    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      First, try closing and restarting SketchUp.
      Next, look in View>Tool Palettes. Or look in Tools>Fredo6 Collection.
        PeterHead
        need help..
        I already install round corner but the icon didn't show up
          Have you also installed the latest version of Fredo's Lib ?
          Most of his tools require this.
          It's also readily available from the PluginStore...
          Also after installing any tools which use a Lib restart SketchUp to ensure everything gets properly synced...
          • fredo6F Offline
            NEW RELEASE: LibFredo6 v9.2a - 16 Oct 19
            LibFredo6 9.2a is a major release for FredoTools v3.6:
            • FredoTools::ColorByAltitude tool, which create a color mapping for a terrain mesh based on the altitude of its faces.
            • FredoTools::ColorPaint tool, which is a configurable Color Selector.
            • A new view 'Outliner' in FredoTools::ReportLabelArea tool, with a hierarchical, expandable tree of groups and components with their individual areas.
            It also includes various bug fixing and cosmetic adjustments.
            • H Offline
              Ha Kyoung
              I've tried several times to use the plugin you've developed, But everytime I download this'Libfredo6' extension and open sketchup pro, there's a 'Load Error' window saying
              'Error Loading File Fredo6_!LibFredo6.rb
              Error: #<ArgumentError: invalid byte sequence in UTF-8>
              c:/users/μ˜€ν•˜κ²½/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:52:in gsub' c:/users/μ˜€ν•˜κ²½/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:52:in get_dir_from_ENV'
              c:/users/μ˜€ν•˜κ²½/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:415:in `dir_appdata'
              ... and the plugins didn't work
              How can I fix it?
                It is your Korean Windows user-name.
                Ruby used to fail with any text that was not pure ASCII [UTF-8], newer versions have some ways of forcing strings from different alphabets into usable UTF-8 formats.
                Clearly things are failing in your case...
                Can you try the following in your Ruby Console, and report back what it prints - it might help Fredo refine his code...
                Copy/paste this code + <enter>
                plugins = Sketchup.find_support_file('Plugins') puts plugins puts plugins.encoding
                It should print the full path to your plugins folder, and also its encoding...
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v9.3a - 02 Nov 19
                  LibFredo6 9.3a is a major release for FredoTools v3.7:
                  • FredoTools::ColorByAltitude --> cosmetic adjustments and bug fixing.
                  • FredoTools::ColorPaint --> support of transparency, cosmetic adjustments, bug fixing.
                  • FredoTools::ReportLabelArea --> cosmetic adjustments and bug fixing.
                  It also includes various bug fixing and cosmetic adjustments useful for my other plugins
                  • fredo6F Offline
                    NEW RELEASE: LibFredo6 v9.4a - 18 Nov 19
                    LibFredo6 9.4a is a major release for FredoPortrait v2.0 and FredoTools v3.8:
                    • FredoPortrait::Screenshot --> New plugin to generate images at specified dimensions.
                    • FredoTools::ColorFlatMode --> New plugin to switch to minimum color shading
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v9.4b - 25 Nov 19
                      LibFredo6 9.4b is a minor release for FredoPortrait v2.0:
                      • for FredoPortrait v2.0b
                      • add a new color palette ('SVG') for FredoTools::ColorPaint
                      • fredo6F Offline
                        NEW RELEASE: LibFredo6 v9.5a - 23 Dec 19
                        LibFredo6 9.5a is a major release for FredoGuides v1.1.
                          markvladi
                          After installing LibFredo6_v9.4b, an error appears.
                            Did you try restarting SketchUp?
                              markvladi
                              Yes. After selecting a template, the Bugsplat window crashes. The button "View report data" is not active. After removing the "Fredo6_! LibFredo6 folders" and "Fredo6_! LibFredo6.rb folders" from the plugin directory, SketchUp18 opens. When upgrading to SketchUp19, the same thing happens.
                                When you installed SketchUp from the downloaded installer, did you right click on it and choose Run as administrator from the Context menu?
                                  markvladi
                                  Yes.
                                  • Y Offline
                                    yonofun
                                    sh: /Users/Jonathan/Documents/Animator Videos/ffmpeg-4.2.2.cpgz: Permission denied
                                    mac high sierra 10.13.6 I've followed countless tutorials to get ffmpeg installed properly, starting with libfredo6 for animator in sketchup. After downloading the zip and or package file from ffmpeg.org, I don't get the same results from the step by step tutorials. Even in terminal I'm getting unsuccessful responses to line commands at a certain point. I found animator very user friendly and edited a great technical video very efficiently. I'm stuck not being able to generate an mp4 video file to share on my website. Please help
                                    • fredo6F Offline
                                      Did you see my answer in the Animator subforum?
                                      I give a link to the latest version of FFmpeg for Mac.
                                      • This points to a zip file.
                                      • Extract the file 'ffmpeg' located in the zip archive under 'bin'
                                      • put this file somewhere on your Mac where it's convenient to you
                                      • In the Animator video, Click on the button 'locate FFMpeg' and point to this local file.
                                      • fredo6F Offline
                                        NEW RELEASE: LibFredo6 v9.5b - 08 Jan 20
                                        LibFredo6 9.5b is a minor release for bug fixing and adjustments.
                                          penumbra
                                          On SU 2018 the new update (with LibFredo v9.5b) is not preserving the guides.
                                          (Correction) posted in wrong forum, this comment was meant for Fredo Guides.
                                          • fredo6F Offline
                                            Could you open the Ruby Console when you protect guides and then when you delete them, in order to see if there are error messages. Thanks.
                                            • 108
                                            • 109
                                            • 1 / 109
