    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • HornOxxH Offline
      HornOxx
      SubD´s range of possibilities couldn't be better illustrated than with Alsomar´s corinthian column masterpiece and Box´s ingenious Guitar Pic quicky-exercise (both above here) - both are great examples! Thanks for sharing 😄
      never trust a skinny cook
      • alsomarA Offline
        alsomar Extension Creator
        D'oh! What a great Homer!
        Alejandro Soriano Visuals · All my links
        • alsomarA Offline
          Hello there!
          Here's a vintage fan I modelled yesterday. Besides SUbD I used some other extensions like VertexTools and QuadFace Tools.
          Rendered pic in V-Ray
          Rendered pic in V-Ray (quads overlayed)
          Views in SketchUp (0 subdivisions)
          Views in SketchUp (2 subdivisions)
          Views in SketchUp (just profiles)
          • HornOxxH Offline
            HornOxx
            ... Prima !! 👍
            • BoxB Offline
              Excellent.
              • alsomarA Offline
                An old fashioned caravan.
                • HornOxxH Offline
                  HornOxx
                  😄 👍 ... again a so nice model idea - especially with the box-shaped carriage, I wouldn't have guessed SubD first 😄
                  • HornOxxH Offline
                    HornOxx
                    Hi All - To bring my Homer Simpson endless project to an end, I finally decided to put him on his white shirt, his blue pants and his shoes. Finally the winter is approaching here and Homer should not freeze 😄
                    If anyone wants to SubD-play with this thick cuddly yellow guy himself, I´ll add the entire proxy model here...
                    The rendered model, without SubD-function then, is also available in the 3D Warehouse:
                    https://3dwarehouse.sketchup.com/model/60074a83-9b9d-4f29-85aa-73cf6e29be75/Homer-Simpson-by-HornOxx
                    edit: pic2 - did some minor modeling improvements at Homer's mouth
                    PROXY model
                    • BoxB Offline
                      A little early morning SUbD insanity, took quite a while to subdivide. I wouldn't have done the whole thing if I had thought about it properly, just one segment and array. But this is all one piece with thickness and is a solid. Added the cutaway to see the inner structure.
                        • BoxB Offline
                          Just a bit of fun. For the absolute simplicity of it.
                          • HornOxxH Offline
                            HornOxx
                            ... wunderbar - how does this inner glass shape look like (raw)? Somewhere I read of "extra thumbs up" - you know where it right now comes from...
                            • BoxB Offline
                              Is this what you mean?
                              I didn't save the model so I reproduced it.
                              Note the outer layer I have thickened with JPP, not shown in the original image.
                              • BoxB Offline
                                This one shows how if you SUbD before JPP you get the sharp edges in the original render rather than the soft ones in the second model.
                                • HornOxxH Offline
                                  HornOxx
                                  Thanks, now I got it 😄 - I first assumed to see 2 shapes above. To see your competent handling with geometry is impressive allways 👍 - for exampe that you started with a section plane to generate this first shape ...
                                  • BoxB Offline
                                    No, you are right, there are two shapes, the red and the blue. The blue one fits around the red one.
                                    Here's the rest of it, hope that makes sense.
                                    • HornOxxH Offline
                                      HornOxx
                                      Yes 😄 - and I really enjoy this kind of geometry exercises ...
                                      • V Offline
                                        Vizan
                                        @cotty said:
                                        Hopefully the beginning of a looong and helpful topic...
                                        How did you render with a square grid without triangles? It doesn’t work out for me((
                                          Callegari_hr
                                          In QuadFaceTools plugin there is Convert Triangulated Mesh to Quads, select two triangles of one quad and run that tool.
                                          • cottyC Offline
                                            cotty
                                            You can use this tool with no visible hidden geometry for it.
                                            my SketchUp gallery
                                            • 82
                                            • 83
                                            • 4 / 83
