    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 697.0k Views 121 Watching
      dangeruss03
      I Just download it, i can't use Curvishear properly. i try to make ramp for my basement but it seems like something wrong. i don't know what happen and what to do. please help if anybody knew something
      https://drive.google.com/open?id=10pUU20bQVzGIdDTC4R4sciJ__mzsUNbB
        Your image doesn't show. Please attach the SKP file so we can see what you are trying to do and exactly how you have it set up.
          dangeruss03
          Ramp_Trial.skpthis is the file thanks
            I'm not sure what you are doing wrong. I do see that all of your curves are exploded to their individual segments. I welded the curves back together and ran Curvishear. It worked fine for me.
            Maybe you can review the usage instructions here and try again. It would also be helpful if you outline the exact steps you are using as you are setting up for and running Curvishear.
              dangeruss03
              [attachment=0:2rb4kko1]<!-- ia0 -->Screenshot - 12_1_2019 , 8_07_53 AM.png<!-- ia0 -->[/attachment:2rb4kko1]
              But how to weld all the lines, i tried to use super weld plugin and it work just like that
                I used TIG-Weld to do it but I only welded the curves. I did not weld the entire perimeter. Why are the curves exploded in the first place? Maybe you should redraw them so they aren't exploded.
                • O Offline
                  oo7wazzy
                  HI Fredo
                  I downloaded the LibFredo6 package for Sketchup 19 on MAC. It is loaded and installed, but I can't see any of the tools. It is showing in the Window drop down menu but nowhere else that I can see. Have I done something wrong in the installation ? In the extension manager it is Enabled. Any help would be appreciated.
                    Have you quit and restarted SketchUp after installing?
                    Fredo Tools shows in the Tools menu. Do you see that?
                      rv1974
                      Many years I dream of ability to explicitly move the end vertex, run CurviShear and get desired slope (it means curve as required condition has to be ditched).
                      • fredo6F Offline
                        Unless I am wrong, you can do it natively
                        1. Launch the Move tool with no selection
                        2. Hover an extremity, click and drag vertically.
                        3. The curve should deform itself
                          rv1974
                          It won't happen (the curve will be deformed in plan view and it won't even remotely resemble a ramp). That's why CurviShear was created.
                          • fredo6F Offline
                            In short, you would like an interactive version of CurviShear....
                              rv1974
                              No (although I wouldn't disagree). Take a look at TT's Edge tools (last 5 commands).
                              https://sketchucation.com/pluginstore?pln=tt_edgetools
                              I'm talking of CurviShear to adopt the similar way of input.
                              I wouldn't call it interactive. I just feed Curvishear real geometry (bunch of connected edges or polyline) and get result without any input in modal window.
                              • fredo6F Offline
                                But then tt_edgetools does the job.
                                Do I miss something?
                                Or do you want to keep the original curve?
                                  rv1974
                                  CurviShear generates right 'ramp' curve, TT's 'Make colinear' doesn't. That's the main difference πŸ™‚
                                  The only CurviShear's weak link is UI.
                                  Group_728.skp
                                  • fredo6F Offline
                                    Ok. Understood. I put it on my list, but this is what I mean by 'interactive'.
                                      dalenster
                                      Hello, Not sure if I'm posting in the correct location. I have a shape with an image as the face. I'm trying to round the corners and have a smooth transition. However, I'm getting the following results. Is there a workaround, I'm I doing something wrong. I don't think this was a problem in the previous version.
                                      https://muzeoprints.com/wp-content/uploads/2020/01/Rounded-corner-with-image-fail.jpg
                                      • fredo6F Offline
                                        It would be helpful to say which tool you use (RoundCorner, FredoCorner, or something else).
                                        None of these tools have the objective to ensure texture continuity. In general, texture application should be done after the geometry is generated.
                                        Anyway, posting the model would help.
                                          kubap
                                          Hi Fredo,
                                          It's a great plugin, especially ThruPaint. Thank you πŸ˜„
                                          Is it possible to add an option to paint algong the shortest/lognest sides when painting whole groups/components?
                                          It would be great for example for wood furniture so the texture always goes along the long side of a plank. For example when you have a cupboard made of many planks every plank is textured along the longer sides automatically, as it is in real furniture.
                                          Now it's kind of random and the only way is to correct it manually face after face.
                                          • fredo6F Offline
                                            @kubap said:
                                            Is it possible to add an option to paint along the shortest/longest sides when painting whole groups/components?
                                            Unfortunately, Sketchup does not provide any UV control for painting objects (groups or components). The positioning of textures is based on axes and position of the objects.
                                            So, if you want control of orientation, you have to paint at the face level.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 23
                                            • 24
                                            • 18 / 24
