: Permission denied
                            mac high sierra 10.13.6 I've followed countless tutorials to get ffmpeg installed properly, starting with libfredo6 for animator in sketchup. After downloading the zip and or package file from ffmpeg.org, I don't get the same results from the step by step tutorials. Even in terminal I'm getting unsuccessful responses to line commands at a certain point. I found animator very user friendly and edited a great technical video very efficiently. I'm stuck not being able to generate an mp4 video file to share on my website. Please help
                            • fredo6F
                              Did you see my answer in the Animator subforum?
                              I give a link to the latest version of FFmpeg for Mac.
                              • This points to a zip file.
                              • Extract the file 'ffmpeg' located in the zip archive under 'bin'
                              • put this file somewhere on your Mac where it's convenient to you
                              • In the Animator video, Click on the button 'locate FFMpeg' and point to this local file.
                              • fredo6F
                                NEW RELEASE: LibFredo6 v9.5b - 08 Jan 20
                                LibFredo6 9.5b is a minor release for bug fixing and adjustments.
                                • P
                                  penumbra
                                  On SU 2018 the new update (with LibFredo v9.5b) is not preserving the guides.
                                  (Correction) posted in wrong forum, this comment was meant for Fredo Guides.
                                  • fredo6F
                                    Could you open the Ruby Console when you protect guides and then when you delete them, in order to see if there are error messages. Thanks.
                                    • P
                                      penumbra
                                      Annotation 2020-01-09 132839.pngruby console is blank, doesn't show any activity.
                                      • fredo6F
                                        @penumbra said:
                                        [attachment=0:v3qajxdy]<!-- ia0 -->Annotation 2020-01-09 132839.png<!-- ia0 -->[/attachment:v3qajxdy]ruby console is blank, doesn't show any activity.
                                        Does the problem happens with any model?
                                        • P
                                          penumbra
                                          Annotation 2020-01-09 164744.pnginterestingly, no it does not. starting a fresh model the plugin works fine.
                                          but here is something that pops up on the ruby consol when i start the sketchup file where it doesn't work.
                                          • fredo6F
                                            Could you post or PM me the model.
                                            Because of this error, the process of protection does not start and thus is not active for this model.
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 115
                                            • 116
                                            • 74 / 116
