[Plugin] Universal Importer - v1.2.6 - 30 July 2024
441 Posts 106 Posters 432.2k Views 106 Watching
    samuel_t
    @glro said:
    Hi, i tried your plugin
    It worked for a OBJ file
    but not for this DXF file (joined)
    do you know why?
    Import fails because filename contains a '#' character.
    Substitute '#' with '_' and import will be succesful. 😉
    plateforme_202001051957_ca.dxf
      samuel_t
      @khai said:
      thanks again!
      You're welcome! 👍
        paladinjnr
        I have installed the plugin in my SketchUp 2018 , absolutely brilliant
        how ever I am having a problem with textures , models import fine but no textures, which format should the textures be , I have tried dds and png
          ken
          I have not had this program to import any files, STL or OBJ or STP. Below is the following error message I get trying to import an STP file of a nut that is 24k large.
          I did notice in the program, it lists the file as obj file when the file name is, CROSBY 2160 300T NUT.STP.
          Thanks for your help.
          Ken
            samuel_t
            @paladinjnr said:
            Could you please upload whole folder (model and textures) to a file hoster? This way I could debug it.
              samuel_t
              @oxer said:
              Fantastic plugin but I work on mac, is there plan for macos support?
              Good news: I'm working on a macOS version of plugin. 😛 Stay tuned!
                Run SketchUp as Administrator then re-import OBJ model. Let me know if problem persists.
                If this step fixes the issue then it's almost certain that SketchUp was not installed correctly !
                To fix it...
                Whilst logged into Windows as your normal Windows user-name, ensure that SketchUp is closed.
                Find the SketchUp installer's exe file - probably in your Downloads folder ?
                Select the exe file's icon and right-click > context-menu > "Run as administrator"
                When prompted choose "Repair".
                Restart SketchUp and retry...
                Installing any complex app in any other way can cause weird and unpredictable problems, often around permissions...
                So never double-click an installer's exe file to 'Run' it - even if you have admin-powers, it is not the same thing.
                  Didier Bur
                  French translation file 😄
                  fr.zip
                  DB
                    samuel_t
                    @paladinjnr said:
                    Hi Here is a link to the model as requested.
                    Filehorst wurde abgeschaltet! Filehorst has been shut down!
                    (filehorst.de)
                    Your model had absolute paths to textures. That's not supported by plugin.
                    I converted absolute paths to relative paths with a text editor. It's OK now:
                    Fixed DirectX Model
                    Fixed model is attached below:
                    Fixed DirectX Model
                      samuel_t
                      Thank you! 😄
                        Danish9762
                        Hi sir im using sketchup 2017 when i install this plugins by extension manager so im getting unsigned plugin please contact plugins developer. Not working please gix it or tell me how to fix it
                          juju
                          @Danish9762: You need to relax the extension loading policy you have set withing SketchUp.
                            samuel_t
                            @Danish9762 "Unsigned" problem isn't a bug, it just means plugin doesn't come from SketchUp Extension Warehouse.
                            As suggested by @juju, relax SketchUp extension loading policy settings. To access these settings, select Window > Preferences > Extensions Policy (Microsoft Windows) or SketchUp > Preferences > Extensions > Policy tab (OS X). SketchUp has three available extension policy modes: “Identified Extensions Only”, “Approve Unidentified Extensions”, and “Unrestricted”. Select “Unrestricted” then restart SketchUp.
                              sketch3d.de
                              based on the MeshLab engine should maybe be mentioned.
                                paladinjnr
                                Will do
                                (filehorst.de)
                                Many Thanks Rae
                                Thank You for your help, I have spent most of today importing different models , some worked some didn't , so I am gong to give it a break for a couple of weeks then pick it up again .
                                Once again many thanks for your help
                                Keep up the good work
                                Rae
                                  samuel_t
                                  It was already mentioned on GitHub page . And now, it's also mentioned on SketchUcation page .
                                    • O Offline
                                      Oxer
                                      Thanks for the macos version!! 👍
                                      SU2017 & macOS 10.13.6
                                      I found some problems with the importing:
                                      1. If you import a file that contains a space in filename (e.g. Pinas Prueba.obj), it appears a popup message window in Sketchup: "Import Error". I looked in the Console (I opened SketchUp via Terminal) and this is the error message:
                                      assimp export; wrote output file; /Users/Oxer/.UniversalImporter/tmp/Pinas Prueba.obj.dae
                                      Warning; uri contains white space, dom will convert them to %20 in output files!
                                        uri=#Pinas Prueba.obj.obj
                                      Error; daeStandardURIResolver;;resolveElement() - failed to resolve file;//localhost/Users/Oxer/.UniversalImporter/tmp/Pinas Prueba.obj.dae#Pinas Prueba.obj.obj
                                      2. With a file without spaces in filename Universal Importer work fine but nothing is imported, it appears a popup window in Sketchup with this text --> 'An empty component cannot be inserted'
                                      I probed with different file format: obj, dae, fbx, blend and the same in all.
                                      Perhaps it is a SketchUp error or perhaps is a problem with the scale, I don't know it, but I tried changing the 405 line in converter.rb:
                                      dae_export.sub!('meter="1"', 'meter="0.01"')
                                       to
                                       dae_export.sub!('meter="1"', 'meter="1"')
                                      And the Universal Importer inserted a flat component with two lines, see the image:
                                      3. When you select a file (e.g. in the Finder) to import, the plugin copy all Finder files to the temp folder, why? and are this files delete automatically or is it necessary delete manually?
                                      4. A minor detail, the texts 'Select a 3D Model' '3D Models |.3d;.3ds;.3mf;.ac;.ac3d;.acc;...' 'Select a Texture Atlas (Optional)' 'Images |.jpg;.png;*.bmp;||' do not appear in the importing windows.
                                      Again, thanks for your efforts !!
                                        samuel_t
                                        Thanks for detailed report! 😉
                                        @oxer said:
                                        1. If you import a file that contains a space in filename (e.g. Pinas Prueba.obj), it appears a popup message window in Sketchup: "Import Error". [...]
                                        OK. I'm gonna fix that.
                                        @oxer said:
                                        2. With a file without spaces in filename Universal Importer work fine but nothing is imported, it appears a popup window in Sketchup with this text --> 'An empty component cannot be inserted' [...]
                                        Did you tried to import a completely different model? Could you please upload original "Pinas Prueba.obj + mtl + jpg" to a file hoster or here. This way I could debug it.
                                        Model and associated files are copied to a temp folder to avoid invalid characters in path.
                                        These temp files are automatically deleted at each import.
                                        Strange. Maybe it's a SketchUp API bug on MacOS... 😕
                                        • O Offline
                                          Oxer
                                          Hi, I tried to import the same Pinas.obj file with QuadTools plugin and the importing works fine.
                                          Here the files:
                                          Pinas.obj, Pinas.mtl and texture
                                          • 22
                                          • 23
                                          • 1 / 23
                                          1 / 23
